  <title>R-pod Owners Forum : Air conditioner and furnace</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Air conditioner and furnace</description>
  <pubDate>Thu, 24 Sep 2026 20:40:38 +0000</pubDate>
  <lastBuildDate>Thu, 27 Nov 2014 20:52:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=5591</WebWizForums:feedURL>
   <title>Air conditioner and furnace :   Originally posted by AKgo/...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54575#54575</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3180" rel="nofollow">Luv2Q</a><br /><strong>Subject:</strong> 5591<br /><strong>Posted:</strong> 27 Nov 2014 at 8:52pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by AKgo</strong></em><br /><br />/ .. snip .. /....when on air it must be set on AU...not LO or HI....Thanks again...</td></tr></table><div><br></div><div>Don't think it works quite as you described. &nbsp;Here's how mine works.</div><div><br></div><div>Cooling:</div><div>A. &nbsp;You want cooling and want fan working only when a/c <span style="line-height: 1.4;">compressor i</span><span style="line-height: 1.4;">s on.</span></div><blockquote style="margin: 0 0 0 40px; border: n&#111;ne; padding: 0px;"><div>Actions: Set fan to AU then select Cool.</div></blockquote>B. &nbsp;You want cooling and want fan always on constantly regardless of whether a/c compressor is on.<blockquote style="margin: 0 0 0 40px; border: n&#111;ne; padding: 0px;"><div>Actions: &nbsp;Set fan to Hi or Lo, wait for fan to come on, then select Cool.</div></blockquote><br><div><div>Furnace:</div><div>A. &nbsp;You want heat but use only the furnace fan.</div></div><blockquote style="margin: 0 0 0 40px; border: n&#111;ne; padding: 0px;"><div><div>Actions:&nbsp;<span style="line-height: 1.4;">Set fan to AU then select Heat.</span></div></div></blockquote>B. &nbsp;You want heat and want the a/c fan on&nbsp;constantly regardless of whether furnace is on.<blockquote style="margin: 0 0 0 40px; border: n&#111;ne; padding: 0px;"><div>Actions: Set fan to Hi or Lo, wait for fan to come on, then select Heat.</div></blockquote><div><div><div><div><br></div></div></div></div><div>A couple of additional notes:</div><div><ol><li>When on heat, there is no way to have the a/c fan cycle on only when the furnace comes on.</li><li>You'll notice I've suggested waiting for the fan to come on after selecting Hi or Lo. &nbsp;This is <u>not</u> absolutely necessary. &nbsp;If you immediately select Heat, likely not a problem. &nbsp;If you immediately select Cool, however, without waiting for the fan to spin up, you <u>could</u> have a problem especially if you're using a 20 amp input or a smallish generator.&nbsp;</li></ol><div>This may be TMI but hope it helps.</div></div>]]>
   <pubDate>Thu, 27 Nov 2014 20:52:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54575#54575</guid>
   <title>Air conditioner and furnace : FWUnder.....Thanks....there was...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54573#54573</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3378" rel="nofollow">AKgo</a><br /><strong>Subject:</strong> 5591<br /><strong>Posted:</strong> 27 Nov 2014 at 5:55pm<br /><br />FWUnder.....Thanks....there was a thread within the thread....when on air it must be set on AU...not LO or HI....Thanks again...]]>
   <pubDate>Thu, 27 Nov 2014 17:55:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54573#54573</guid>
   <title>Air conditioner and furnace : Hi AKgo,You may find a solution...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54570#54570</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 5591<br /><strong>Posted:</strong> 27 Nov 2014 at 1:28pm<br /><br />Hi AKgo,<div><br></div><div>You may find a solution in this thread:</div><div><br></div><div><a href="http://www.rpod-owners.com/forum_posts.asp?TID=5522&amp;KW=furnace&amp;PID=53708" target="_blank">http://www.rpod-owners.com/forum_posts.asp?TID=5522&amp;KW=furnace&amp;PID=53708</a></div><div><br></div><div>Happy Holidays,</div><div><br></div><div>fred</div>]]>
   <pubDate>Thu, 27 Nov 2014 13:28:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54570#54570</guid>
   <title>Air conditioner and furnace : Greetings again....My second post....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54568#54568</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3378" rel="nofollow">AKgo</a><br /><strong>Subject:</strong> 5591<br /><strong>Posted:</strong> 27 Nov 2014 at 12:35pm<br /><br />Greetings again....My second post. &nbsp; We are new owners of a brand new 179....we are on our first outing and are having a problem.&nbsp;&nbsp; First night out the temps dropped to about 28 degrees and we decided&nbsp; to test the furnace.&nbsp; The thermostat gives 3 selection...fan, cool, furnace.&nbsp;&nbsp; I selected furnace and set a temperature and all worked well.&nbsp; Night 2 was different.&nbsp; Selected furnace and both the air conditioner and furnace came on.&nbsp;&nbsp; Tried everything I could think of and finally killed the air by tripping the breaker, we were getting cold.&nbsp; We have a small space heater, but I want to test all ewquipment to make sure it works.&nbsp; This AM I turned the air breaker back on and same thing happened.&nbsp; What in the ^%#%*&amp; did I do wrong?????<br>]]>
   <pubDate>Thu, 27 Nov 2014 12:35:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5591&amp;PID=54568#54568</guid>
