  <title>R-pod Owners Forum : Electric problem</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Electric problem</description>
  <pubDate>Wed, 28 Oct 2026 23:18:55 +0000</pubDate>
  <lastBuildDate>Sun, 04 Aug 2013 21:05:59 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3799</WebWizForums:feedURL>
   <title>Electric problem : Check your cable connections to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36367#36367</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 04 Aug 2013 at 9:05pm<br /><br />Check your cable connections to your battery.&nbsp; If you are attaching the charger directly to the cables, you are bypassing the battery if the terminals need to be cleaned.&nbsp; Otherwise, yes, you might have a dead battery, but I doubt it.<br><br>Bob<br>]]>
   <pubDate>Sun, 04 Aug 2013 21:05:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36367#36367</guid>
   <title>Electric problem : no breaker kicked,got a smsll...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36356#36356</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1010" rel="nofollow">rex</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 04 Aug 2013 at 8:04pm<br /><br />no breaker kicked,got a smsll charger from a friend got it set at 2amps as long as its connected all works ok leaving lake tuesday morning,could i have a bad battery !!!&nbsp; thanks for help rex pHp stuart fla]]>
   <pubDate>Sun, 04 Aug 2013 20:04:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36356#36356</guid>
   <title>Electric problem : Should be one that controls the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36348#36348</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 04 Aug 2013 at 3:09pm<br /><br />Should be one that controls the converter, yes. &nbsp;However, that is different than the battery itself. &nbsp;Its good you disconnect it. &nbsp;But the circuit breaker would control the converter when plugged into AC.]]>
   <pubDate>Sun, 04 Aug 2013 15:09:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36348#36348</guid>
   <title>Electric problem :   Originally posted by techntrekFridge,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36346#36346</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1958" rel="nofollow">Sleepless</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 04 Aug 2013 at 1:51pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by techntrek</strong></em><br /><br />Fridge, lights, bathroom fan, all need 12 volts to run so it sounds like the converter is dead. &nbsp;First check for flipped circuit breakers, one of them controls the converter itself.</td></tr></table><br><br>techntrek, are you sure that one breaker controls the converter itself?&nbsp; You may have just taught me something.&nbsp; I have always disconnected the battery cable to stop battery drain while in storage.&nbsp; My pod is in storage now so I can't check it out.<br><br>Bob<br>]]>
   <pubDate>Sun, 04 Aug 2013 13:51:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36346#36346</guid>
   <title>Electric problem : Fridge, lights, bathroom fan,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36344#36344</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 04 Aug 2013 at 11:58am<br /><br />Fridge, lights, bathroom fan, all need 12 volts to run so it sounds like the converter is dead. &nbsp;First check for flipped circuit breakers, one of them controls the converter itself.]]>
   <pubDate>Sun, 04 Aug 2013 11:58:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36344#36344</guid>
   <title>Electric problem : thanks will find a meter and check  ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36328#36328</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1010" rel="nofollow">rex</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 03 Aug 2013 at 8:54pm<br /><br />thanks will find a meter and check]]>
   <pubDate>Sat, 03 Aug 2013 20:54:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36328#36328</guid>
   <title>Electric problem : if you have a volt meter check...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36327#36327</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2101" rel="nofollow">asreichler</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 03 Aug 2013 at 8:51pm<br /><br />if you have a volt meter check the voltage at the battery terminals. should be over 13 volts if you are getting a charge from the converter. if not that is your problem. the frig needs 12 volts to run ite electronics.]]>
   <pubDate>Sat, 03 Aug 2013 20:51:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36327#36327</guid>
   <title>Electric problem : Just got back to camp from fishing.Went...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36325#36325</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1010" rel="nofollow">rex</a><br /><strong>Subject:</strong> 3799<br /><strong>Posted:</strong> 03 Aug 2013 at 8:41pm<br /><br /><font size="2"><font face="Arial, Helvetica, sans-serif">Just got back to camp from fishing.Went inside;ac was running.all inside outlets worked,roof fan not working,fridge not running,micro working,tv works,all was hooked up to shore power this morning,pulled out side cover of fridge checked outlet it worked. took battery charger hooked to battery.ext lights came on and so did fridge,shows it is on shore power by the symbols display, need help maybe something simple.&nbsp; Paige if you see this will have answers soon. ready to take long trip about 4 weeks, so far all is working fine&nbsp; rex pHp stuart fla</font></font>]]>
   <pubDate>Sat, 03 Aug 2013 20:41:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3799&amp;PID=36325#36325</guid>
