  <title>R-pod Owners Forum : flag pole</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Miscellaneous / Off-topic : flag pole</description>
  <pubDate>Sun, 25 Oct 2026 20:07:31 +0000</pubDate>
  <lastBuildDate>Thu, 13 Nov 2014 14:47:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=5552</WebWizForums:feedURL>
   <title>flag pole :   I like your solution. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=54021#54021</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 5552<br /><strong>Posted:</strong> 13 Nov 2014 at 2:47pm<br /><br />I like your solution.]]>
   <pubDate>Thu, 13 Nov 2014 14:47:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=54021#54021</guid>
   <title>flag pole : I have a flagpole of sorts...I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=53985#53985</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=418" rel="nofollow">Outbound</a><br /><strong>Subject:</strong> 5552<br /><strong>Posted:</strong> 12 Nov 2014 at 5:19pm<br /><br />I have a flagpole of sorts...<div><br></div><div>I bought a set of replacement 7/16" fibreglass tent poles (about 8 1/2' assembled length), which were stiff enough to stand vertical holding the weight of a flag. &nbsp;To the backside of the trailer's tongue jack, I zip-tied a 18" length of 3/4" (inner) poly pipe.</div><div><br></div><div>When it comes time to setup, I slip together the fibreglass poles, attach a flag to the top with binder clips and slip the bottom into the pipe for support.</div><div><br></div><div>With the height of the tongue, the top of the flag is about 10' in the air. &nbsp;Its located at the front of the trailer, which is generally the most visible spot from the road. &nbsp;And, given the curve of the roof, my flag stands proud and doesn't slap against the trailer. &nbsp; For me, its just about the right solution.</div><div><br></div><div>But, if you're looking for something a little bigger, Camping World carries a <a href="http://www.campingworld.com/shopping/item/16-telescoping-fiberglass-flagpole-kit/60338" target="_blank">telescoping pole with a base plate</a> that you slip under a tire for stability.</div>]]>
   <pubDate>Wed, 12 Nov 2014 17:19:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=53985#53985</guid>
   <title>flag pole :   If you have a tall flagpole,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=53977#53977</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 5552<br /><strong>Posted:</strong> 12 Nov 2014 at 11:13am<br /><br />If you have a tall flagpole, maybe you could use a ratcheting tie-down to attach it to the propane tank.&nbsp; ]]>
   <pubDate>Wed, 12 Nov 2014 11:13:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=53977#53977</guid>
   <title>flag pole : 	Since my new rpod doesn&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=53975#53975</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3363" rel="nofollow">john in idaho</a><br /><strong>Subject:</strong> 5552<br /><strong>Posted:</strong> 12 Nov 2014 at 10:52am<br /><br /><span ="Apple-tab-span" style="white-space:pre">	</span>Since my new rpod doesn't have a ladder, does anyone have a good way to attach a flagpole when parked?]]>
   <pubDate>Wed, 12 Nov 2014 10:52:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5552&amp;PID=53975#53975</guid>
