  <title>R-pod Owners Forum : RPod Sidewall Leak and Repair</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : RPod Sidewall Leak and Repair</description>
  <pubDate>Thu, 26 Nov 2026 16:14:25 +0000</pubDate>
  <lastBuildDate>Tue, 15 Oct 2013 08:37:58 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=4105</WebWizForums:feedURL>
   <title>RPod Sidewall Leak and Repair :   Originally posted by TerryMI&amp;#039;m...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39639#39639</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1099" rel="nofollow">Bill-GA</a><br /><strong>Subject:</strong> 4105<br /><strong>Posted:</strong> 15 Oct 2013 at 8:37am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by TerryM</strong></em><br /><br />&nbsp;I'm glad you live close to Florida in case I ever need that kind of work done on my Pod!<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /><br><br>Terry<br></td></tr></table><div><br></div><div>My Rpod was originally purchased by first owner in FL. I purchased it in Macon, GA. My sister lives in St. Augustine and we usually visit once a year.<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />&nbsp;If you see a 176T, give a wave.</div>]]>
   <pubDate>Tue, 15 Oct 2013 08:37:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39639#39639</guid>
   <title>RPod Sidewall Leak and Repair : It looks like a job well done!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39637#39637</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 4105<br /><strong>Posted:</strong> 15 Oct 2013 at 2:53am<br /><br />It looks like a job well done!&nbsp; I'm glad you live close to Florida in case I ever need that kind of work done on my Pod!<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /><br><br>Terry<br>]]>
   <pubDate>Tue, 15 Oct 2013 02:53:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39637#39637</guid>
   <title>RPod Sidewall Leak and Repair :  Repair of a 2010 176T - Top...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39631#39631</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1099" rel="nofollow">Bill-GA</a><br /><strong>Subject:</strong> 4105<br /><strong>Posted:</strong> 14 Oct 2013 at 10:51pm<br /><br />&nbsp;Repair of a 2010 176T - Top left after bad vinyl and plywood &nbsp;taken &nbsp;off. Window trim removed.<div><img src="uploads/1099/TopB4Repair.jpg" height="600" width="800" border="0" /></div><div>Bottom Left after vinyl / plywood taken off.</div><div><img src="uploads/1099/BotB4Repair.jpg" height="600" width="800" border="0" /><br></div><div>Close up showing removed plywood.</div><div><img src="uploads/1099/BotLeftOrig.jpg" height="400" width="300" border="0" /><br></div><div>Patch plywood using Contact Cement and first feathering with Bondo</div><div><img src="uploads/1099/BotLeftPatched2.jpg" height="400" width="300" border="0" /><br></div><div><br></div><div><img src="uploads/1099/B&#111;ndo.jpg" height="400" width="300" border="0" /><br></div><div>Top with plywood replacements and first Bondo feathering.&nbsp;</div><div><img src="uploads/1099/TopLeftPatched.jpg" height="300" width="400" border="0" /><br></div><div>Bottom showing final coat of Bondo. Overlap of Red coloring was covered with new vinyl.</div><div><img src="uploads/1099/BotWith5Coats.jpg" height="300" width="400" border="0" /><br></div><div>Finished with new vinyl applied. No bubbles or ripples. &nbsp;Trim (&amp; blinds) to be re-installed.</div><div><img src="uploads/1099/FinishWOTrim.jpg" height="300" width="400" border="0" /><br></div>]]>
   <pubDate>Mon, 14 Oct 2013 22:51:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39631#39631</guid>
   <title>RPod Sidewall Leak and Repair : I have a 2010 176T which I bought...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39629#39629</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1099" rel="nofollow">Bill-GA</a><br /><strong>Subject:</strong> 4105<br /><strong>Posted:</strong> 14 Oct 2013 at 10:05pm<br /><br />I have a 2010 176T which I bought used in early 2012. &nbsp;I noticed some 'rippling' of the vinyl wallpaper over my left side window. &nbsp;I didn't think much about it until the spring of 2013 (I had the factory recall for lights late in 2012). &nbsp;I began to see more rippling and some small bubbles appearing in vinyl covering above and below window. &nbsp;I called Forest River and verified they could send me some new, matched sticky vinyl, then boldly began to cut vinyl to expose the damage. It was pretty bad and I cut and exposed every thing that was wet a mushy! &nbsp;I also cut out layers of the plywood (1/16") that had come away from the existing wall. &nbsp;After it was all exposed I went outside, and caulked all the rear and corner seams. &nbsp;I then decided to leave the inside open to dry ... and to verify it would stay dry. &nbsp;I camped all summer 2013 and kept checking that it stayed dry.<div><br></div><div>Last week, &nbsp;I decided to begin the repair. &nbsp;I experimented with wood glue and 1/16" bass wood sections I purchased at Hobby Lobby. Wood Glue curled the bass wood and fell off. &nbsp;I decided to use Contact Cement which worked great! &nbsp;Since the vinyl had come off with a thin (1/64"?) layer of plywood, I decided to use BONDO (called by other names) to feather the repaired edges. &nbsp;I REALLY got bold and decide to actually create a tin layer of Bondo across the <u>entire patch job</u>. &nbsp;Caution: I have worked with this material in MANY home fixes and it is extremely hard to use as it literally begins to cure in TWO minutes. &nbsp;If you try to use this, please experiment first and get used to working with it.</div><div><br></div><div>I went with probably 5 layers (with minimal to no sanding) before I was happy. &nbsp;There was some "red bleeding" onto adjacent vinyl which I covered with new vinyl. &nbsp;I will add several pictures and comments in a single post in a few minutes. &nbsp;I welcome all comments or other experiences.</div>]]>
   <pubDate>Mon, 14 Oct 2013 22:05:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4105&amp;PID=39629#39629</guid>
