  <title>R-pod Owners Forum : Fish&#039;n&#039;Chips for 2</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Gas/electric stove : Fish&#039;n&#039;Chips for 2</description>
  <pubDate>Sun, 04 Oct 2026 02:15:45 +0000</pubDate>
  <lastBuildDate>Mon, 03 Jun 2013 15:54:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3549</WebWizForums:feedURL>
   <title>Fish&#039;n&#039;Chips for 2 : Tried past week end with sea trout...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3549&amp;PID=33911#33911</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1010" rel="nofollow">rex</a><br /><strong>Subject:</strong> 3549<br /><strong>Posted:</strong> 03 Jun 2013 at 3:54pm<br /><br />Tried past week end with sea trout excellent ,happy trails to you rex pHp stuart fl.]]>
   <pubDate>Mon, 03 Jun 2013 15:54:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3549&amp;PID=33911#33911</guid>
   <title>Fish&#039;n&#039;Chips for 2 : These are best cooked using a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3549&amp;PID=33740#33740</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1442" rel="nofollow">P&M</a><br /><strong>Subject:</strong> 3549<br /><strong>Posted:</strong> 29 May 2013 at 8:57am<br /><br />These are best cooked using a propane stove as it will be easier to keep the heat consistent.<DIV>&nbsp;</DIV><DIV><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">1 pound of Cod or other suitable fish</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">1.5 cups of flour</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">1 tsp each of salt, pepper, garlic powder, onion powder, and baking powder</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">1 Tbl of Old Bay seasoning</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">1 egg</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">1 bottle of good beer (or water if you prefer)</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">2 potatoes cut into fries</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">Canola or Peanut oil</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><?: prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">&nbsp;</FONT></o:p></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">Add the flour and all the seasonings to a bag and mix up … do this ahead of time and take with you camping already prepared.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>1 hour before cooking dump the dry mix into a bowl, add egg and beer and stir up.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Add more or less liquid to make your batter as thick or thin as you would like it to be.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Cut up the fish into smaller pieces, add to the batter and stir them up to make sure they are all covered, put lid or cover on it and put in fridge/cooler to stay cold.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Pour oil 2” deep in cast iron pan or dutch oven and start heating it up.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>It is hot enough when you dip an end of a fry into it and it starts to immediately sizzle.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Add the fries and cook for 8-10 minutes … do them in 2 batches if you have a smaller pan.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Take out to drain on paper towels or newspaper and immediately salt them.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Let the oil come back up to temp, and then start adding the fish.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Take them out of the batter and let some of it drain off before putting them into the oil … use tongs or a fork so you don’t get splatter burned!<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Cook for 4-5 minutes and then flip over and cook for another 4-5 minutes … they should be golden brown and crunchy.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Take out and drain, continuing to add fish until completed.</FONT></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><o:p><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">&nbsp;</FONT></o:p></P><P style="LINE-HEIGHT: normal; MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT size=2 face="Geneva, Arial, Helvetica, sans-serif">Serve with malt vinegar, lemon and tartar sauce – or whatever else floats your boat!</FONT></P></DIV>]]>
   <pubDate>Wed, 29 May 2013 08:57:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3549&amp;PID=33740#33740</guid>
