  <title>R-pod Owners Forum : Fresh water tank debris</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : Fresh water tank debris</description>
  <pubDate>Wed, 23 Sep 2026 07:16:20 +0000</pubDate>
  <lastBuildDate>Fri, 24 Oct 2014 09:22:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=5459</WebWizForums:feedURL>
   <title>Fresh water tank debris : Thanks for all the tips. These...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53175#53175</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3170" rel="nofollow">Unclewillis</a><br /><strong>Subject:</strong> 5459<br /><strong>Posted:</strong> 24 Oct 2014 at 9:22am<br /><br />Thanks for all the tips. These are great.]]>
   <pubDate>Fri, 24 Oct 2014 09:22:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53175#53175</guid>
   <title>Fresh water tank debris : Goose is right as usual. I check...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53097#53097</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1034" rel="nofollow">dsmiths</a><br /><strong>Subject:</strong> 5459<br /><strong>Posted:</strong> 22 Oct 2014 at 9:54pm<br /><br />Goose is right as usual. I check ours when winterizing and found plastic debris on the first check but not since. Its easy to do.]]>
   <pubDate>Wed, 22 Oct 2014 21:54:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53097#53097</guid>
   <title>Fresh water tank debris :   Originally posted by UnclewillisI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53082#53082</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 5459<br /><strong>Posted:</strong> 22 Oct 2014 at 1:30pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Unclewillis</strong></em><br /><br />I keep meaning to post this and keep forgetting. <br>I recently drained the fresh water tank for the 1st time since new. Alot of plastic shavings came out of the drain, which leads me to assume there might be more that did not fit through the drain. <br><br>You may want to do this on a new model. having that debris in the pump would not be good</td></tr></table><div><br></div><div>There is a strainer/filter device before the pump, little round thing with a twist off cap that you can clean out.</div><div><br></div><div>These manufacturing shavings will end up at the end of your lines at the faucets sometimes preventing waterflow, you can pop off the little screens then and flush them out all the way.</div>]]>
   <pubDate>Wed, 22 Oct 2014 13:30:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53082#53082</guid>
   <title>Fresh water tank debris : Unclewillis you will want to clean...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53081#53081</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=648" rel="nofollow">Goose</a><br /><strong>Subject:</strong> 5459<br /><strong>Posted:</strong> 22 Oct 2014 at 1:29pm<br /><br />Unclewillis you will want to clean the filter that is located at the pump, it is at the inlet side of the pump. Just unscrew the clear plastic cup and you will more than likely find plastic shavings in there from the tank setup. Goose]]>
   <pubDate>Wed, 22 Oct 2014 13:29:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53081#53081</guid>
   <title>Fresh water tank debris : I keep meaning to post this and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53071#53071</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3170" rel="nofollow">Unclewillis</a><br /><strong>Subject:</strong> 5459<br /><strong>Posted:</strong> 22 Oct 2014 at 9:55am<br /><br />I keep meaning to post this and keep forgetting. <br />I recently drained the fresh water tank for the 1st time since new. Alot of plastic shavings came out of the drain, which leads me to assume there might be more that did not fit through the drain. <br /><br />You may want to do this on a new model. having that debris in the pump would not be good]]>
   <pubDate>Wed, 22 Oct 2014 09:55:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5459&amp;PID=53071#53071</guid>
