  <title>R-pod Owners Forum : Carbon Monoxide Detector</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Carbon Monoxide Detector</description>
  <pubDate>Thu, 29 Oct 2026 00:57:12 +0000</pubDate>
  <lastBuildDate>Sun, 08 Sep 2013 09:34:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3917</WebWizForums:feedURL>
   <title>Carbon Monoxide Detector :  I replaced the factory unit...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37848#37848</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 3917<br /><strong>Posted:</strong> 08 Sep 2013 at 9:34am<br /><br /><font size="2"><font face="Times New Roman, Times, serif">I replaced the factory unit with a Kidde KN-COSM-B when it refused to stop beeping. I can only assume it works since it hasn't gone off yet. There's no indication it is or isn't designed for RV use.<br><br>http://www.amazon.com/Kidde-KN-COSM-B-Battery-Operated-Combination-Monoxide/dp/B00004WA4C/ref=sr_1_2?ie=UTF8&amp;qid=1378646919&amp;sr=8-2&amp;keywords=smoke+detector<br></font></font>]]>
   <pubDate>Sun, 08 Sep 2013 09:34:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37848#37848</guid>
   <title>Carbon Monoxide Detector :   Originally posted by techntrekAs...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37846#37846</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3917<br /><strong>Posted:</strong> 08 Sep 2013 at 9:26am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by techntrek</strong></em><br /><br />As far as I know the smoke and CO detectors are the same as home models.</td></tr></table><br><br>I agree.<br><br><br>]]>
   <pubDate>Sun, 08 Sep 2013 09:26:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37846#37846</guid>
   <title>Carbon Monoxide Detector : Anybody have any other input on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37844#37844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 3917<br /><strong>Posted:</strong> 08 Sep 2013 at 9:15am<br /><br />Anybody have any other input on this............RV CO detectors vs household ones?<br>]]>
   <pubDate>Sun, 08 Sep 2013 09:15:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37844#37844</guid>
   <title>Carbon Monoxide Detector : I looked my detector up and it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37566#37566</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 3917<br /><strong>Posted:</strong> 02 Sep 2013 at 9:12pm<br /><br />I looked my detector up and it specifically stated for RV's due to the wide temperature variations and road vibrations.&nbsp; The one I have in the pod is $45 dollars from amazon, basic home models around $15. &nbsp;I guess I'm not sure if this is the case or just a marketing ploy.&nbsp; It really isn't the cost, more is this info accurate.<br>]]>
   <pubDate>Mon, 02 Sep 2013 21:12:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37566#37566</guid>
   <title>Carbon Monoxide Detector : As far as I know the smoke and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37565#37565</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3917<br /><strong>Posted:</strong> 02 Sep 2013 at 8:56pm<br /><br />As far as I know the smoke and CO detectors are the same as home models.]]>
   <pubDate>Mon, 02 Sep 2013 20:56:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37565#37565</guid>
   <title>Carbon Monoxide Detector : Must replace carbon monoxide detector....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37555#37555</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 3917<br /><strong>Posted:</strong> 02 Sep 2013 at 2:51pm<br /><br />Must replace carbon monoxide detector.&nbsp; What is the difference between the RV Carbon Monoxide detectors which are expensive and a $15.00 home model?<br>HogOne<br>]]>
   <pubDate>Mon, 02 Sep 2013 14:51:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3917&amp;PID=37555#37555</guid>
