  <title>R-pod Owners Forum : New 179 in SC!</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : New 179 in SC!</description>
  <pubDate>Thu, 24 Sep 2026 09:09:34 +0000</pubDate>
  <lastBuildDate>Fri, 25 Apr 2014 05:45:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=4627</WebWizForums:feedURL>
   <title>New 179 in SC! : I probably will install a cut...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45121#45121</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2707" rel="nofollow">Budward</a><br /><strong>Subject:</strong> 4627<br /><strong>Posted:</strong> 25 Apr 2014 at 5:45am<br /><br />I probably will install a cut off switch*, no dealer needed though as I have always done higher quality work on my RVs than any dealer and cheaper as my labor is free<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><br><br>I typically run Battery Tender brand maintainers when stored instead of depending on the WFCO convertor/chargers installed in the pod.<br>A couple of reasons for this- <br>&nbsp;1st&gt; the Battery Tender uses far less electricity running 24 hours a day than the WFCO.<br>2nd&gt; the WFCO convertors have a very bad reputation for failing, already had that experience in another RV.&nbsp; A failed WFCO can leave your expensive batteries in either a state of undercharge or worse, cook them from an overcharge when left long term.&nbsp; <br>3rd&gt; IF the Battery Tender was to fail it is small enough to not overcharge most batteries.&nbsp;&nbsp; I run two Group 31 AGM batteries, so long life is important as that is almost $400 worth of batteries!<br><br><br>* I usually use a 50 amp commercial rated DC circuit breaker which is also used as the cutoff switch, rather than just a switch.<br>]]>
   <pubDate>Fri, 25 Apr 2014 05:45:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45121#45121</guid>
   <title>New 179 in SC! : Welcome Budward and happy R-pod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45054#45054</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2546" rel="nofollow">CasaJack</a><br /><strong>Subject:</strong> 4627<br /><strong>Posted:</strong> 23 Apr 2014 at 9:43am<br /><br />Welcome Budward and happy R-pod traveling.&nbsp; I recommend you have the dealer install an on off battery switch next to the batteries so you don't have to disconnect the cables when you are not using the trailer.]]>
   <pubDate>Wed, 23 Apr 2014 09:43:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45054#45054</guid>
   <title>New 179 in SC! :   Welcome to the group!!! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45019#45019</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 4627<br /><strong>Posted:</strong> 22 Apr 2014 at 9:19pm<br /><br />Welcome to the group!!!]]>
   <pubDate>Tue, 22 Apr 2014 21:19:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45019#45019</guid>
   <title>New 179 in SC! : Another sc&amp;#039;er! We pick up...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45013#45013</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2606" rel="nofollow">Kermit</a><br /><strong>Subject:</strong> 4627<br /><strong>Posted:</strong> 22 Apr 2014 at 8:01pm<br /><br />Another sc'er! We pick up our 182g about a two months ago.]]>
   <pubDate>Tue, 22 Apr 2014 20:01:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45013#45013</guid>
   <title>New 179 in SC! : Wonderful to hear about your pickup....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45011#45011</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 4627<br /><strong>Posted:</strong> 22 Apr 2014 at 7:16pm<br /><br />Wonderful to hear about your pickup. &nbsp;Congratulations on the 179.<div><br></div><div>Will be excited to see how you like it once you've had some time to get to know it, but welcome to the group and the community. &nbsp;A lot of great fun to be had here amongst Podders!</div>]]>
   <pubDate>Tue, 22 Apr 2014 19:16:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45011#45011</guid>
   <title>New 179 in SC! : Picking up our new 179 tomorrow...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45006#45006</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2707" rel="nofollow">Budward</a><br /><strong>Subject:</strong> 4627<br /><strong>Posted:</strong> 22 Apr 2014 at 6:25pm<br /><br />Picking up our new 179 tomorrow in SC!&nbsp; <br>Will be towing with a 2011 Toyota FJ Cruiser.&nbsp; Currently tow an Aliner Ranger with it.<br><br>I'm getting very close to retirement and we plan to hit the road with the r-pod/FJ combo when I do finally pull the work plug.<br><br>Have used the 2012 Aliner only a few times although one of those times was a 19 day 6000 mile round trip from SC to the Rockies where we explored off road with the FJ.&nbsp; Had a great time, it was my 4th or 5th trip out there.<br><br>Decided to upfit a little but still keep it light so as not to run the fuel bill too high, averaged about 15mpg on the road with the FJ towing the ALiner, figured it might do 12 with the r-pod.<br>We'll see.<br><br>Just the wife and I and two dogs 99%of the time, so we don't need or want a huge RV.&nbsp; Many of the places I like to camp are more rustic and a larger unit just can't get in there.&nbsp;&nbsp; <br><br><br><br><br>]]>
   <pubDate>Tue, 22 Apr 2014 18:25:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4627&amp;PID=45006#45006</guid>
