  <title>R-pod Owners Forum : elect outlets upfront</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : elect outlets upfront</description>
  <pubDate>Sat, 24 Oct 2026 03:23:25 +0000</pubDate>
  <lastBuildDate>Sat, 20 Jul 2013 10:34:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3571</WebWizForums:feedURL>
   <title>elect outlets upfront : Our 2013 171 has an electrical...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=35814#35814</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 3571<br /><strong>Posted:</strong> 20 Jul 2013 at 10:34am<br /><br />Our 2013 171 has an electrical outlet next to the converter.  It is stock from the factory.  Safe Travels.]]>
   <pubDate>Sat, 20 Jul 2013 10:34:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=35814#35814</guid>
   <title>elect outlets upfront : You may want to consider just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33989#33989</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1442" rel="nofollow">P&M</a><br /><strong>Subject:</strong> 3571<br /><strong>Posted:</strong> 05 Jun 2013 at 9:36am<br /><br />You may want to consider just adding one under the table below the bench seat, up against the front wall as close as you want.&nbsp; That way you won't have to try and run the wiring all the way to the ledge top, and the coffee cord can just plug into it without being in the way.]]>
   <pubDate>Wed, 05 Jun 2013 09:36:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33989#33989</guid>
   <title>elect outlets upfront : Not sure what you are asking.  ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33967#33967</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3571<br /><strong>Posted:</strong> 04 Jun 2013 at 7:56pm<br /><br />Not sure what you are asking.]]>
   <pubDate>Tue, 04 Jun 2013 19:56:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33967#33967</guid>
   <title>elect outlets upfront : how about horizontal cross board...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33953#33953</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1718" rel="nofollow">lsrens</a><br /><strong>Subject:</strong> 3571<br /><strong>Posted:</strong> 04 Jun 2013 at 4:58pm<br /><br />how about horizontal cross board behind wall, dont want any surprises after outlet hole is cut]]>
   <pubDate>Tue, 04 Jun 2013 16:58:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33953#33953</guid>
   <title>elect outlets upfront : If you mean the shelf on the front...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33946#33946</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3571<br /><strong>Posted:</strong> 04 Jun 2013 at 3:08pm<br /><br />If you mean the shelf on the front wall, you could tap into a 120 volt source right at the converter.&nbsp; It is located under the driver-side bench.]]>
   <pubDate>Tue, 04 Jun 2013 15:08:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33946#33946</guid>
   <title>elect outlets upfront : has anyone put an electrical outlet...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33943#33943</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1718" rel="nofollow">lsrens</a><br /><strong>Subject:</strong> 3571<br /><strong>Posted:</strong> 04 Jun 2013 at 1:48pm<br /><br />has anyone put an electrical outlet up front on the wooden ledge shelve in a 2014 &nbsp;r171, if so could use wiring diagram , also wondering if there are any cross boards that may be in the wall that would stop wire from being run, it would be nice to run coffee maker on the table instead of cogesting the work area by stove]]>
   <pubDate>Tue, 04 Jun 2013 13:48:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3571&amp;PID=33943#33943</guid>
