  <title>R-pod Owners Forum : Our New upgrade to an R-Pod 171</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Our New upgrade to an R-Pod 171</description>
  <pubDate>Thu, 24 Sep 2026 08:36:28 +0000</pubDate>
  <lastBuildDate>Tue, 24 Sep 2013 11:46:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=4008</WebWizForums:feedURL>
   <title>Our New upgrade to an R-Pod 171 : I used a 2 ft level and leveled...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38593#38593</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1895" rel="nofollow">Craneman</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 24 Sep 2013 at 11:46am<br /><br />I used a 2 ft level and leveled our pod in the garage as best I could,then I applied the the stick on levelers I got at walley world where i could see them. Made two 2x6 three high to level side to side. We have used it a few times and it works good and fast too<div>&nbsp; &nbsp; Moe</div>]]>
   <pubDate>Tue, 24 Sep 2013 11:46:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38593#38593</guid>
   <title>Our New upgrade to an R-Pod 171 : Welcome. The only issue is the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38584#38584</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 24 Sep 2013 at 10:37am<br /><br />Welcome.&nbsp; The only issue is the fridge, as mentioned above.&nbsp; But it doesn't need to be perfect.&nbsp; In a campground I'll pull out a level and get it fairly close (but usually tilt it slightly forward to allow the shower to drain properly), but there have been stops at places like Flying J where I'll just find the most level blacktop I can find and what we get is what we get.&nbsp; Twice we've had to flip our pillows to the other side of the bed so our feet were downhill.&nbsp; When I do use a level I'll put it on the floor inside the door to figure out side-to-side inclination but will put it on the tongue as I level it front-to-back.]]>
   <pubDate>Tue, 24 Sep 2013 10:37:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38584#38584</guid>
   <title>Our New upgrade to an R-Pod 171 : Welcome and enjoy your 171 ......</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38578#38578</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1442" rel="nofollow">P&M</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 24 Sep 2013 at 9:53am<br /><br />Welcome and enjoy your 171 ... we definitely enjoy ours!&nbsp; Yes, you need to level the Pod out when you park it, side-to-side and front-to-back, as close to level as you can get it without spending an hour on it.&nbsp; We use the same process as Hogone described above.]]>
   <pubDate>Tue, 24 Sep 2013 09:53:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38578#38578</guid>
   <title>Our New upgrade to an R-Pod 171 : Welcome to your new 171! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38568#38568</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 24 Sep 2013 at 7:25am<br /><br />Welcome to your new 171!]]>
   <pubDate>Tue, 24 Sep 2013 07:25:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38568#38568</guid>
   <title>Our New upgrade to an R-Pod 171 : not perfectly level, but doesn&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38567#38567</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 24 Sep 2013 at 7:09am<br /><br />not perfectly level, but doesn't it need to be fairly level for the fridge to work properly?&nbsp; I thought I read that somewhere before.&nbsp; I always try to get it close, but never perfect it seems.&nbsp; I carry a small&nbsp; level with me and just put on the floor for leveling side to side (use blocks), and then the jack in front for front to back leveling<br>]]>
   <pubDate>Tue, 24 Sep 2013 07:09:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38567#38567</guid>
   <title>Our New upgrade to an R-Pod 171 : If it is to far from level you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38564#38564</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 24 Sep 2013 at 3:57am<br /><br />If it is to far from level you may roll out of bed.]]>
   <pubDate>Tue, 24 Sep 2013 03:57:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38564#38564</guid>
   <title>Our New upgrade to an R-Pod 171 : Hi and welcome to the group! You...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38561#38561</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 24 Sep 2013 at 3:19am<br /><br />Hi and welcome to the group!&nbsp; You don't have to have it level, but you should be close I guess.&nbsp; I have had mine pretty far from level and didn't have any problems.<br><br>Terry<br>]]>
   <pubDate>Tue, 24 Sep 2013 03:19:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38561#38561</guid>
   <title>Our New upgrade to an R-Pod 171 : Hi   We just upgraded from a Tear...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38550#38550</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2259" rel="nofollow">Broz</a><br /><strong>Subject:</strong> 4008<br /><strong>Posted:</strong> 23 Sep 2013 at 10:35pm<br /><br />Hi <br /><br />We just upgraded from a Tear Drop camper to our R-Pod 171. Looking forward to many many nights in the camper. At least with this one we can stand up in- I guess that is a bonus. <br /><br />One quick question - I did not notice any level bubbles on the trailer. Is it necessary to level the camper? We had to level the Tear Drop due to the Air conditioner. <br /><br />Well we are looking forward to taking out the camper this weekend. We just purchased the camper on Thursday.<br /><br />BROZ]]>
   <pubDate>Mon, 23 Sep 2013 22:35:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=4008&amp;PID=38550#38550</guid>
