  <title>R-pod Owners Forum : RP179 frame electrified</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : RP179 frame electrified</description>
  <pubDate>Wed, 23 Sep 2026 09:22:23 +0000</pubDate>
  <lastBuildDate>Thu, 07 May 2015 08:17:22 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6171</WebWizForums:feedURL>
   <title>RP179 frame electrified : Thanks Doug We were confused too....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59768#59768</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3135" rel="nofollow">Shadow</a><br /><strong>Subject:</strong> 6171<br /><strong>Posted:</strong> 07 May 2015 at 8:17am<br /><br />Thanks Doug<br />We were confused too. Went out later in the afternoon and no voltage recordings from the frame.  <br />The slide motor is still running rough.  Can't figure that one out either so will take it into the dealer ( Travek mor - excellent service to date)<br /><br />Shirley]]>
   <pubDate>Thu, 07 May 2015 08:17:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59768#59768</guid>
   <title>RP179 frame electrified :   Something isn&amp;#039;t right....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59658#59658</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6171<br /><strong>Posted:</strong> 05 May 2015 at 12:40pm<br /><br />Something isn't right.&nbsp; The&nbsp;NCVT will only detect AC voltages,&nbsp;I just checked the specs and the Klein dual-range NCVT&nbsp;to be sure.&nbsp; Even though the dual-range model will detect as low as 12 volts, it still must be AC and not DC.&nbsp; ]]>
   <pubDate>Tue, 05 May 2015 12:40:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59658#59658</guid>
   <title>RP179 frame electrified : HiThe slide out on our 179 was...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59648#59648</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3135" rel="nofollow">Shadow</a><br /><strong>Subject:</strong> 6171<br /><strong>Posted:</strong> 05 May 2015 at 10:07am<br /><br />Hi&nbsp;<div>The slide out on our 179 was going in and out very roughly. &nbsp;Checked the panel for the slide and red light of continuous flash this Suggesting power to ground error &nbsp;- occurred when on battery power &nbsp;or &nbsp;when plugged in. We've checked all the wires coming into the slide and don't see any obvious loose connections ( as one who knows very little about electricity). &nbsp; On a whim decided to use our new non touch volt meter and while ON BATTERY &nbsp;the entire frame (including all the metal propane connections) makes the volt meter beep and flash rapidly. &nbsp;We had checked iusing the non touch volt meter &nbsp;last week before our first trip and no response from the volt meter ( no problem with the slide last week either.&nbsp;</div><div><br></div><div>Obviously ( I&nbsp;<span style="line-height: 1.4;">think) we have a grounding issue. Dealer is talking to ?Liebart? (Factory) for direction. &nbsp;Any suggestions ideas...</span></div><div><span style="line-height: 1.4;"><br></span></div><div>Big thanks for recommendation of buying and using the non touch volt meter!!!!</div><div><br></div><div>Shirley</div>]]>
   <pubDate>Tue, 05 May 2015 10:07:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59648#59648</guid>
   <title>RP179 frame electrified : hi all </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59646#59646</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3135" rel="nofollow">Shadow</a><br /><strong>Subject:</strong> 6171<br /><strong>Posted:</strong> 05 May 2015 at 9:51am<br /><br />hi all]]>
   <pubDate>Tue, 05 May 2015 09:51:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6171&amp;PID=59646#59646</guid>
