  <title>R-pod Owners Forum : sway bar needed with F150 and the 178?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : sway bar needed with F150 and the 178?</description>
  <pubDate>Sun, 25 Oct 2026 02:34:56 +0000</pubDate>
  <lastBuildDate>Mon, 06 Apr 2015 10:42:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6032</WebWizForums:feedURL>
   <title>sway bar needed with F150 and the 178? : We use a WDH, and definitely don&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58614#58614</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6032<br /><strong>Posted:</strong> 06 Apr 2015 at 10:42am<br /><br />We use a WDH, and definitely don't "need" it, by spec. We don't run anti sway, but our new TV does have it built in. Our old TV was same make/model/specs minus the integrated brake controller and anti sway and we never had a sway issue. We towed two full seasons without using our WDH, and then I said, "you know, we own it, lets see if it makes a difference" and we felt the big eX rode better, so have used it ever since.&nbsp;]]>
   <pubDate>Mon, 06 Apr 2015 10:42:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58614#58614</guid>
   <title>sway bar needed with F150 and the 178? : Much appreciate all the information...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58611#58611</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3346" rel="nofollow">rpodbend</a><br /><strong>Subject:</strong> 6032<br /><strong>Posted:</strong> 06 Apr 2015 at 10:03am<br /><br />Much appreciate all the information from you guys! &nbsp;Ok I am headed down to get it set up.<div>thanks again</div><div>Loren&nbsp;</div>]]>
   <pubDate>Mon, 06 Apr 2015 10:03:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58611#58611</guid>
   <title>sway bar needed with F150 and the 178? :  First, see the link in my signature,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58584#58584</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6032<br /><strong>Posted:</strong> 05 Apr 2015 at 7:03pm<br /><br />First, see the link in my signature, the section on sway control. &nbsp;Below is a recent post I made about WDHs.<div><br></div><div><span style="line-height: 15.27272605896px; : rgb251, 251, 253;">There are&nbsp;4&nbsp;</span><span ="highlight"="" style="line-height: 15.27272605896px;">type</span><span style="line-height: 15.27272605896px; : rgb251, 251, 253;">s of sway and/or weight distribution, with the sway bar being the lowest level.&nbsp; It doesn't do any WD and only attempts to stop sway after it has started.&nbsp; However, I always recommend the next level for pods, a full&nbsp;</span><span ="highlight"="" style="line-height: 15.27272605896px;">WDH</span><span style="line-height: 15.27272605896px; : rgb251, 251, 253;">&nbsp;that includes sway control.&nbsp; The lowest level here is a combined WD with friction control, like the Equalizer or E2.&nbsp; Above that is the cam&nbsp;</span><span ="highlight"="" style="line-height: 15.27272605896px;">type</span><span style="line-height: 15.27272605896px; : rgb251, 251, 253;">&nbsp;like the Reese Dual Cam, which actively prevents sway before it starts.&nbsp; The highest level is the Hensley Arrow which actually guarantees no sway period.</span></div>]]>
   <pubDate>Sun, 05 Apr 2015 19:03:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58584#58584</guid>
   <title>sway bar needed with F150 and the 178? : We pull our 171 using a WDH (spring...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58582#58582</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2911" rel="nofollow">ChinookPod</a><br /><strong>Subject:</strong> 6032<br /><strong>Posted:</strong> 05 Apr 2015 at 6:44pm<br /><br />We pull our 171 using a WDH (spring bars). &nbsp;For short trips to and from the storage yard we leave the bars off but the bouncing/porpoising is noticeable on less-than-perfect streets. &nbsp;The WDH really dampens the bounce. &nbsp;Our hitch also has an equalizer bar but we were told it isn't necessary for such a short trailer. &nbsp;We have significant winds (up to 80 mph) not uncommon but the trailer stays put behind the truck.]]>
   <pubDate>Sun, 05 Apr 2015 18:44:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58582#58582</guid>
   <title>sway bar needed with F150 and the 178? : I towed my &amp;#039;14 178 with a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58566#58566</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2709" rel="nofollow">jan demarinis</a><br /><strong>Subject:</strong> 6032<br /><strong>Posted:</strong> 05 Apr 2015 at 10:05am<br /><br />I towed my '14 178 with a BMW X3 and found that the anti-sway really helped. Especially on the interstates. A WDH was mandatory also. Good luck and welcome to the Pod side.<div>Jan</div>]]>
   <pubDate>Sun, 05 Apr 2015 10:05:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58566#58566</guid>
   <title>sway bar needed with F150 and the 178? : Dear Friends,We are about to get...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58565#58565</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3346" rel="nofollow">rpodbend</a><br /><strong>Subject:</strong> 6032<br /><strong>Posted:</strong> 05 Apr 2015 at 9:51am<br /><br /><font size="3">Dear Friends,</font><div><font size="3">We are about to get started using our 2015 R Pod 178. &nbsp;We are pretty darned excited about it! &nbsp;Currently I will be pulling it with a Ford F150. &nbsp;When I brought it home from the dealer I noticed it bounced along a bit so I think I'll go ahead and put the stabilizing hitch on it. &nbsp;I am wondering if I need to do a sway bar as well? &nbsp;I would like your input and advice.</font></div><div><font size="3">Next year I will be changing vehicles and will be pulling it with a Ford Explorer AWD and I'll get one with the 5000 lb capacity so I guess the question will be the same?</font></div><div><font size="3">Thanks in advance for any info I can get! &nbsp;I think I'll go get it set up in a week or so.</font></div><div><font size="3">Much appreciated</font></div><div><font size="3">Loren and Sally in Bend</font></div>]]>
   <pubDate>Sun, 05 Apr 2015 09:51:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6032&amp;PID=58565#58565</guid>
