  <title>R-pod Owners Forum : Power cord adapter</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : Power cord adapter</description>
  <pubDate>Sat, 24 Oct 2026 19:22:12 +0000</pubDate>
  <lastBuildDate>Tue, 01 Jul 2014 09:29:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=4910</WebWizForums:feedURL>
   <title>Power cord adapter : I agree that a &amp;#034;hockey puck&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47740#47740</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4910<br /><strong>Posted:</strong> 01 Jul 2014 at 9:29am<br /><br /><P>I agree that a "hockey puck" or "dog bone" adapter, used with the existing 10 gauge (30 amp)&nbsp;cord, is easiest.&nbsp; If you really want to use a 12 or 14 gauge extension cord coming from the camper&nbsp;you can find a short adapter for about $15-20 online.&nbsp; Google "L5-30R to 5-20P".</P><DIV></DIV><DIV>This is one example, but it is way too expensive.&nbsp; <a href="http://www.lockingpowercords.com/products/86-5-15p-to-l5-30r-plug-adapter.aspx" target="_blank">http://www.lockingpowercords.com/products/86-5-15p-to-l5-30r-plug-adapter.aspx</A></DIV><DIV>&nbsp;</DIV><DIV>I also recommend you get about a half-dozen of these, for the pod and around the house.&nbsp; In the pod I use one on my water hose, power cord, power cord extension, and the 15 amp extension cord.&nbsp; <a href="http://www.lowes.com/pd_316747-1781-CW-T3RR25_4294722508__?productId=3439228&amp;Ns=p_product_qty_sales_dollar|1&amp;pl=1&amp;currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&amp;facetInfo" target="_blank">http://www.lowes.com/pd_316747-1781-CW-T3RR25_4294722508__?productId=3439228&amp;Ns=p_product_qty_sales_dollar|1&amp;pl=1&amp;currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&amp;facetInfo</A>=</DIV>]]>
   <pubDate>Tue, 01 Jul 2014 09:29:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47740#47740</guid>
   <title>Power cord adapter : Adapters are available at Walmart...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47739#47739</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 4910<br /><strong>Posted:</strong> 01 Jul 2014 at 8:30am<br /><br />Adapters are available at Walmart or any place that caters to campers/RV owners.&nbsp; Or you can make one with parts from Home Depot or Lowes, but that will probably cost more than one from Walmart.&nbsp; Walmarts usually have a little section for RV goodies between camping and automotive.&nbsp; You want 30 to 15 or 20 amp.&nbsp; As someone else said, you do not want 50 amp plug.<br><br>TT<br>]]>
   <pubDate>Tue, 01 Jul 2014 08:30:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47739#47739</guid>
   <title>Power cord adapter :  I made the same thing as above-...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47735#47735</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2707" rel="nofollow">Budward</a><br /><strong>Subject:</strong> 4910<br /><strong>Posted:</strong> 01 Jul 2014 at 5:15am<br /><br />I made the same thing as above- only I made mine about 8 ft.&nbsp; I use it connect to a generator without dragging out the big bulky cord.&nbsp; I also use it at home to connect to an extension cord to run the power convertor.<br>If you just want to run the camper without the air conditioner you only need a 14 gauge cable between the adapters, since most extension cords are that size.&nbsp; You could even cut off the female end of your extension cord and put the L5-30R directly on it.<br><br>Beware-&nbsp;&nbsp; I bought a L5-30R connector sold by Amazon, made by Well Shin,&nbsp; that was a shock hazard that could have been deadly.&nbsp;&nbsp; The hot and neutral screw colors were reversed so be SURE to check what you buy if you make one.<br>]]>
   <pubDate>Tue, 01 Jul 2014 05:15:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47735#47735</guid>
   <title>Power cord adapter :  A regular 120V plug and a L530C...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47734#47734</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2551" rel="nofollow">Cap-n-Cray</a><br /><strong>Subject:</strong> 4910<br /><strong>Posted:</strong> 01 Jul 2014 at 1:02am<br /><br />A regular 120V plug and a L530C twist lock plug with 10 gauge SO cable.<br><br><img src="http://i582.photobucket.com/albums/ss269/Cap-n-Cray/CIMG3537_zpsa84ae10d.jpg" height="768" width="1024" border="0" /><br>]]>
   <pubDate>Tue, 01 Jul 2014 01:02:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47734#47734</guid>
   <title>Power cord adapter : I made a short adapter. I use...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47733#47733</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2551" rel="nofollow">Cap-n-Cray</a><br /><strong>Subject:</strong> 4910<br /><strong>Posted:</strong> 01 Jul 2014 at 12:42am<br /><br />I made a short adapter. I use it when I just need to run a hair dyer off the generator, who'd of thought it would be important. Cost maybe $20 in parts. I'll post a photo.<br>]]>
   <pubDate>Tue, 01 Jul 2014 00:42:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47733#47733</guid>
   <title>Power cord adapter : Here&amp;#039;s my two cents: The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47731#47731</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2709" rel="nofollow">jan demarinis</a><br /><strong>Subject:</strong> 4910<br /><strong>Posted:</strong> 01 Jul 2014 at 12:00am<br /><br />Here's my two cents: The power cord that came with the Pod is 30 amp not 50. Any hardware store has adapters for a 30 amp to 15/20 amp regular house/extension cord plug. This is what I did and it works great. There are a lot of electric genius' on this forum, I am sure they will chime in. You can read the previous threads about this. Good luck.<div><br></div>]]>
   <pubDate>Tue, 01 Jul 2014 00:00:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47731#47731</guid>
   <title>Power cord adapter : I&amp;#039;m looking for an adapter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47730#47730</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2772" rel="nofollow">Cookpod</a><br /><strong>Subject:</strong> 4910<br /><strong>Posted:</strong> 30 Jun 2014 at 11:45pm<br /><br />I'm looking for an adapter that will allow me to use a standard extension cord instead of the bulky 50 amp cord that came with the trailer. Would like to be able to use standard extension cord for basic battery charging, fridge pre-cooling, etc.&nbsp;<div><br></div><div>So far I am only finding them in the $80 range but i don't think I need anything that stout. If anyone has found something similar for a reasonable price any info or links would be appreciated.&nbsp;</div>]]>
   <pubDate>Mon, 30 Jun 2014 23:45:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4910&amp;PID=47730#47730</guid>
