  <title>R-pod Owners Forum : Beware the Exploding Faucet!</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : Beware the Exploding Faucet!</description>
  <pubDate>Wed, 23 Sep 2026 09:22:03 +0000</pubDate>
  <lastBuildDate>Sun, 28 Sep 2014 10:29:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=5349</WebWizForums:feedURL>
   <title>Beware the Exploding Faucet! : Also turning down the valve on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52142#52142</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3020" rel="nofollow">wildfire305</a><br /><strong>Subject:</strong> 5349<br /><strong>Posted:</strong> 28 Sep 2014 at 10:29am<br /><br />Also turning down the valve on any plumbing system will not reduce the pressure, only the volume. ]]>
   <pubDate>Sun, 28 Sep 2014 10:29:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52142#52142</guid>
   <title>Beware the Exploding Faucet! : Speaking from the viewpoint of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52141#52141</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3020" rel="nofollow">wildfire305</a><br /><strong>Subject:</strong> 5349<br /><strong>Posted:</strong> 28 Sep 2014 at 10:28am<br /><br />Speaking from the viewpoint of a plumber, slowly opening is better for the plastic piping system. Also when the water was turned on, the air in the water heater compressed, causing a large volume of air under pressure to rush the faucet. The reason it blew the aerator off was the air hit a slug of water laying in the pipe and hammered it to the faucet. Also a regulator should be standard equipment in everyones hook up kit. The plastic system can't handle more than 75 psi static for prolonged periods without wearing faster. My regulator is set to 50.]]>
   <pubDate>Sun, 28 Sep 2014 10:28:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52141#52141</guid>
   <title>Beware the Exploding Faucet! : i would turn the water supply...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52092#52092</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3252" rel="nofollow">rcamper</a><br /><strong>Subject:</strong> 5349<br /><strong>Posted:</strong> 26 Sep 2014 at 7:33pm<br /><br />i would turn the water supply on half way at the camp ground then open faucets to clear when done open campground valve all the way. sometimes the pressure at the caMPGROUND MAY BE HIGH BUT, IF THAT'S THE CASE THEN TURN IT DOWN AT THERE SPIGOT&nbsp;&nbsp;&nbsp;]]>
   <pubDate>Fri, 26 Sep 2014 19:33:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52092#52092</guid>
   <title>Beware the Exploding Faucet! : The water heater had not yet been...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52062#52062</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1464" rel="nofollow">coopercdrkey</a><br /><strong>Subject:</strong> 5349<br /><strong>Posted:</strong> 26 Sep 2014 at 6:51am<br /><br />The water heater had not yet been turned on. &nbsp;We were running water through the system to make sure it was full prior to turning on the electric element.<div><br></div><div>My best guess is that there was so little water in the lines that the first onrush at city water pressure hit the aerator with enough force to blow it off. (And shred the pot metal threads, BTW.)</div><div><br></div><div>We had never had a problem opening the faucet fully at this point, and in fact considered it a benefit to purging the air from the system, but from now on we will both take the additional time to just crack the faucet and the water bib until the air is purged.</div><div><br></div><div>I know there are devices designed to regulate the pressure from the city water bib- &nbsp;in fact I have one, but it leaks too badly to use. &nbsp;I don't think the water pressure was excessive.</div>]]>
   <pubDate>Fri, 26 Sep 2014 06:51:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52062#52062</guid>
   <title>Beware the Exploding Faucet! : In the short no, outside air temps...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52055#52055</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1034" rel="nofollow">dsmiths</a><br /><strong>Subject:</strong> 5349<br /><strong>Posted:</strong> 25 Sep 2014 at 10:39pm<br /><br />In the short no, outside air temps 70, 80 or 90 is not going to cause a increase in pressure in the closed system. My best guess is that there may have been an air pocket in the hot water heater and it boiled and created a high pressure pocket. but I am not sure. any one else got an idea ?]]>
   <pubDate>Thu, 25 Sep 2014 22:39:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52055#52055</guid>
   <title>Beware the Exploding Faucet! : Hoping this isn&amp;#039;t too dumb...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52050#52050</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3180" rel="nofollow">Luv2Q</a><br /><strong>Subject:</strong> 5349<br /><strong>Posted:</strong> 25 Sep 2014 at 9:11pm<br /><br />Hoping this isn't too dumb a question, but here goes: &nbsp;If the trailer sat for a long time - in a hot summer - and if all taps/valves were closed, could the heat have built up the kind of pressure you're talking about?<div><br></div><div>John</div>]]>
   <pubDate>Thu, 25 Sep 2014 21:11:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52050#52050</guid>
   <title>Beware the Exploding Faucet! : We have a pretty well orchestrated...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52042#52042</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1464" rel="nofollow">coopercdrkey</a><br /><strong>Subject:</strong> 5349<br /><strong>Posted:</strong> 25 Sep 2014 at 1:45pm<br /><br /><img src="https://www.rpod-owners.com/smileys/smiley11.gif" border="0" alt="Dead" title="Dead" />&nbsp; We have a pretty well orchestrated set up routine which puts me in charge of the outside activities, and Joyce handles the interior stuff. &nbsp;At the appropriate point I ask her to purge the hot water lines before I turn on the water heater. &nbsp;Until this trip there was never more than a little sputtering and thumping as the city water worked out the air pockets.<div><br></div><div>This time, probably because the 'Pod sat for so long between trips, the water surged through the kitchen faucet with enough force to blow the aeriator off the end of the faucet. &nbsp;More scary than anything else and a little splashed water to clean up. &nbsp;(Plus a trip to a (fortunately) nearby WM for a replacement aerator...)</div><div><br></div><div>From now on I will ask Joyce to "bleed" the hot water line. &nbsp;You may want to do the same.&nbsp;</div>]]>
   <pubDate>Thu, 25 Sep 2014 13:45:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5349&amp;PID=52042#52042</guid>
