  <title>R-pod Owners Forum : cooking biscuits</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Miscellaneous / Off-topic : cooking biscuits</description>
  <pubDate>Sat, 24 Oct 2026 19:48:07 +0000</pubDate>
  <lastBuildDate>Mon, 29 Oct 2012 20:23:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=3062</WebWizForums:feedURL>
   <title>cooking biscuits :   OK got that... IF we are not...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29039#29039</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 3062<br /><strong>Posted:</strong> 29 Oct 2012 at 8:23pm<br /><br />OK got that... IF we are not knee deep in snow i may get out at end of week and will really try this method. I have the cast iron trivit and even a mini-potpie tin would do the trick! I just love to find out ways to do some of the things with what I have!&nbsp;&nbsp; thank you for information.<div>hope wherever you are you are safe from the storm<img src="https://www.rpod-owners.com/smileys/smiley2.gif" height="18" width="18" border="0" alt="Wink" title="Wink" /></div>]]>
   <pubDate>Mon, 29 Oct 2012 20:23:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29039#29039</guid>
   <title>cooking biscuits : Correct, water would only steam...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29025#29025</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1442" rel="nofollow">P&M</a><br /><strong>Subject:</strong> 3062<br /><strong>Posted:</strong> 29 Oct 2012 at 5:16pm<br /><br />Correct, water would only steam them and then you'd have soggy biscuits.&nbsp; Ick.&nbsp; The pre-heating does cut down on the cook time and provides a little bit better level of overall heat circulation, but the key is to get the pan of biscuits off the bottom with a trivett or anything else that allows for an air pocket.&nbsp; It is the air that gets heated and circulates to cook the bisuits.]]>
   <pubDate>Mon, 29 Oct 2012 17:16:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29025#29025</guid>
   <title>cooking biscuits :   i plan to try it in a small...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29024#29024</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 3062<br /><strong>Posted:</strong> 29 Oct 2012 at 5:03pm<br /><br />i plan to try it in a small cast iron dutch oven with lid. the flame will not overheat the cast iron, I know I dry my cast iron by putting it over gas flame, but not for a long time. I guess by preheating all that cuts the cook time down some? If water is put in bottom that would only "steam" the biscuits, right?]]>
   <pubDate>Mon, 29 Oct 2012 17:03:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29024#29024</guid>
   <title>cooking biscuits : One way that I have done it in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29016#29016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1442" rel="nofollow">P&M</a><br /><strong>Subject:</strong> 3062<br /><strong>Posted:</strong> 29 Oct 2012 at 11:12am<br /><br />One way that I have done it in the past is to place a trivet inside on the bottom of the dutch oven, and then put the biscuits in a disposable aluminum pan that will fit inside and put the lid on it.&nbsp; By raising it up and off of the bottom you create a mini-oven environment that helps to keep the biscuits from burning on the bottom.&nbsp; Preheat it so that it is hot inside the "oven" before putting the biscuits in, and keep checking until they are done.]]>
   <pubDate>Mon, 29 Oct 2012 11:12:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=29016#29016</guid>
   <title>cooking biscuits :   I posted a question in cooking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=28965#28965</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 3062<br /><strong>Posted:</strong> 26 Oct 2012 at 7:20pm<br /><br />I posted a question in cooking with gas, but might not get found there.<div>&nbsp;</div><div>If anyone knows how to do biscuits in a small cast iron dutch oven with lid, using the stove eye inside the Pod, would you please share the info with me. </div><div>The flame only goes down so much and I have heard you actually kind of saute the biscuits. how to keep from burning, using one of the cast iron grids used on gas stoves inside house??? </div><div>I am not building a fire outside OR taking a propane stove and little oven..</div><div>only thing other than that might be my little propane "campfire" and someplace I have one of the fold out ovens. But this is getting pretty much to do if the weather is really cold out!</div><div>&nbsp;</div><div>Thanks ahead if any one knows how to or Has suggestions on how too!</div>]]>
   <pubDate>Fri, 26 Oct 2012 19:20:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=3062&amp;PID=28965#28965</guid>
