  <title>R-pod Owners Forum : wire chaffing through</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : wire chaffing through</description>
  <pubDate>Thu, 29 Oct 2026 00:56:34 +0000</pubDate>
  <lastBuildDate>Wed, 25 Sep 2013 14:18:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=4013</WebWizForums:feedURL>
   <title>wire chaffing through :   Originally posted by techntrekOT...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38683#38683</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 25 Sep 2013 at 2:18pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by techntrek</strong></em><br /><br />OT - mtbmitch, I swear each time I read your name my mind leaves out the 2nd "m".&nbsp; <img src="http://www.rpod-owners.com/smileys/smiley3.gif" height="18" width="18" border="0" alt="Shocked" title="Shocked" /></td></tr></table><br><br>Getting OLD Doug! <img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" /><br><br>Terry<br>]]>
   <pubDate>Wed, 25 Sep 2013 14:18:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38683#38683</guid>
   <title>wire chaffing through : OT - mtbmitch, I swear each time...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38680#38680</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 25 Sep 2013 at 12:03pm<br /><br />OT - mtbmitch, I swear each time I read your name my mind leaves out the 2nd "m".&nbsp; <img src="http://www.rpod-owners.com/smileys/smiley3.gif" height="18" width="18" border="0" alt="Shocked" title="Shocked" />]]>
   <pubDate>Wed, 25 Sep 2013 12:03:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38680#38680</guid>
   <title>wire chaffing through : Here is a link to some aerodyn...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38648#38648</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2239" rel="nofollow">mtbmitch</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 24 Sep 2013 at 11:09pm<br /><br />Here is a link to some aerodynamics<br>http://cafefoundation.org/v2/tech_enablingtech_dragreduction.php<br><br>]]>
   <pubDate>Tue, 24 Sep 2013 23:09:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38648#38648</guid>
   <title>wire chaffing through : The aerodynamics professional...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38642#38642</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 24 Sep 2013 at 10:16pm<br /><br />The aerodynamics professional that posted here a few days ago indicated the problem likely was the slope on the tail of the pod.  Interesting stuff.]]>
   <pubDate>Tue, 24 Sep 2013 22:16:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38642#38642</guid>
   <title>wire chaffing through : Up here in Idaho, my 4.6l with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38631#38631</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2239" rel="nofollow">mtbmitch</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 24 Sep 2013 at 8:35pm<br /><br />Up here in Idaho, my 4.6l with all of 200 hp at sea level is probably down to 140 up at 6 thousand feet.&nbsp; So it screams in 2nd gear at 65mph and on the flats with a stiff headwind, I can not pass<br>a semi in third. The wind they push is more than my 4.6 can handle. So I can turn the engine 260 rpm higher and get into the meat of the hp curve. Then without a headwind, OD will be usable.&nbsp; Thinking of making some small wind aluminim deflectors and use super strong magnetics to hold them&nbsp; in place. I guess the best thing would be an accordion type device to minimize drag between the TV and Rpod. <br>]]>
   <pubDate>Tue, 24 Sep 2013 20:35:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38631#38631</guid>
   <title>wire chaffing through : Welcome. I agree you shouldn&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38627#38627</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 24 Sep 2013 at 7:45pm<br /><br />&nbsp;Welcome. &nbsp;I agree you shouldn't need to change your rear diff. &nbsp;Going with a lower gear will hurt your mpgs. &nbsp;You'll get more torque but the problem isn't getting the pod moving off the line, its the aerodynamic drag at highway speeds. &nbsp;I have a 3.42 rear and can jump ahead of traffic from a stoplight w/o a problem.<br>]]>
   <pubDate>Tue, 24 Sep 2013 19:45:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38627#38627</guid>
   <title>wire chaffing through :   Originally posted by David...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38622#38622</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 24 Sep 2013 at 7:17pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David and Danette</strong></em><br /><br />&nbsp; Welcome to the form and the life of owning a r-pod. It will take you a little time but you will be able to fix your r-pod the way you like it so that you can enjoy it. Yes they attract attention, I stopped at a rest area in Tennessee and there was a tour bus with tourist from Australia they were asking me questions about my caravan as they call a camper in Australia . And then they started taking turns taking group pictures standing beside the r-pod. I don't think you need to change the gearing in your differential what you have I think would work fine. &nbsp; &nbsp;David</td></tr></table> &nbsp;I just noticed that you have a E-150 not a F-150 maybe changing the differential would help. &nbsp;&nbsp;]]>
   <pubDate>Tue, 24 Sep 2013 19:17:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38622#38622</guid>
   <title>wire chaffing through : Welcome to the form and the life...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38621#38621</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 24 Sep 2013 at 7:13pm<br /><br />&nbsp; Welcome to the form and the life of owning a r-pod. It will take you a little time but you will be able to fix your r-pod the way you like it so that you can enjoy it. Yes they attract attention, I stopped at a rest area in Tennessee and there was a tour bus with tourist from Australia they were asking me questions about my caravan as they call a camper in Australia . And then they started taking turns taking group pictures standing beside the r-pod. I don't think you need to change the gearing in your differential what you have I think would work fine. &nbsp; &nbsp;David]]>
   <pubDate>Tue, 24 Sep 2013 19:13:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38621#38621</guid>
   <title>wire chaffing through :  HiWe picked up a used 2010 151...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38618#38618</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2239" rel="nofollow">mtbmitch</a><br /><strong>Subject:</strong> 4013<br /><strong>Posted:</strong> 24 Sep 2013 at 4:30pm<br /><br /><img src="uploads/2239/IMAG0529_800x449.jpg" height="449" width="800" border="0" />Hi<br>&nbsp;We picked up a used 2010 151 last week. After reading tips and maintenance, I was on a mission<br>to quiet the water pump. While in the compartment, I was appalled by the factory wiring job.<br>I removed about 20 feet of extra wiring. Also the 30 amp 110 red romex was chaffing through.<br>A bit of a water leak and the wire all the way chaffed through could have been fun.<br>&nbsp; First time towing, very stable behind my 2000 Ford E-150. I will need to change out the rear drive<br>ratio from 3.55 to 3.89. Any body had any luck with aftermarket ECU chips? The Rpod's sure attract<br>a lot of attention.<br><br><br>]]>
   <pubDate>Tue, 24 Sep 2013 16:30:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4013&amp;PID=38618#38618</guid>
