  <title>R-pod Owners Forum : Torsion axle assembly</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : Torsion axle assembly</description>
  <pubDate>Wed, 23 Sep 2026 09:22:44 +0000</pubDate>
  <lastBuildDate>Mon, 25 May 2015 11:10:34 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6254</WebWizForums:feedURL>
   <title>Torsion axle assembly : I have an Indiana POD and it has...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60732#60732</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 25 May 2015 at 11:10am<br /><br />I have an Indiana POD and it has a Lippert axle. Lippert is located in Indiana.&nbsp;]]>
   <pubDate>Mon, 25 May 2015 11:10:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60732#60732</guid>
   <title>Torsion axle assembly : I believe that FR used Lippert...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60728#60728</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=648" rel="nofollow">Goose</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 25 May 2015 at 10:25am<br /><br />I believe that FR used Lippert axles for those PODS made out west and Dexter axles for those that were made in Indiana. Goose]]>
   <pubDate>Mon, 25 May 2015 10:25:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60728#60728</guid>
   <title>Torsion axle assembly :   Originally posted by Alaskan...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60722#60722</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1004" rel="nofollow">Seanl</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 25 May 2015 at 8:43am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Alaskan Road Warrior</strong></em><br /><br />I bought my 2012 R pod 172 and love it. Just drove home to Alaska and noticed that one of my tires (door side) wore very uneven. The middle of the tire looks new. There is only 5-7 thousand on tires. Wondering if it could be axle trouble? I did have the wheel bearings done before I hit the rode. We keep proper pressure and not overloaded. Thanks for any suggestions. Thank you Ausdland for the post. Happy Memorial Weekend to all</td></tr></table><div><br></div><div>Did it wear out on one side or both?</div><div><br></div><div><br></div>]]>
   <pubDate>Mon, 25 May 2015 08:43:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60722#60722</guid>
   <title>Torsion axle assembly : I bought my 2012 R pod 172 and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60653#60653</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4017" rel="nofollow">Alaskan Road Warrior</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 23 May 2015 at 1:09am<br /><br />I bought my 2012 R pod 172 and love it. Just drove home to Alaska and noticed that one of my tires (door side) wore very uneven. The middle of the tire looks new. There is only 5-7 thousand on tires. Wondering if it could be axle trouble? I did have the wheel bearings done before I hit the rode. We keep proper pressure and not overloaded. Thanks for any suggestions. Thank you Ausdland for the post. Happy Memorial Weekend to all]]>
   <pubDate>Sat, 23 May 2015 01:09:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60653#60653</guid>
   <title>Torsion axle assembly :   FR uses two manufacturers,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60389#60389</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 17 May 2015 at 4:47pm<br /><br />FR uses two manufacturers, Dexter and Lippert. They are both long established manufacturers with a good reputation. Airstream uses the same manufacturers and components. And has for decades. A replacement is not all that expensive, but paying a shop to order and instal it may be. If you order one "drum to drum" it would be 4 bolts and 4 wire connections to change. I've helped with a couple on older 'streams. Ours are 35 years old, and still sit fine.<br><br>As far as knowing which you have, look under the trailer and read the label. It really is that easy. In fact there are some codes on it that describe the axle, and could be handy to have a picture of if you at some time in the future needed to order a replacement on YOUR dime.. :)<br>]]>
   <pubDate>Sun, 17 May 2015 16:47:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60389#60389</guid>
   <title>Torsion axle assembly : Sorry, idk. I do know FR doesn&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60387#60387</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3517" rel="nofollow">ausdland</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 17 May 2015 at 4:39pm<br /><br />Sorry, idk. I do know FR doesn't manufacture the axle; they had to get one from the actual manufacturer then ship to the dealer.]]>
   <pubDate>Sun, 17 May 2015 16:39:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60387#60387</guid>
   <title>Torsion axle assembly : Could you tell us who is the manufacturer?...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60381#60381</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 17 May 2015 at 4:19pm<br /><br />&nbsp; &nbsp;Could you tell us who is the manufacturer? I wonder if Forest River has used different manufacturers.&nbsp;]]>
   <pubDate>Sun, 17 May 2015 16:19:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60381#60381</guid>
   <title>Torsion axle assembly : Folks, Keep an eye on your trailer&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60378#60378</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3517" rel="nofollow">ausdland</a><br /><strong>Subject:</strong> 6254<br /><strong>Posted:</strong> 17 May 2015 at 3:58pm<br /><br />Folks,<br />Keep an eye on your trailer's wheels/tires while you're driving especially at speed. I took my pod into a local dealer for some warranty trim work in March and on the way noticed my driver's side tire wobbling. It took the dealer 3-4 weeks to get to it and they found the torsion axle assembly to be defective. I just bought the pod in Feb and had only driven from Oregon back to SF. Well, it took FR another 3-4 weeks to get to it, but they did replace the entire assembly under warranty just in time for my trip to Utah. The dealer said they've replaced 3 TA assemblies on pods just in this year. It may be a common problem? And I'm sure it'd be expensive out of warranty. fyi]]>
   <pubDate>Sun, 17 May 2015 15:58:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6254&amp;PID=60378#60378</guid>
