  <title>R-pod Owners Forum : Generator for Pod 177</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Miscellaneous / Off-topic : Generator for Pod 177</description>
  <pubDate>Sun, 25 Oct 2026 12:46:34 +0000</pubDate>
  <lastBuildDate>Sun, 27 Oct 2013 21:26:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=4137</WebWizForums:feedURL>
   <title>Generator for Pod 177 :  I do the same, using a large...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40181#40181</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 27 Oct 2013 at 9:26pm<br /><br /><p>I do the same, using a large 4 kw UPS to power most of the house for up to an hour, and then I power the UPS from my Prius&nbsp;once the batteries are drained: &nbsp;</p><p><a href="http://www.wind-sun.com/ForumVB/showthread.php?12962-Using-a-Prius-as-a-generator" target="_blank">http://www.wind-sun.com/ForumVB/showthread.php?12962-Using-a-Prius-as-a-generator</a></p><p><br></p>]]>
   <pubDate>Sun, 27 Oct 2013 21:26:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40181#40181</guid>
   <title>Generator for Pod 177 : There are lots of opinions on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40098#40098</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1956" rel="nofollow">GA_RPOD_178</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 25 Oct 2013 at 3:02pm<br /><br />There are lots of opinions on this issue. &nbsp;I use a UPS with my system connected to a generator since my UPS will not keep my system "up" for an extended period. &nbsp;In some cases the UPS will not "accept" the power from some generators.]]>
   <pubDate>Fri, 25 Oct 2013 15:02:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40098#40098</guid>
   <title>Generator for Pod 177 : I&amp;#039;m in the same boat, way...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40077#40077</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 25 Oct 2013 at 9:29am<br /><br />I'm in the same boat, way out at the edge of the service territory with frequent issues.&nbsp; We were out for 55 hours after Sandy (minor compared to some, I know).&nbsp; Neighbors have stories of being out for weeks after ice storms in the 90's.<DIV>&nbsp;</DIV><DIV>"Computers need clean electricity" is happily a myth.&nbsp; They are much more tolerant of voltage and frequency fluctuations than some appliances, like tube-based&nbsp;televisions.&nbsp;&nbsp;&nbsp;A popular computer magazine did a test of computer power supplies in the early 90's, taking them to low voltage, high voltage, wild frequencies, voltage surges/sags, and most of them still supplied steady outputs.&nbsp; Modern computer power supplies are even more tolerant due to European regulations and since they can auto-accept 50 or 60 Hz, 120 or 220 volt inputs (with actual minimum and maximums much lower and higher than their name plate ratings).&nbsp; In fact many of them will also accept DC inputs at similar voltages.&nbsp; Lots of other consumer electronics have the same power supplies in them like flat screen televisions, cable boxes, etc.</DIV>]]>
   <pubDate>Fri, 25 Oct 2013 09:29:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40077#40077</guid>
   <title>Generator for Pod 177 : Doug (Techntrek) makes a lot of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40066#40066</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1956" rel="nofollow">GA_RPOD_178</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 25 Oct 2013 at 5:41am<br /><br />Doug (Techntrek) makes a lot of good points. &nbsp;We have always used Hondas. &nbsp;They are, as he said, more expensive, but since we also use them as backups for our home outages, I like that inverters are safer for my computer than a traditional generator. &nbsp;We have the Ei2000 and its companion unit. &nbsp;This time of year we can carry only one, since we don't use the A/C. &nbsp;For hotter months, we load both of them and rig them in sequence. &nbsp;Again, its an investment because of the need to be able to work (computers) safely at home during outages. &nbsp;Because we are in "the boonies" we are on the "first out, last on" power grid.]]>
   <pubDate>Fri, 25 Oct 2013 05:41:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40066#40066</guid>
   <title>Generator for Pod 177 :   Originally posted by techntrekNote...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40062#40062</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 10:03pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by techntrek</strong></em><br /><br /><p>Note the cap for the 2000 will NOT work with the 2400.</td></tr></table></p><p>&nbsp; Glad I didn't bet too much.</p><p>&nbsp; TT<br></p>]]>
   <pubDate>Thu, 24 Oct 2013 22:03:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40062#40062</guid>
   <title>Generator for Pod 177 : This past summer ours always cut...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40060#40060</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 9:13pm<br /><br /><p>This past summer ours always cut out at the 8 hour mark, I wish it did last 11 hours. &nbsp;It was typically in the 80's most of each night. &nbsp;I have been looking at&nbsp;ways to extend the Yamaha run time - shouldn't be a problem as long as the external tank is elevated.</p><p>Note the cap for the 2000 will NOT work with the 2400.</p><p>&nbsp;</p>]]>
   <pubDate>Thu, 24 Oct 2013 21:13:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40060#40060</guid>
   <title>Generator for Pod 177 :   Originally posted by ThinkerAll...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40058#40058</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 8:56pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Thinker</strong></em><br /><br />All things being equal, I would go with the EU2000i. You can put a cap on it that allows it to draw fuel from an outboard motor tank. The Honda has a fuel pump, the Yamaha does not. This means a longer run without getting out of the sack to refuel. I carry a little 3 gallon outboard tank.  My Honda runs my A/C or as Tech said will run the Micro, but not both at the same time. I seldom need the microwave while sleeping..</td></tr></table><br><br>A couple of things: my Yamaha 2400 has run for 11 hour on a tank.&nbsp; If you're camping somewhere you can run a generator at night you just fill it up before bed and you're good until morning.<br><br>I don't know if it's made by Yamaha and I don't have one, but there is an aftermarket cap for the Yamaha 2000 (I bet it works on the 2400 too) that let's you draw from an external tank.&nbsp; http://www.amazon.com/YAMAHA-EF2000iS-GENERATOR-EXTENDED-FUEL/dp/B004FPDLFM<br><br>TT<br>]]>
   <pubDate>Thu, 24 Oct 2013 20:56:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40058#40058</guid>
   <title>Generator for Pod 177 :  Originally posted by w4bgbobThanks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40037#40037</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1736" rel="nofollow">Thinker</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 2:33pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by w4bgbob</strong></em><br /><br />Thanks techntrek I understand what your saying and agree with the logic, I have been researching the yamaha model you mentioned and also a honda model eu2000i. For now either will have to wait, too many iorns in the fire and other things taking precedence over my toys, but I certainly appreciate all your input and information.<br /><br /></td></tr></table> <br /><br />All things being equal, I would go with the EU2000i. You can put a cap on it that allows it to draw fuel from an outboard motor tank. The Honda has a fuel pump, the Yamaha does not. This means a longer run without getting out of the sack to refuel. I carry a little 3 gallon outboard tank.  My Honda runs my A/C or as Tech said will run the Micro, but not both at the same time. I seldom need the microwave while sleeping.. ]]>
   <pubDate>Thu, 24 Oct 2013 14:33:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40037#40037</guid>
   <title>Generator for Pod 177 : Thanks techntrek I understand...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40034#40034</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2334" rel="nofollow">w4bgbob</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 2:16pm<br /><br />Thanks techntrek I understand what your saying and agree with the logic, I have been researching the yamaha model you mentioned and also a honda model eu2000i. For now either will have to wait, too many iorns in the fire and other things taking precedence over my toys, but I certainly appreciate all your input and information.<br /><br />]]>
   <pubDate>Thu, 24 Oct 2013 14:16:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40034#40034</guid>
   <title>Generator for Pod 177 : Something I didn&amp;#039;t mention...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40030#40030</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 1:44pm<br /><br />Something I didn't mention is you have two basic options - old style generator which always runs at 3600 rpms, or newer inverter-generator which can idle down under no/low load.&nbsp; The old style is always loud and uses a lot of gas.&nbsp; The new style are quieter even under full load, and almost always use less gas since generators are rarely run at full throttle all the time.<DIV>&nbsp;</DIV><DIV>Neither can be used in any campground overnight, and even if you are camped where you can use one, if you are near others in a campground or someplace like a Wal-Mart parking lot, you will make enemies running the old style for more than a few minutes.&nbsp; For something like running A/C overnight at Wal-Mart (we prefer truck stops) or for charging batteries in the middle of the day for a few hours, you'll want the new style.&nbsp; It is of course much more expensive, but over time the lower fuel consumption can make it pay for itself.</DIV>]]>
   <pubDate>Thu, 24 Oct 2013 13:44:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40030#40030</guid>
   <title>Generator for Pod 177 : Thank you gentleman for your responses,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40029#40029</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2334" rel="nofollow">w4bgbob</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 12:35pm<br /><br />Thank you gentleman for your responses, I agree smaller would be better and doing without a/c while the oven is on for a few mins sounds very feasable too. I will most definetly check into the yamaha generator and again thanks for the info.]]>
   <pubDate>Thu, 24 Oct 2013 12:35:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40029#40029</guid>
   <title>Generator for Pod 177 : My experience with a 2400w Yamaha...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40021#40021</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 24 Oct 2013 at 8:28am<br /><br />My experience with a 2400w Yamaha generator is that you can run the AC or the microwave/convection oven but not both at the same time.&nbsp; The generator shuts off when it gets overloaded, which is a bit of a pain until you learn to use one or the other of the big draws.&nbsp; Once you get that mindset taken care of, for me at least, it's absolutely no bother.&nbsp; I haven't tried cooking a turkey in the middle of the Chihuahuan desert in August, but otherwise I have no problem doing without air con for a few minutes while the oven is on.&nbsp; The noise, bulk, weight, etc, of a larger generator just isn't worth it to me.<br><br>TT<br>]]>
   <pubDate>Thu, 24 Oct 2013 08:28:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=40021#40021</guid>
   <title>Generator for Pod 177 : Welcome. I&amp;#039;ve moved this...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39962#39962</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 23 Oct 2013 at 8:56am<br /><br />Welcome.&nbsp; I've moved this post out of the Flea Market section, since that area is for wanted/for sale ads.<DIV>&nbsp;</DIV><DIV>The smaller you go with generators, the less fuel they'll burn, especially if you get an inverter-generator.&nbsp; My Yamaha EF2400is burns 1.6 gallons in 8 hours while running the A/C.&nbsp; It will run either my A/C or my microwave - in my opinion there's no reason to haul around a much heavier 3000 watt generator that can run both at the same time, plus carry and&nbsp;burn the extra fuel, when the microwave is only used a small percentage of the day.</DIV>]]>
   <pubDate>Wed, 23 Oct 2013 08:56:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39962#39962</guid>
   <title>Generator for Pod 177 : just trying to be on the safe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39958#39958</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2334" rel="nofollow">w4bgbob</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 23 Oct 2013 at 1:26am<br /><br />just trying to be on the safe side, might be over kill but i already had the 40# tank just had to add a longer length of hose and figured why not....]]>
   <pubDate>Wed, 23 Oct 2013 01:26:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39958#39958</guid>
   <title>Generator for Pod 177 : No advice on a generator, but...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39955#39955</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2174" rel="nofollow">shroomer</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 22 Oct 2013 at 11:20pm<br /><br />No advice on a generator, but curious about the 40# tank. We camped about 20 nights, some with heat, and used a 20# tank. More than half the cooking was outside the pod. Our refrigerator only ran on propane, never AC. (DC on the road only.) I was pleasantly surprised at the "gas mileage" I got with the propane. Have you run out of propane a lot or are you just trying to be on the safe side? <br>]]>
   <pubDate>Tue, 22 Oct 2013 23:20:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39955#39955</guid>
   <title>Generator for Pod 177 : Im sure this question has already...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39952#39952</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2334" rel="nofollow">w4bgbob</a><br /><strong>Subject:</strong> 4137<br /><strong>Posted:</strong> 22 Oct 2013 at 9:47pm<br /><br /><FONT size=2 face="Arial, Helvetica, sans-serif">Im sure this question has already been asked and answered, but i am considering getting a generator for my new R-Pod and was hoping someone could tell me how big of a generator I would need&nbsp;to handle&nbsp;the a/c and the microwave, my only mod so far is to change the 20lb propane take out to a 40lb tank. Any and all comments and or suggestions would be appreciated.</FONT>]]>
   <pubDate>Tue, 22 Oct 2013 21:47:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4137&amp;PID=39952#39952</guid>
