  <title>R-pod Owners Forum : Black Water Tank</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : Black Water Tank</description>
  <pubDate>Wed, 23 Sep 2026 08:01:06 +0000</pubDate>
  <lastBuildDate>Fri, 25 Jul 2014 11:51:59 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=5031</WebWizForums:feedURL>
   <title>Black Water Tank : Since you have already gotten...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5031&amp;PID=48829#48829</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 5031<br /><strong>Posted:</strong> 25 Jul 2014 at 11:51am<br /><br />Since you have already gotten to it, It has a "flow direction arrow", make sure it's pointed the right direction. Quite a few have been found to be backwards..]]>
   <pubDate>Fri, 25 Jul 2014 11:51:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5031&amp;PID=48829#48829</guid>
   <title>Black Water Tank : Hi,  We are new Rpod owners...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5031&amp;PID=48823#48823</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3017" rel="nofollow">rmooreh</a><br /><strong>Subject:</strong> 5031<br /><strong>Posted:</strong> 25 Jul 2014 at 10:39am<br /><br /><p ="Ms&#111;normal">Hi,</p><p ="Ms&#111;normal">We are new Rpod owners and new to RVing, we just picked upthe Rpod 178 about three months ago and did a short two day stay at a localKOA. We both loved the Rpod. Last week we took her out for a two day stay atthe ocean and had a great time. On the way home I thought I would empty theblack and gray tanks as they were showing 2/3 full. The black water tank dumpfine but I hooked up the black water tank and could not see any clear water oranything more coming out of the tank, yes the water was turned on. All of asudden water started to flow out of the bottom of the Rpod. I tuned the wateroff and went inside and had water on the floor and in the bath room, I was notsure what was going on. I went back and empty out the gray water tank. Weheaded home; once I got home I called the dealer and got an appointment in twoweeks to drop it off so they could look at it. I have spent 30 years working infacilities maintenance and hate it when things don’t work right and I don’tknow why. I searched the forum for black water tank flush, and found areference to a check valve under the sink in the bathroom for the black watertank. I hooked up a hose to the tank flush and had my wife watch the checkvalve while I turned the water on and guess what we had water coming out of thecheck valve. Not sure if it is installed wrong or broken but I will let thedealer fix it under warranty, at least I can tell them what is wrong with myRpod. Good to know I was not doing some thing wrong.</p><p ="Ms&#111;normal">I love the forums people helping other people out.<span style="mso-spacerun:yes">&nbsp;&nbsp; </span>Thanks all.&nbsp;</p>]]>
   <pubDate>Fri, 25 Jul 2014 10:39:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5031&amp;PID=48823#48823</guid>
