  <title>R-pod Owners Forum : 12 volt / 120 volt question</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : 12 volt / 120 volt question</description>
  <pubDate>Thu, 26 Nov 2026 16:19:08 +0000</pubDate>
  <lastBuildDate>Thu, 21 May 2015 13:54:41 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6279</WebWizForums:feedURL>
   <title>12 volt / 120 volt question : Thanks podster That is all the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60602#60602</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3984" rel="nofollow">802 JJ</a><br /><strong>Subject:</strong> 6279<br /><strong>Posted:</strong> 21 May 2015 at 1:54pm<br /><br />Thanks podster<br />That is all the info I need ( for that question anyways )<br />Great info<br />802 JJ]]>
   <pubDate>Thu, 21 May 2015 13:54:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60602#60602</guid>
   <title>12 volt / 120 volt question :  Usually that is the case, converting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60589#60589</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 6279<br /><strong>Posted:</strong> 21 May 2015 at 7:27am<br /><br />Usually that is the case, converting power generally cost you about 10% loss. The modern HDTV, Visio, pulls about 25 AC watts. I do use a 150w MSW inverter to power it. I figure it consumes about 2 AH DC. Not to bad. So yes, 12v devises are more efficient to run on a 12v system. However, on smaller low draw devices with the right size inverter it will cost you a little, but not a bunch to where its just crazy to do it.&nbsp;<div><br></div><div>Just for reference, generally, for every 100w of AC power that your inverter is pulling, it will draw 10DC amps from the battery.&nbsp;</div><div><br></div><div><br></div>]]>
   <pubDate>Thu, 21 May 2015 07:27:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60589#60589</guid>
   <title>12 volt / 120 volt question : Oops I was so excited about my...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60586#60586</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3984" rel="nofollow">802 JJ</a><br /><strong>Subject:</strong> 6279<br /><strong>Posted:</strong> 21 May 2015 at 2:25am<br /><br />Oops I was so excited about my r pod I forgot to ask my question. Does anyone know if a 110 v TV pluged into a 140 watt power inverter will use more battery power than a regular 12 v TV ? I'm assuming it does but not sure. <br />Thanks]]>
   <pubDate>Thu, 21 May 2015 02:25:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60586#60586</guid>
   <title>12 volt / 120 volt question : Congrats! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60573#60573</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6279<br /><strong>Posted:</strong> 20 May 2015 at 8:29pm<br /><br />Congrats!]]>
   <pubDate>Wed, 20 May 2015 20:29:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60573#60573</guid>
   <title>12 volt / 120 volt question : Enjoy!!! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60568#60568</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 6279<br /><strong>Posted:</strong> 20 May 2015 at 7:46pm<br /><br />Enjoy!!!]]>
   <pubDate>Wed, 20 May 2015 19:46:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60568#60568</guid>
   <title>12 volt / 120 volt question : Hello fellow podders today I did...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60566#60566</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3984" rel="nofollow">802 JJ</a><br /><strong>Subject:</strong> 6279<br /><strong>Posted:</strong> 20 May 2015 at 7:38pm<br /><br />Hello fellow podders today I did it ! Bought a new HRE 171 named " KAMP KRAMP " Can't wait to start my mods. <br />Thanks to all that have responded to my questions. It is really cool to find a group of people that help each other out and keep in touch all because of a frog and some rings ! 🐸 ♻️ 🔘<br /><br />Thank you all]]>
   <pubDate>Wed, 20 May 2015 19:38:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6279&amp;PID=60566#60566</guid>
