  <title>R-pod Owners Forum : tow</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : tow</description>
  <pubDate>Thu, 24 Sep 2026 22:20:53 +0000</pubDate>
  <lastBuildDate>Mon, 13 Apr 2015 13:16:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6044</WebWizForums:feedURL>
   <title>tow : There are solutions for a sloppy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58884#58884</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 13 Apr 2015 at 1:16pm<br /><br />There are solutions for a sloppy receiver, here is just one: &nbsp;<a href="http://www.etrailer.com/Hitch-Accessories/Bo&#111;ne-Outdoor/93347.html" target="_blank">http://www.etrailer.com/Hitch-Accessories/Boone-Outdoor/93347.html</a><div><br></div><div>For the exhaust, I would look at other alternatives, like adding a support that pulls the exhaust away from the problem area, or adding some silicone caulk on the spot to remove the metal-on-metal contact.</div>]]>
   <pubDate>Mon, 13 Apr 2015 13:16:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58884#58884</guid>
   <title>tow : Thanks - that&amp;#039;s helpful....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58869#58869</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3785" rel="nofollow">Robert Free</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 13 Apr 2015 at 5:54am<br /><br />Thanks - that's helpful. I've now discovered two separate sources of knocking. The first is that the receiver for the trailer hitch is indeed bigger than the hitch. The whole thing wiggles quite significantly and I can hear that on uneven surfaces at speed (but not starting off).&nbsp;<div><br></div><div>Then there's another noise - which I've now tracked to the fact that the Curt hitch has less than 3/4" clearance from my tail pipe on one side and that once the exhaust system is hot and under certain engine loads (eg. changing up a gear) it knocks against it briefly.&nbsp;</div><div><br></div><div>Not sure there's an easy fix to either of these things. Unless there's some shim solution to the hitch square problem? And in terms of the Curt hitch it'd mean cutting a small section out of the one side of the t-bar under the car. Which I'm cautious to do...</div><div><br></div><div>Anyway, I think these two things fall into the category of annoying rather than urgent.</div><div><br></div><div>The ride quality seemed to improve once I filled up the R-pod fresh water tank, which looks to be behind the axle and therefore presumably reduced tongue weight. Still no sway, so that seems to be a happy medium.</div><div><br></div><div>Other than that, the rig has done quite well and I'm now in southern Utah. 11-12mpg, the car has been stout and the power-to-weight ratio has actually felt better than the triple-e Unity Mercedes sprinter RV that I rented a couple of years ago. There have been some biggish passes and some moderate sidewinds, but no heart-stopping moments.&nbsp;</div>]]>
   <pubDate>Mon, 13 Apr 2015 05:54:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58869#58869</guid>
   <title>tow : Some receivers (the square part...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58814#58814</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 11 Apr 2015 at 10:35pm<br /><br />Some receivers (the square part mounted on the TV) are slightly too big, so when the hitch is mounted it can move slightly. &nbsp;That will sound like a thump on bumps and uneven roads because as the pod's tongue rises the hitch can wiggle around momentarily. &nbsp;Usually when you have a WDH in place it won't thump when starting or stopping because it is maintaining upward pressure on the hitch. &nbsp;With your hitch in place but not hooked to the pod, can you wiggle it around? &nbsp;<div><br></div><div>Some squeaking when starting may be the WDH, or the ball.</div><div><br></div><div>Check your owner's manual, it may state one maximum w/o a WDH and another with a WDH. &nbsp;You want to keep the pod's tongue weight at 10-15% of the total weight of the pod for proper handling, so don't unload it too much.</div><div><br></div><div>Normal when towing, but if a WDH is set up correctly the ride quality should be comfortable because the front axle will be close to its normal height and the rear axle will be within an inch or two. &nbsp;Plus the WDH adds an extra suspension system to the whole rig with its spring bars.</div>]]>
   <pubDate>Sat, 11 Apr 2015 22:35:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58814#58814</guid>
   <title>tow :   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58762#58762</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3785" rel="nofollow">Robert Free</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 10 Apr 2015 at 10:10am<br /><br /><div>&nbsp;</div>]]>
   <pubDate>Fri, 10 Apr 2015 10:10:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58762#58762</guid>
   <title>tow : It would be nice to know which...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58691#58691</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 6:18pm<br /><br />It would be nice to know which engine was in the Rover used for that test, as it's a eurospec, it could be the bigger diesel.. would make a difference I think.]]>
   <pubDate>Tue, 07 Apr 2015 18:18:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58691#58691</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58689#58689</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3785" rel="nofollow">Robert Free</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 5:04pm<br /><br />&nbsp;]]>
   <pubDate>Tue, 07 Apr 2015 17:04:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58689#58689</guid>
   <title>tow :   If you can rent locally thatmay...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58671#58671</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 12:44pm<br /><br />If you can rent locally that&nbsp;may be a better option.&nbsp; Remember to take into the equation the amount of gas you save by not towing it all the way there and back at 12 mpg (US) <em>or less</em>.&nbsp; Probably half of what you normally get.<div>&nbsp;</div><div>Your specs have just enough power and torque, minimum.&nbsp; 6 speed tranny is good, it will be geared lower on 1st and 2nd gear than a 4-speed to get off the line easier while towing.&nbsp; Average sized brakes for that towing limit.&nbsp; </div><div>&nbsp;</div><div>The biggest limitation is the wheel base, 105 inches is short for towing.&nbsp; Which means a sway bar or WDH with sway control is a must.&nbsp; NOT just the "sway control" built into the vehicle, that is secondary to real sway control.&nbsp; That just&nbsp;selectively applies the brakes to dampen sway after it has started, causing excessive brake wear and heating.&nbsp;&nbsp; See the link in my signature for more info on controlling sway - a short wheel base is one of the biggest contributors to starting sway.</div>]]>
   <pubDate>Tue, 07 Apr 2015 12:44:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58671#58671</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58665#58665</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3785" rel="nofollow">Robert Free</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 9:43am<br /><br />&nbsp;]]>
   <pubDate>Tue, 07 Apr 2015 09:43:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58665#58665</guid>
   <title>tow : It&amp;#039;s not going to be the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58661#58661</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 8:42am<br /><br />It's not going to be the weight alone, it's also about frontal area, and as aero as a pod <i>looks</i>.. they are not. Your owners manual may very well address this, mine does.<br><br>I suspect that trip, with that combination of trailer and tow vehicle would be pretty hard on everybody and everything, involved.<br>]]>
   <pubDate>Tue, 07 Apr 2015 08:42:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58661#58661</guid>
   <title>tow : Ditto to everything Tars said....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58660#58660</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3180" rel="nofollow">Luv2Q</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 8:39am<br /><br />Ditto to everything Tars said. &nbsp;Good luck with whatever you decide.]]>
   <pubDate>Tue, 07 Apr 2015 08:39:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58660#58660</guid>
   <title>tow : You are at the bare minimum in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58659#58659</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 1:22am<br /><br />You are at the bare minimum in terms of capability.&nbsp; I'm not an expert, or even competent at dealing with technical specs, but it sounds like your Evoque will work, but I'd be surprised if you'll be happy with it as a tow vehicle for the Pod.&nbsp; Towing is about safety more than anything.&nbsp; You will almost certainly need a weight distributing hitch (which adds weight that counts against your load) and sway control to be safe.&nbsp; It goes without saying, but here I go anyway, that a brake controller is essential for safety and legality.&nbsp; You are still going to be very much aware of your extra load, and you won't be doing your engine or transmission any favors.<br><br>On smooth roads you'll probably be fine.&nbsp; On long hills, or mountain passes, you will probably be cursing the Evoque, the Pod, yourself, or something.&nbsp; A transmission cooler would probably be in order.<br><br>BC to AZ is a long trip and it's not all down hill.<br><br>I think people pull pods with things like this, but if you do and ever try pulling the pod with an 8 cylinder truck or SUV, you will never go back.&nbsp; If you have a choice, I'd really recommend something with at least a 5000 lb towing capacity out of the box.&nbsp; <br><br>If it's in the budget, in my opinion you'll enjoy the trip a lot more with a larger TV.<br><br>TT<br>]]>
   <pubDate>Tue, 07 Apr 2015 01:22:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58659#58659</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58658#58658</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3785" rel="nofollow">Robert Free</a><br /><strong>Subject:</strong> 6044<br /><strong>Posted:</strong> 07 Apr 2015 at 12:14am<br /><br /><div><div><br></div><div><br></div></div>]]>
   <pubDate>Tue, 07 Apr 2015 00:14:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6044&amp;PID=58658#58658</guid>
