  <title>R-pod Owners Forum : 172 Improvements Made (pics)</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : 172 Improvements Made (pics)</description>
  <pubDate>Sat, 24 Oct 2026 00:01:59 +0000</pubDate>
  <lastBuildDate>Sun, 26 Jul 2009 11:08:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=298</WebWizForums:feedURL>
   <title>172 Improvements Made (pics) : With the back up camera on our...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2117#2117</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=204" rel="nofollow">Tusten Traveler</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 26 Jul 2009 at 11:08am<br /><br />With the back up camera on our SUV it made "docking" the rpod to the hitch a breeze. I highly recommend getting one as an add-on and then having the portability to use it while camping to see the front of the camper is an excellent idea.<DIV>&nbsp;</DIV><DIV>We also would love to put at least a porthole size window above the sink in the 174. I know John will be looking into doing it, so will let all know.</DIV>]]>
   <pubDate>Sun, 26 Jul 2009 11:08:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2117#2117</guid>
   <title>172 Improvements Made (pics) : I was looking for one of those...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2110#2110</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 25 Jul 2009 at 8:26pm<br /><br />I was looking for one of those back up cameras today - thought about adding one of those up front so I can see whats happening up there while camped and/or parked at a walmart or rest area?  Sams had just sold their last one and Cosco did not have any - anyone know of a source and cost????]]>
   <pubDate>Sat, 25 Jul 2009 20:26:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2110#2110</guid>
   <title>172 Improvements Made (pics) : It depends on how close the studs...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2107#2107</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 25 Jul 2009 at 12:53pm<br /><br />&nbsp;&nbsp;&nbsp;&nbsp; It depends on how close the studs are and the size window. You may have enough space between the studs for a small port hole style window. Thats why I thought it would be good to call Forest River to find out the spacing between the studs.&nbsp;&nbsp;&nbsp;&nbsp; David]]>
   <pubDate>Sat, 25 Jul 2009 12:53:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2107#2107</guid>
   <title>172 Improvements Made (pics) : The window addition could be done...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2102#2102</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 25 Jul 2009 at 9:42am<br /><br />The window addition could be done but it would be expensive.&nbsp; You would have to cut the aluminum studs and weld in a cross member above and below the window.&nbsp; That would mean removing more of the outside fiberglass and the inside paneling.&nbsp; So you would have a mismatch when you finished off the window.<br><br>I have the 175 with the sink in the front end.&nbsp; I thought there should be a window there also.&nbsp; For one thing you can't see if someone walks into your lot from the front.&nbsp; I can see out the back and both sides but not the front.<br><br>Terry<br>]]>
   <pubDate>Sat, 25 Jul 2009 09:42:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2102#2102</guid>
   <title>172 Improvements Made (pics) : Charlene , I have a 171 and removed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2101#2101</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 25 Jul 2009 at 8:56am<br /><br />&nbsp;&nbsp;&nbsp; Charlene , I have a 171 and removed a window to do repairs. The window opening has wood around the edges for support to the sidewalls. You would have to remove the foam insulation between the side walls and replace with wood for strength. The problem you will proably have, I am not sure of is the aluminum frame. If you have to cut that , not sure of the strength and integrity of the trailer that would be lost.&nbsp;A call to Forest River would proably be best.&nbsp;&nbsp;&nbsp; David]]>
   <pubDate>Sat, 25 Jul 2009 08:56:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2101#2101</guid>
   <title>172 Improvements Made (pics) : I, too, would be interested in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2094#2094</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 25 Jul 2009 at 1:52am<br /><br />I, too, would be interested in hearing about adding windows. The 172 is awfully dark up front. We need more light. I have no idea if this is a difficult modification. My husband would be doing the work and is pretty handy, but we're wondering if there are issues about which we should be aware before cutting into the side of the unit.<br><br>charlene<br>]]>
   <pubDate>Sat, 25 Jul 2009 01:52:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=2094#2094</guid>
   <title>172 Improvements Made (pics) : These are all great ideas. We...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=1968#1968</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 20 Jul 2009 at 11:34am<br /><br />These are all great ideas. We also made a prop stick for the bunk storage. I am using plastic trays I got from WalMart years ago to cover the stove top. Turned upside down they work great for added counter space. Do you find that cutting off the storage door under the seat cushion weakens the bed support any? Also, what kind of suction cups are you using for the rdome? We tried with velcro, but the cloth side has to be sewn and the other side is kind of ugly stuck on the side. <DIV>&nbsp;</DIV><DIV>We want to add the stablizers. Which kind did you get and how much to install? </DIV><DIV>&nbsp;</DIV><DIV>One thing we would like on our 172 are a couple more windows. I would like to have two windows that will open over the bunks. We thought even little porthole type windows might be cute. Have you heard of anyone adding windows?</DIV>]]>
   <pubDate>Mon, 20 Jul 2009 11:34:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=1968#1968</guid>
   <title>172 Improvements Made (pics) : Here&amp;#039;s some of the changes...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=1899#1899</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=140" rel="nofollow">HuronSailor</a><br /><strong>Subject:</strong> 298<br /><strong>Posted:</strong> 17 Jul 2009 at 7:35am<br /><br /><P align=center>Here's some of the changes we've made so far:</P><DIV align=center>1) Made a cover for the stovetop for more counter space. The top is ceramic tiles with cork around the perimeter. &nbsp;If you turn it over it doubles as a serving tray.</DIV><DIV align=center>&nbsp;</DIV><DIV align=center><img src="http://www.rpodnati&#111;n.com/uploads/140/Rpod_Improvements__01_sm.jpg" height="350" width="500" border="0" /></DIV><DIV>&nbsp;</DIV><DIV align=center>2) Drilled a finger hole and made a prop rod for the lower bunk storage area:</DIV><P align=center><img src="http://www.rpodnati&#111;n.com/uploads/140/Rpod_Improvements__02_sm.jpg" height="500" width="350" border="0" /></P><DIV>&nbsp;</DIV><DIV align=center>3) Added a bungee cord around the TV to keep the screen secure during travel:</DIV><DIV align=center>&nbsp;</DIV><DIV align=center><img src="http://www.rpodnati&#111;n.com/uploads/140/Rpod_Improvements__03_sm.jpg" height="350" width="500" border="0" /></DIV><DIV align=center>&nbsp;</DIV><DIV align=center>4) Couldn't open the dinette storage compartement easily as the back cushion overlapped the storage compartment cover. Cut off the compartment cover so it would bypass the cushion.</DIV><DIV align=center>&nbsp;</DIV><DIV align=center><img src="http://www.rpodnati&#111;n.com/uploads/140/Rpod_Improvements__05_sm.jpg" height="350" width="500" border="0" /></DIV><DIV align=center></DIV><DIV align=center>&nbsp;</DIV><DIV align=center>6) Found a perfect little stool for easier access to the top bunk.</DIV><DIV align=center>&nbsp;</DIV><P align=center><img src="http://www.rpodnati&#111;n.com/uploads/140/Rpod_Improvements__06_sm.jpg" height="350" width="500" border="0" /></P><DIV align=center></DIV><DIV align=center></DIV><P align=center>7) A wireless indoor/outdoor thermometer lets you keep closer tabs on the fridge temp.</P><DIV align=center>&nbsp;</DIV><DIV align=center><img src="http://www.rpodnati&#111;n.com/uploads/140/Rpod_Improvements__08_sm.jpg" height="350" width="500" border="0" /></DIV><DIV align=center>&nbsp;</DIV><DIV align=center>Other stuff:&nbsp;added a second set of stabilizing jacks to the front of the Rpod, bought suction cup hooks to hang wet jackets on just outside the door, use suction cups to hold the Rdome flaps to the side of the Rpod rather than drilling into the side.</DIV>]]>
   <pubDate>Fri, 17 Jul 2009 07:35:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=298&amp;PID=1899#1899</guid>
