  <title>R-pod Owners Forum : Trim sealant on Rpod</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Trim sealant on Rpod</description>
  <pubDate>Wed, 28 Oct 2026 22:31:28 +0000</pubDate>
  <lastBuildDate>Sun, 08 Sep 2013 12:57:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3942</WebWizForums:feedURL>
   <title>Trim sealant on Rpod : Camping World is always a good...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37854#37854</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 12:57pm<br /><br />Camping World is always a good source.&nbsp; Here is a link to those on eBay.&nbsp; Some even show you how to measure for the correct width.&nbsp; Looks like it comes in 1/2, 3/4 ad 1" widths, with 1" being the most common.<br>http://www.ebay.com/sch/i.html?_sacat=0&amp;_from=R40&amp;_nkw=RV+vinyl+trim&amp;_dcat=50069&amp;Part%2520Type=Exterior&amp;rt=nc<br><br>Bob<br>]]>
   <pubDate>Sun, 08 Sep 2013 12:57:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37854#37854</guid>
   <title>Trim sealant on Rpod : I was looking at it on the campers...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37853#37853</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 11:00am<br /><br />I was looking at it on the campers world website.&nbsp; It comes in various lengths, either 3/4 or 1 inch wide, and in various colors.&nbsp; If I recall right, a 100 foot length runs around $20.&nbsp; I'm going to check to see if I can get some under warranty, but again the whole job for around $20.&nbsp; <br>]]>
   <pubDate>Sun, 08 Sep 2013 11:00:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37853#37853</guid>
   <title>Trim sealant on Rpod : Can you post a link to the trim,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37852#37852</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=140" rel="nofollow">HuronSailor</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 10:42am<br /><br />Can you post a link to the trim, please?]]>
   <pubDate>Sun, 08 Sep 2013 10:42:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37852#37852</guid>
   <title>Trim sealant on Rpod : Squeeze it. If you buy the right...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37851#37851</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 10:32am<br /><br />Squeeze it.&nbsp; If you buy the right width, it will fit tightly in the channel.&nbsp; <br><br>Bob<br>]]>
   <pubDate>Sun, 08 Sep 2013 10:32:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37851#37851</guid>
   <title>Trim sealant on Rpod : So to install, do you squeeze...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37850#37850</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 10:20am<br /><br />So to install, do you squeeze it into the channel as well, or slide it in from one of the ends?<br>]]>
   <pubDate>Sun, 08 Sep 2013 10:20:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37850#37850</guid>
   <title>Trim sealant on Rpod : Good point, Derek, one I forgot...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37849#37849</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 9:59am<br /><br />Good point, Derek, one I forgot to mention.&nbsp; The vinyl strip will have a tendency to shift unless it is anchored at both ends.&nbsp; However, don't anchor it until it has had some time to acclimate.&nbsp; Chances are it will stretch in length a little when you insert it, so give it a little time to relax to its normal length.&nbsp; The first time I replaced a trim strip, I trimmed it to length right away.&nbsp; After a few days in the sun, it was a few inches too short.&nbsp; Allow a little extra length, and wait a few days before trimming. <br><br>Bob<br>]]>
   <pubDate>Sun, 08 Sep 2013 09:59:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37849#37849</guid>
   <title>Trim sealant on Rpod : Make sure you check the ends of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37847#37847</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=665" rel="nofollow">DerekMc</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 9:28am<br /><br />Make sure you check the ends of the trim pieces as with mine it was tucked in underneath about an inch and had a screw in it. It was also sealed around the screw.&nbsp;<div><br></div><div>Derek</div>]]>
   <pubDate>Sun, 08 Sep 2013 09:28:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37847#37847</guid>
   <title>Trim sealant on Rpod : Thanks Sleepless. So even if not...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37843#37843</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 9:13am<br /><br />Thanks Sleepless.&nbsp; So even if not covered, a cheap fix.&nbsp; I'll call to check though.<br>]]>
   <pubDate>Sun, 08 Sep 2013 09:13:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37843#37843</guid>
   <title>Trim sealant on Rpod : I have replaced the trim on 2...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37841#37841</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 8:58am<br /><br />I have replaced the trim on 2 or 3 trailers that I have owned through the years.&nbsp; Normally the vinyl will last for many years.&nbsp; Removal of the old and insertion of new is very simple.&nbsp; Just squeeze the sides together and it come right out of the channel.&nbsp; 1" is the most common size but it does come in at least one other width.&nbsp; Cost is around $8.00 to $10.00 per roll and a pod would probably take 2 rolls.&nbsp; I would think it would be covered under warranty.&nbsp; <br><br>Bob<br>]]>
   <pubDate>Sun, 08 Sep 2013 08:58:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37841#37841</guid>
   <title>Trim sealant on Rpod : The trim on mine is all cracked...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37840#37840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 08 Sep 2013 at 8:28am<br /><br />The trim on mine is all cracked on both sides.&nbsp; I wonder if this would be covered under warranty; I have an extended plan but do not have any info on exactly what is covered.<br>]]>
   <pubDate>Sun, 08 Sep 2013 08:28:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37840#37840</guid>
   <title>Trim sealant on Rpod : The trim comes in different widths....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37819#37819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 07 Sep 2013 at 12:46pm<br /><br />The trim comes in different widths.&nbsp; From what you described, you need to install the wider width.&nbsp; No sealant is required.<br><br>Bob<br>]]>
   <pubDate>Sat, 07 Sep 2013 12:46:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37819#37819</guid>
   <title>Trim sealant on Rpod : Back in July of 2013, Omaha, NE...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37807#37807</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1293" rel="nofollow">betsypgarmy@yahoo.co</a><br /><strong>Subject:</strong> 3942<br /><strong>Posted:</strong> 06 Sep 2013 at 11:24pm<br /><br /><div><br></div><div><br></div>Back in July of 2013, Omaha, NE experienced a significant hail storm. The 2012 R177 RPod was unscathed (no dents) with the exception of the black trim on both sides of the Pod. Only one side of the trim needed it replacing though. This black trim covers the screws on both sides of the Pod.<div><br></div><div>The dealer suggested buying a package of black trim and installing ourselves. Our son replaced it on the damaged side of the Pod.</div><div><br></div><div>While traveling last weekend, we noticed we were dragging the trim behind the trailer and had to remove it.</div><div><br></div><div>What is the best way to install this trim, so it &nbsp;stays?&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley18.gif" border="0" alt="Ouch" title="Ouch" /></div><div><br></div><div>Thanks</div><div>The Conways and two Scotties</div><div>2012 Toyota Highlander</div><div><br></div><div><br></div>]]>
   <pubDate>Fri, 06 Sep 2013 23:24:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3942&amp;PID=37807#37807</guid>
