  <title>R-pod Owners Forum : Buick towing capacity</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Buick towing capacity</description>
  <pubDate>Wed, 28 Oct 2026 14:31:00 +0000</pubDate>
  <lastBuildDate>Mon, 29 Oct 2012 19:10:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3064</WebWizForums:feedURL>
   <title>Buick towing capacity :   Originally posted by DezIt...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29034#29034</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 29 Oct 2012 at 7:10pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Dez</strong></em><br /><br />It is a 2009. I contacted the dealer to confirm towing capacity.</td></tr></table><br><br>Please don't take this wrong, but "dealers" are in fact often, wrong.<br><br>Do you have an owners manual? If so turn to page 4-27. <br><br>If not follow<a href="http://www.buick.com/c&#111;ntent/dam/Buick/Global/master/nscwebsite/en/home/Owners/Vehicle_Manuals/01_Images/2009-Enclave-Owner-Manual.pdf" target="_blank"> this link</a>, and read page... 4-27. <br>]]>
   <pubDate>Mon, 29 Oct 2012 19:10:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29034#29034</guid>
   <title>Buick towing capacity : It is a 2009. I contacted the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29033#29033</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1547" rel="nofollow">Dez</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 29 Oct 2012 at 6:52pm<br /><br />It is a 2009. I contacted the dealer to confirm towing capacity.]]>
   <pubDate>Mon, 29 Oct 2012 18:52:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29033#29033</guid>
   <title>Buick towing capacity : What year is it? Everything I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29032#29032</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 29 Oct 2012 at 6:48pm<br /><br />What year is it? Everything I find says the towing capacity should be 2000 without "towing package" and 4500 with..]]>
   <pubDate>Mon, 29 Oct 2012 18:48:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29032#29032</guid>
   <title>Buick towing capacity :   Yup, you are all set. I highly...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29026#29026</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 29 Oct 2012 at 5:26pm<br /><br />Yup, you are all set. &nbsp;I highly recommend a WDH as Sean mentioned above, it will improve your ride quality.]]>
   <pubDate>Mon, 29 Oct 2012 17:26:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29026#29026</guid>
   <title>Buick towing capacity : Thanks - good to know. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29023#29023</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1547" rel="nofollow">Dez</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 29 Oct 2012 at 4:34pm<br /><br />Thanks - good to know.]]>
   <pubDate>Mon, 29 Oct 2012 16:34:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29023#29023</guid>
   <title>Buick towing capacity :   Originally posted by DezI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29020#29020</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1004" rel="nofollow">Seanl</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 29 Oct 2012 at 3:57pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Dez</strong></em><br /><br />I did a little more research and talked with my dealer and the horsepower is actually 288 hp. Towing capacity is 3500 lbs and tongue weight max is 400 lbs. I think this sounds OK for towing a 177 but wanted to get some opinions.<br><br>Thanks.<br><br>Dez</td></tr></table><div><br></div><div>That is a lot more power than my jeep and the tongue weight max is more than you need. You might find you need a Weight Distribution Hitch being that close to you max towing capacity but I don't think you will have any problems.&nbsp;</div>]]>
   <pubDate>Mon, 29 Oct 2012 15:57:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29020#29020</guid>
   <title>Buick towing capacity : I did a little more research and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29019#29019</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1547" rel="nofollow">Dez</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 29 Oct 2012 at 2:25pm<br /><br />I did a little more research and talked with my dealer and the horsepower is actually 288 hp. Towing capacity is 3500 lbs and tongue weight max is 400 lbs. I think this sounds OK for towing a 177 but wanted to get some opinions.<br /><br />Thanks.<br /><br />Dez]]>
   <pubDate>Mon, 29 Oct 2012 14:25:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29019#29019</guid>
   <title>Buick towing capacity : You are probably on the lower...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29000#29000</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 28 Oct 2012 at 7:20pm<br /><br />You are probably on the lower end of acceptable. &nbsp;My Sienna had 215 horsepower and we towed our pod from Maine to Florida - but those trips also showed me that it was underpowered to deal with strong headwinds even on flatlands.]]>
   <pubDate>Sun, 28 Oct 2012 19:20:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=29000#29000</guid>
   <title>Buick towing capacity : Towing capacity is 3500 . Hp is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=28985#28985</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1547" rel="nofollow">Dez</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 27 Oct 2012 at 5:10pm<br /><br />Towing capacity is 3500 . Hp is 240 v6 engine. Don't know torque.]]>
   <pubDate>Sat, 27 Oct 2012 17:10:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=28985#28985</guid>
   <title>Buick towing capacity : Welcome. What is the horsepower...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=28981#28981</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 27 Oct 2012 at 4:37pm<br /><br />Welcome. &nbsp;What is the horsepower and torque for your engine? &nbsp;What is the towing capacity?]]>
   <pubDate>Sat, 27 Oct 2012 16:37:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=28981#28981</guid>
   <title>Buick towing capacity : I have done all the research and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=28979#28979</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1547" rel="nofollow">Dez</a><br /><strong>Subject:</strong> 3064<br /><strong>Posted:</strong> 27 Oct 2012 at 4:27pm<br /><br />I have done all the research and decided an r pod is the perfect match for my wife and me and we are ready to purchase. We currently have a Buick Enclave and I believe this car can tow the r pod with no trouble. But, I have never seen an Enclave towing any type of trailer and that has me a little concerned.<br />Does anyone tow their r pod with a v6 Buick Enclave? Or maybe a GMC Acadia (also v6)? If yes, how does it perform?<br />Thanks,,<br />Dez]]>
   <pubDate>Sat, 27 Oct 2012 16:27:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3064&amp;PID=28979#28979</guid>
