  <title>R-pod Owners Forum : TV Antenna Removal</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Miscellaneous / Off-topic : TV Antenna Removal</description>
  <pubDate>Sun, 25 Oct 2026 05:08:08 +0000</pubDate>
  <lastBuildDate>Sun, 05 May 2013 16:53:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3452</WebWizForums:feedURL>
   <title>TV Antenna Removal :  We have been thinking of removing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32828#32828</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 3452<br /><strong>Posted:</strong> 05 May 2013 at 4:53pm<br /><br />We have been thinking of removing ours, and putting in one that will actually get signal, it means not only covering and closing one hole.. but making another..<br><br>Please note.. we aren't putting it very high on the mod list, since it was just last month we ever even tried to watch TV..<br>]]>
   <pubDate>Sun, 05 May 2013 16:53:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32828#32828</guid>
   <title>TV Antenna Removal : I wouldn&amp;#039;t worry about leaks,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32819#32819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3452<br /><strong>Posted:</strong> 05 May 2013 at 10:41am<br /><br />I wouldn't worry about leaks, just use a liberal amount of caulk like the factory did when it installed everything.]]>
   <pubDate>Sun, 05 May 2013 10:41:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32819#32819</guid>
   <title>TV Antenna Removal : I&amp;#039;ve thought of taking mine...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32815#32815</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 3452<br /><strong>Posted:</strong> 04 May 2013 at 8:41pm<br /><br />I've thought of taking mine off because it looks stupid and is useless but currently I'd rather not fool with the change of a leak afterwards.]]>
   <pubDate>Sat, 04 May 2013 20:41:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32815#32815</guid>
   <title>TV Antenna Removal : If you&amp;#039;re looking for increased...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32813#32813</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 3452<br /><strong>Posted:</strong> 04 May 2013 at 4:52pm<br /><br /><font size="3"><font face="Times New Roman, Times, serif">If you're <font size="3">looking for increased gas mileage, I doubt the <font size="3">removal</font> of the antenna will make much difference. The big contributor is the front cross sectional area of the pod. As some<font size="3">one said to me "it's like pulling a parachute."<br><font size="3">That said, the antenna is a bit useless so removing it <font size="3">won't hurt if you don't creat<font size="3">e a leak.</font></font> </font><br></font></font></font></font>]]>
   <pubDate>Sat, 04 May 2013 16:52:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32813#32813</guid>
   <title>TV Antenna Removal : Has anyone removed the television...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32811#32811</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=714" rel="nofollow">Podsible Dream</a><br /><strong>Subject:</strong> 3452<br /><strong>Posted:</strong> 04 May 2013 at 3:44pm<br /><br />Has anyone removed the television antenna from the front roof of the pod? &nbsp;I am considering it after knowing the mileage I get with it up there. &nbsp;Don't watch TV when camping, so it isn't needed.<div><br></div><div>Any help appreciated. Walt</div>]]>
   <pubDate>Sat, 04 May 2013 15:44:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3452&amp;PID=32811#32811</guid>
