  <title>R-pod Owners Forum : A/C - D/C Converter Problems</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : A/C - D/C Converter Problems</description>
  <pubDate>Wed, 23 Sep 2026 07:25:50 +0000</pubDate>
  <lastBuildDate>Tue, 08 Jan 2013 22:10:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=2883</WebWizForums:feedURL>
   <title>A/C - D/C Converter Problems : Yes, and yes. :-)   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=30140#30140</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 08 Jan 2013 at 10:10pm<br /><br />Yes, and yes. &nbsp;:-)]]>
   <pubDate>Tue, 08 Jan 2013 22:10:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=30140#30140</guid>
   <title>A/C - D/C Converter Problems : Does a 3-stage charger allow you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=30129#30129</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1609" rel="nofollow">ReddOrion</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 08 Jan 2013 at 4:32pm<br /><br />Does a 3-stage charger allow you to stay connected to shore power for long periods without boiling your batteries dry?<div><br></div><div>I am assuming that the chargers would be more/less the same from year to year and model to model. Is this correct?&nbsp;</div>]]>
   <pubDate>Tue, 08 Jan 2013 16:32:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=30129#30129</guid>
   <title>A/C - D/C Converter Problems : Yes, it has a good 3-stage battery...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27298#27298</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 30 Aug 2012 at 12:36pm<br /><br /><P>Yes, it has a good 3-stage battery charger.</P>]]>
   <pubDate>Thu, 30 Aug 2012 12:36:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27298#27298</guid>
   <title>A/C - D/C Converter Problems :   I forgot to ask. is the battery...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27294#27294</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1023" rel="nofollow">The Principal</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 30 Aug 2012 at 10:26am<br /><br />I forgot to ask. is the battery charger built into the converter?]]>
   <pubDate>Thu, 30 Aug 2012 10:26:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27294#27294</guid>
   <title>A/C - D/C Converter Problems :    </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27293#27293</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1023" rel="nofollow">The Principal</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 30 Aug 2012 at 10:25am<br /><br />]]>
   <pubDate>Thu, 30 Aug 2012 10:25:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27293#27293</guid>
   <title>A/C - D/C Converter Problems :   Thank Seanl , Headed out to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27291#27291</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1023" rel="nofollow">The Principal</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 30 Aug 2012 at 10:08am<br /><br />Thank Seanl , Headed out to look right now.]]>
   <pubDate>Thu, 30 Aug 2012 10:08:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27291#27291</guid>
   <title>A/C - D/C Converter Problems : It is under the fuse panel. If...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27289#27289</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1004" rel="nofollow">Seanl</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 30 Aug 2012 at 9:33am<br /><br />It is under the fuse panel. If you take the front&nbsp;panel&nbsp;off the fuse panel the Converter is in the area under the breakers and fuses. It at the front of the 176 in front of the bunks by the floor I think.&nbsp;&nbsp;]]>
   <pubDate>Thu, 30 Aug 2012 09:33:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27289#27289</guid>
   <title>A/C - D/C Converter Problems :   Can anyone tell me where the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27287#27287</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1023" rel="nofollow">The Principal</a><br /><strong>Subject:</strong> 2883<br /><strong>Posted:</strong> 30 Aug 2012 at 9:21am<br /><br />Can anyone tell me where the Electric Converter is located on a R-176.<div>&nbsp;</div><div>Paul</div><div>The Principal</div>]]>
   <pubDate>Thu, 30 Aug 2012 09:21:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2883&amp;PID=27287#27287</guid>
