  <title>R-pod Owners Forum : Potential Podder</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Potential Podder</description>
  <pubDate>Thu, 24 Sep 2026 23:13:03 +0000</pubDate>
  <lastBuildDate>Wed, 17 Jun 2015 19:41:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6438</WebWizForums:feedURL>
   <title>Potential Podder : Thank you sir! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61954#61954</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4168" rel="nofollow">klaster23</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 7:41pm<br /><br />Thank you sir!]]>
   <pubDate>Wed, 17 Jun 2015 19:41:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61954#61954</guid>
   <title>Potential Podder : Current discussion with my recommendations...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61938#61938</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 2:53pm<br /><br /><p>Current discussion with my recommendations for small inverters here:&nbsp; <a href="http://www.rpod-owners.com/forum_posts.asp?TID=6427&amp;title=upgrade-batteries-and-propane" target="_blank">http://www.rpod-owners.com/forum_posts.asp?TID=6427&amp;title=upgrade-batteries-and-propane</a></p>]]>
   <pubDate>Wed, 17 Jun 2015 14:53:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61938#61938</guid>
   <title>Potential Podder : Thanks for the welcome, tips,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61930#61930</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4168" rel="nofollow">klaster23</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 1:16pm<br /><br />Thanks for the welcome, tips, and ideas. <br /><br />I do think I will probably just go with the simple two battery setup to start off with and see how that goes just doing a few days of dry camping at a time. <br />For techntrek or anyone else, what size inverter and other mods or equipment would you suggest to go with that two battery setup? <br />]]>
   <pubDate>Wed, 17 Jun 2015 13:16:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61930#61930</guid>
   <title>Potential Podder : Welcome </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61913#61913</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 9:06am<br /><br />Welcome]]>
   <pubDate>Wed, 17 Jun 2015 09:06:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61913#61913</guid>
   <title>Potential Podder :   Welcome. If you will camp...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61904#61904</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 8:37am<br /><br />Welcome.&nbsp; If you will camp where you will be in shade, solar won't do much for you.&nbsp; Even just a corner of a panel shaded will drop the output dramatically.&nbsp; For your time frame you may want to just add a 2nd battery.&nbsp; With conservation you won't need solar or a generator.]]>
   <pubDate>Wed, 17 Jun 2015 08:37:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61904#61904</guid>
   <title>Potential Podder : Just a note; You will need a 120...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61898#61898</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3971" rel="nofollow">Pooterpod</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 7:55am<br /><br />Just a note; You will need a 120 AC plug in or a generator to run the Air , microwave, &nbsp;and&nbsp;most likely the&nbsp;&nbsp;hair dryer and &nbsp;small electric heater.&nbsp;]]>
   <pubDate>Wed, 17 Jun 2015 07:55:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61898#61898</guid>
   <title>Potential Podder : I&amp;#039;m not going to be any help...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61884#61884</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3006" rel="nofollow">Marx</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 6:42am<br /><br />I'm not going to be any help with the solar stuff but I know others who are that will chime in.&nbsp; The RPOD is a great camper and super lite, might get a bit stuffy inside when dry camping though so I'd recommend a fan to push some air and potentially a generator too.&nbsp; Good luck with your search.]]>
   <pubDate>Wed, 17 Jun 2015 06:42:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61884#61884</guid>
   <title>Potential Podder : Hello,The wife and i are looking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61878#61878</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4168" rel="nofollow">klaster23</a><br /><strong>Subject:</strong> 6438<br /><strong>Posted:</strong> 17 Jun 2015 at 12:00am<br /><br />Hello,<div></div><div>The wife and i are looking into purchasing a small camper in the near future.  We love tent camping, but we would like to upgrade to a camper.  I've done a good bit of research over the past month or two and I've come to the conclusion that the R-Pod just might be the best bet for us.  We really like the R-Pod for a couple reasons: </div><div>1. It is a good size for our needs (just the two of us and our pup) </div><div>2. It is a good size to be towed by my jeep cherokee 3.2L V6 </div><div>3. We like the internal and external aesthetics and features (especially the 178 floor plan)</div><div>4. Because we plan to camp both at campground and do some dry camping, we really that it is solar ready and eco friendly.</div><div></div><div>On the solar topic, I've done a ton of reading on here and just in general and have a good idea of approximately how much I would need to invest on solar equipment, but I'd like to hear what some of you think.  </div><div>First off, we will likely only be dry camping for a few days (3-4) at a time.  We will plan to only dry camp when its neither too hot or too cold to avoid using A/C or heat as much as possible.  Our favorite part about camping is getting outside and exploring: hiking, kayaking, sight seeing, etc. so we won't be using a ton of power during the day on most days.  We will also try to minimize the use of power hungry appliances such as microwave and hair dryer.  We will do the majority of our cooking on the range using propane or outside on a grill.  We will be using cell phones, laptops, and TV during the evenings and on days when weather keeps us inside and maybe some small fans or a small space heater when it gets warm or chilly. <br />Based on what i said above i was thinking about purchasing a 100w-120w solar panel, a 1000w pure sine wave inverter, and a second 12v deep cycle battery.  I know there's additonal solar equipment i would need to purchase, but those wouldbe the most expensive.<br />Basically I'm just trying to figure out if I'm on track with the equipment based on my needs and approximately how much i would be looking at spending on the solar equipment on top of what i would be investing in the camper itself. <br /><br />Thanks podders!<br /><br />Kyle]]>
   <pubDate>Wed, 17 Jun 2015 00:00:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6438&amp;PID=61878#61878</guid>
