  <title>R-pod Owners Forum : Plywood Bed and Bed Frame</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Plywood Bed and Bed Frame</description>
  <pubDate>Thu, 29 Oct 2026 08:51:38 +0000</pubDate>
  <lastBuildDate>Mon, 25 Aug 2014 14:28:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=5203</WebWizForums:feedURL>
   <title>Plywood Bed and Bed Frame : Awesome idea! Thanks David and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5203&amp;PID=50547#50547</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3099" rel="nofollow">rpodnewbie</a><br /><strong>Subject:</strong> 5203<br /><strong>Posted:</strong> 25 Aug 2014 at 2:28pm<br /><br />Awesome idea! Thanks David and Danette!]]>
   <pubDate>Mon, 25 Aug 2014 14:28:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5203&amp;PID=50547#50547</guid>
   <title>Plywood Bed and Bed Frame :    You could glue some 1&amp;#034;x...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5203&amp;PID=50546#50546</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 5203<br /><strong>Posted:</strong> 25 Aug 2014 at 2:27pm<br /><br />&nbsp; &nbsp; You could glue some 1"x 3" oak across the bottom with some 3/4" flat head wood screws going through the top of the plywood into the oak. That is what we did with our 171. Didn't need to replace the plywood but I think I may have trimmed the edges from hitting the side walls.]]>
   <pubDate>Mon, 25 Aug 2014 14:27:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5203&amp;PID=50546#50546</guid>
   <title>Plywood Bed and Bed Frame : Howdy everyone,My 177 plywood...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5203&amp;PID=50545#50545</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3099" rel="nofollow">rpodnewbie</a><br /><strong>Subject:</strong> 5203<br /><strong>Posted:</strong> 25 Aug 2014 at 1:10pm<br /><br />Howdy everyone,<div><br></div><div>My 177 plywood under the bed is beginning to bow. Also, it squeaks like crazy when you move around on it. I'm thinking about replacing the plywood with something stronger (hopefully about the same weight) and adding something to stop the squeak.&nbsp;</div><div><br></div><div>Any ideas?</div><div><br></div><div>Thanks!</div><div><br></div>]]>
   <pubDate>Mon, 25 Aug 2014 13:10:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5203&amp;PID=50545#50545</guid>
