  <title>R-pod Owners Forum : Non-Ethanol Gas</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : Non-Ethanol Gas</description>
  <pubDate>Wed, 23 Sep 2026 07:28:46 +0000</pubDate>
  <lastBuildDate>Thu, 03 Jul 2014 10:14:01 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3389</WebWizForums:feedURL>
   <title>Non-Ethanol Gas : Everyone needs to bookmark this...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=47833#47833</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2258" rel="nofollow">CO_PILOT</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 03 Jul 2014 at 10:14am<br /><br /><p>Everyone needs to bookmark this website&nbsp; that locates ethanol-free fuel retailers in every state:&nbsp;</p><p><br></p><p>http://pure-gas.org/&nbsp;</p><p><br></p>]]>
   <pubDate>Thu, 03 Jul 2014 10:14:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=47833#47833</guid>
   <title>Non-Ethanol Gas : I used &amp;#039;regular-ethanol&amp;#039;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=36871#36871</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=422" rel="nofollow">TIDALWAVE</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 17 Aug 2013 at 11:11am<br /><br />I used 'regular-ethanol' gas for my ATV, boat motors, etc., until they all had to go into the shop for 'carb-adjustment' cleaning.&nbsp; Every mechanic told me that a majority of gas line problems they worked on were directly caused by using ethanol.&nbsp; I immediately began to use non-ethanol...all of my engines start quickly and I have never had a fuel line problem since then.&nbsp; The $500 in repair/cleaning would have paid for a lot of 'hi-cost' non-ethanol gas.<br>I have found that a couple of my cars do not seem to get much better mileage from non-ethanol. But my TV pickup does. So when I tow my Pod, I use my calculator to determine if buying the more expensive non-ethanol is worth getting better mileage. <br>]]>
   <pubDate>Sat, 17 Aug 2013 11:11:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=36871#36871</guid>
   <title>Non-Ethanol Gas : Those with boats keep in mind...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=36679#36679</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2114" rel="nofollow">ahefner</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 12 Aug 2013 at 9:44pm<br /><br />Those with boats keep in mind that ethanol fuel is a bad idea. From my understanding ethanol is hydrophilic which means that it attracts moisture and will result in water forming in the gas tanks.<div><br></div><div>Seafoam or other fuel treatments may help with this but try to buy the real stuff if it is available when buying fuel for your boat.</div>]]>
   <pubDate>Mon, 12 Aug 2013 21:44:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=36679#36679</guid>
   <title>Non-Ethanol Gas : I filled up with it when I was...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32683#32683</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 29 Apr 2013 at 12:18pm<br /><br />I filled up with it when I was setting on empty.&nbsp; I gained 4/10ths of a mileage gain.<br><br>Terry<br>]]>
   <pubDate>Mon, 29 Apr 2013 12:18:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32683#32683</guid>
   <title>Non-Ethanol Gas :   I hd never seen one with them...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32248#32248</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 13 Apr 2013 at 7:50am<br /><br />I hd never seen one with them but I have not seen them all.&nbsp; Thanks,]]>
   <pubDate>Sat, 13 Apr 2013 07:50:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32248#32248</guid>
   <title>Non-Ethanol Gas : Our gas stations will have the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32244#32244</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1173" rel="nofollow">Racer|X|</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 12 Apr 2013 at 9:56pm<br /><br />Our gas stations will have the high octane non-ethanol for "recreation vehicles" as the signs usually state.<div><br></div><div>Keith...Farm &amp; Fleet doesn't have gas pumps by me.</div><div><br></div><div>X</div>]]>
   <pubDate>Fri, 12 Apr 2013 21:56:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32244#32244</guid>
   <title>Non-Ethanol Gas : About a quarter of the gas stations...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32225#32225</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=422" rel="nofollow">TIDALWAVE</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 12 Apr 2013 at 11:09am<br /><br />About a quarter of the gas stations here in Central Mn carry hi-octane (90) ethanol-free gasoline.<br>It is used for "non-automobile" uses such as high-compression autos,&nbsp; ATVs, outboards, lawn equipment, etc. It generally costs about 10% more than 10-15% ethanol gas.&nbsp; So do an experiment...let your tow vehicle get low on fuel and fill up totally with the non-ethanol gas and record your odometer setting.&nbsp; Record the mileage when you are again nearly empty and refill with standard ethanol gas.&nbsp; Repeat and check your mpg...if you get a higher mpg percentage using non-ethanol than the higher percentage gas price, it is more economical to fill with the non-ethanol gas.<br>]]>
   <pubDate>Fri, 12 Apr 2013 11:09:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32225#32225</guid>
   <title>Non-Ethanol Gas : You noticed it big time...marine!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32224#32224</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1247" rel="nofollow">Burt</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 12 Apr 2013 at 10:41am<br /><br />You noticed it big time...marine!&nbsp; Sta-Bil does also make a marine formula which is meant for reducing or eliminating ethanol in gas.<br><br>It's a blue color not like the brown/yellow color.<br><br>I carry some of that when towing in case I can't find real gas.<br><br>Burt<br>]]>
   <pubDate>Fri, 12 Apr 2013 10:41:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32224#32224</guid>
   <title>Non-Ethanol Gas :    I guess that is another...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32223#32223</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1464" rel="nofollow">coopercdrkey</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 12 Apr 2013 at 10:32am<br /><br />I guess that is another advantage to living near the water-&nbsp; outboard motors do not do well at all on ethanol-laced gas.<div>&nbsp;</div><div>Even the convenience store here on the Key has a non-ethanol pump.&nbsp; Costs more, but at least it's available.</div>]]>
   <pubDate>Fri, 12 Apr 2013 10:32:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32223#32223</guid>
   <title>Non-Ethanol Gas :   We are positioned so we can...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32222#32222</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 12 Apr 2013 at 5:15am<br /><br />We are positioned so we can easily get to both, but we are in Fleet Farm country.&nbsp; I like em both too.&nbsp; Does Farm and Fleet have gas stations?]]>
   <pubDate>Fri, 12 Apr 2013 05:15:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32222#32222</guid>
   <title>Non-Ethanol Gas : Farm and Fleet by me. Those two...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32218#32218</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1173" rel="nofollow">Racer|X|</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 11 Apr 2013 at 10:41pm<br /><br />Farm and Fleet by me. &nbsp;Those two always crack me up. &nbsp;Greatest store on the planet though...I can spend hours in one. &nbsp;When the Zombie Apocolypse comes, I want to be near a FF, everything you need for survival. 😄]]>
   <pubDate>Thu, 11 Apr 2013 22:41:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32218#32218</guid>
   <title>Non-Ethanol Gas :   Fleet Farm gas stations normally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32213#32213</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 11 Apr 2013 at 9:21pm<br /><br />Fleet Farm gas stations normally have ethanol free gas.&nbsp; Check it out if you have one near,]]>
   <pubDate>Thu, 11 Apr 2013 21:21:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32213#32213</guid>
   <title>Non-Ethanol Gas : Ethanol sucks!!!! My Ford will...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32202#32202</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1173" rel="nofollow">Racer|X|</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 11 Apr 2013 at 7:56pm<br /><br />Ethanol sucks!!!! &nbsp;My Ford will get 22-23 MPG with real gas....down to 16-17 with ethanol (not towing).<div><br></div><div>Bad part is, living in farm country it is hard to find. &nbsp;Much more common and available in the "Up North" as we say in WI or the Northwoods.</div><div><br></div><div>X</div>]]>
   <pubDate>Thu, 11 Apr 2013 19:56:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32202#32202</guid>
   <title>Non-Ethanol Gas : I have been asked about Non-Ethanol...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32187#32187</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1247" rel="nofollow">Burt</a><br /><strong>Subject:</strong> 3389<br /><strong>Posted:</strong> 11 Apr 2013 at 3:02pm<br /><br />I have been asked about Non-Ethanol gas many times and found out that it does have more power per gallon than the corn fuel we are forced to buy.<br><br>Therefore, when you tow with a vehicle at or near capacity, Non-Ethanol will pull you around easier and even get better mileage.<br><br>Here is a website that will help you locate REAL GAS:<br><br>www.pure-gas.org<br><br>If you use a smart phone, it will give you directions, coordinates, addresses, etc....<br><br>Happy Towing<br><br>Burt<br>]]>
   <pubDate>Thu, 11 Apr 2013 15:02:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3389&amp;PID=32187#32187</guid>
