  <title>R-pod Owners Forum : Worlds End SP</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Camping Adventures : Worlds End SP</description>
  <pubDate>Fri, 23 Oct 2026 14:07:15 +0000</pubDate>
  <lastBuildDate>Sat, 27 Apr 2013 20:51:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3431</WebWizForums:feedURL>
   <title>Worlds End SP : Yes   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32653#32653</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1648" rel="nofollow">Yak</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 27 Apr 2013 at 8:51pm<br /><br />Yes]]>
   <pubDate>Sat, 27 Apr 2013 20:51:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32653#32653</guid>
   <title>Worlds End SP : Good to know. I assume the repeater&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32648#32648</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 27 Apr 2013 at 5:59pm<br /><br />Good to know. &nbsp;I assume the repeater's antenna is fairly high.]]>
   <pubDate>Sat, 27 Apr 2013 17:59:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32648#32648</guid>
   <title>Worlds End SP : OK, you saw the antenna on the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32637#32637</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1648" rel="nofollow">Yak</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 26 Apr 2013 at 9:52pm<br /><br />OK, you saw the antenna on the back of my camper, it's called a J-Pole. Using that antenna and less than a watt I can work the repeater in Paoli from French Creek on 2 meters, 50 miles??]]>
   <pubDate>Fri, 26 Apr 2013 21:52:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32637#32637</guid>
   <title>Worlds End SP :  Well, same height rules (and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32636#32636</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 26 Apr 2013 at 9:27pm<br /><br /><p>Well, same height rules (and both allow external antennas unlike FRS) so it comes down to frequency and wattage.</p><p>Any recommendations for programmable mobile and handheld units?</p>]]>
   <pubDate>Fri, 26 Apr 2013 21:27:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32636#32636</guid>
   <title>Worlds End SP : I&amp;#039;ll take the high antenna...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32629#32629</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1648" rel="nofollow">Yak</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 26 Apr 2013 at 7:59pm<br /><br />I'll take the high antenna for $500 Alex<img src="https://www.rpod-owners.com/smileys/smiley2.gif" border="0" alt="Wink" title="Wink" />]]>
   <pubDate>Fri, 26 Apr 2013 19:59:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32629#32629</guid>
   <title>Worlds End SP : I definitely need to look into...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32610#32610</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 26 Apr 2013 at 12:52pm<br /><br />I definitely need to look into the Tech license - wouldn't take much review for me to pass it.&nbsp; Getting a ham rig needs to be a priority on my prep to-dos (I've been working on supplies for a while), for communication with the outside world. <DIV>&nbsp;</DIV><DIV>Sorry I should have been more specific with my question.&nbsp; I'm looking into family communication if SHTF and one of us needs to go some distance from home base (or an evacuation forces us apart).&nbsp; So I'm&nbsp;assuming no cell phone system, or repeaters&nbsp;of any type.&nbsp; There's zero chance I'll get them to learn/take/pass a ham certification so this leaves the unlicensed voice bands.&nbsp; I know of four options:</DIV><DIV>&nbsp;</DIV><DIV>CB, 27 Mhz, 5 watts max, 40 channels (not including SSB), close to 10 meter ham so decent distance</DIV><DIV>&nbsp;</DIV><DIV>MURS, 151/154 Mhz,&nbsp;2 watts max, 5 channels, close to 2 meter ham so decent distance</DIV><DIV>&nbsp;</DIV><DIV>FRS/GMRS, 462/467 Mhz, 50 watts max (1/2 watt for some FRS&nbsp;channels), 22 channels simplex, above 70 cm ham so fairly short range&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>CB, FRS/GMRS has a wide availability of cheap equipment.&nbsp; Great if you need to scrounge for replacement equipment after SHTF, and for information sharing with the local community, but not great for uninterrupted point-to-point communication.&nbsp; You are right that the GMRS-only channels require a license but it covers a whole family so a minor hurdle.&nbsp; Not to mention that most people that buy the low-powered bubble pack junk don't bother - and I wouldn't care under SHTF conditions for any power.&nbsp; If I went with higher power equipment under normal conditions I would get the license to CYA - I don't need a ding on my record if I go for the ham license.&nbsp; I used CB a lot in the 80's and 90's so I'm familiar with that beast.&nbsp; SSB would be a must in many cases for decent range but getting the family to learn how to dial it in wouldn't be fun.&nbsp; GMRS at high power and 60 feet tower height (or 20 above attached structure) keeps it in the running for 2nd place.&nbsp; MURS only has 5 channels and 2 watts max but its frequency helps, and few people have radios for it.&nbsp; I think it has the same antenna height rules.</DIV>]]>
   <pubDate>Fri, 26 Apr 2013 12:52:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32610#32610</guid>
   <title>Worlds End SP : Yak - Thanks for the video....COOL!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32605#32605</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 26 Apr 2013 at 7:09am<br /><br /><P>Yak - Thanks for the video....COOL!&nbsp; (from an ex-Podder).</P><DIV>Tech - I will add my $.02 and +1 on the Ham license.&nbsp; FMRS &amp; GMRS, in a SHTF scenario - a lot of CERT teams (Community Emergency Response Teams) use the freqs so, they would likely be crowded.&nbsp; Plus, I think, GMRS, with it's higher power, requires a license (I think).&nbsp; The Ham 144mhz and 440 mhz will likely be busy with ARES &amp; RACES activity - both repeaters (if they are still working) and simplex freqs.&nbsp;- depending on the scale of the situation.</DIV><DIV>&nbsp;</DIV><DIV>However, even with an entry level Technician license, you could still likely use 6 meters (50 mhz) or 10 meters (28 mhz).&nbsp; There's lots of room on both.&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>I would be willing to bet that you could pass the test with little or no study...given your present knowledge.&nbsp; There are sites on the Web where one can take "sample" tests.&nbsp; Give one a try and see how you do! <img src="http://www.rpod-owners.com/smileys/smiley1.gif" height="18" width="18" border="0" alt="Smile" title="Smile" /></DIV><DIV>&nbsp;</DIV><DIV>NOTE:&nbsp; ARES = Amateur Radio Emergency Service</DIV><DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; RACES = Radio Amateur Civil Emergency Service (operates under/at the direction of the&nbsp;&nbsp;&nbsp; Dept. of Homeland Security)&nbsp;</DIV>]]>
   <pubDate>Fri, 26 Apr 2013 07:09:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32605#32605</guid>
   <title>Worlds End SP : True propagation has little to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32602#32602</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1648" rel="nofollow">Yak</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 25 Apr 2013 at 10:18pm<br /><br />True propagation has little to do with VHF or UHF and are line of sight communications. GMRS allows repeater use, MD has about 14 open repeaters listed. If I remember GMRS allow added antennas 50 watts and a high antenna can do a lot. But..... from reading your posts and talking to you a ham license is just a few weeks of studying away<img src="https://www.rpod-owners.com/smileys/smiley2.gif" border="0" alt="Wink" title="Wink" /><br>]]>
   <pubDate>Thu, 25 Apr 2013 22:18:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32602#32602</guid>
   <title>Worlds End SP : Hey Yak, glad you checked in....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32600#32600</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 25 Apr 2013 at 9:35pm<br /><br /><p>Hey Yak, glad you checked in. &nbsp;I liked the vid, cool idea.</p><p>Just today I was looking into MURS vs. GMRS for long-distance communication in case of SHTF. &nbsp;We've had cheapo FRS/GMRS radios for years so I know how crowded those bands can be when everyone around you has them too. &nbsp;Few have (or even know about) MURS, and with frequencies in the 151-154 Mhz range it should have decent propogation with little absorption, not so much for GMRS at 462 Mhz. &nbsp;But MURS is only allowed to max out at 2 watts vs. 50 for GMRS. &nbsp;Any thoughts? &nbsp;<img src="https://www.rpod-owners.com/smileys/smiley16.gif" border="0" alt="Cool" title="Cool" /></p>]]>
   <pubDate>Thu, 25 Apr 2013 21:35:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32600#32600</guid>
   <title>Worlds End SP : In Sullivan Co PA, paid a visit...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32597#32597</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1648" rel="nofollow">Yak</a><br /><strong>Subject:</strong> 3431<br /><strong>Posted:</strong> 25 Apr 2013 at 9:16pm<br /><br />In Sullivan Co PA, paid a visit to my favorite campground over the weekend. At most there were 10 sites being used. Here's a little vid from the weekend. Sorry it's not a Pod<br><br><br>&#091;TUBE&#093;_HCNOmrog-8&#091;/TUBE&#093;<br>]]>
   <pubDate>Thu, 25 Apr 2013 21:16:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3431&amp;PID=32597#32597</guid>
