  <title>R-pod Owners Forum : Generator</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Generator</description>
  <pubDate>Wed, 23 Sep 2026 15:35:24 +0000</pubDate>
  <lastBuildDate>Thu, 21 Jun 2012 10:29:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=2663</WebWizForums:feedURL>
   <title>Generator : With only a 1000 watt load it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25477#25477</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 21 Jun 2012 at 10:29am<br /><br />With only a 1000 watt load it should be fine on one genset, running.&nbsp; The capacitor just might allow it to start on one as well - but the eco setting may have to be turned off so it has enough momentum to get through the surge.]]>
   <pubDate>Thu, 21 Jun 2012 10:29:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25477#25477</guid>
   <title>Generator : I got my big ladder out and changed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25467#25467</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 20 Jun 2012 at 10:30pm<br /><br />I got my big ladder out and changed the fan cover to the clear one.&nbsp; Easy.&nbsp; Then I extended myself from the ladder and took out the four screws that hold to cover for the A/C.&nbsp; Found the box with the cap but did not want to stand on the unreinforced roof.&nbsp; Found a dealer who will install in for a reasonable price next week.&nbsp; Will then try and run it with only one Honda 2 KW.&nbsp; We'll see.&nbsp; Safe Travels.]]>
   <pubDate>Wed, 20 Jun 2012 22:30:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25467#25467</guid>
   <title>Generator :   Originally posted by PugPod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25463#25463</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1273" rel="nofollow">elko.mike</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 20 Jun 2012 at 8:46pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by PugPod</strong></em><br /><br />&nbsp; Now I am going to find a temperature alarm that will dial my phone when temp is out of range. There could be times on normal power that we could be in the show ring with 1 dog and the others in the cool Pod when power magically disappears.&nbsp; Doesn't take long for the heat to really knock down a Pug. Will post photos of the PugPod &amp; pugs next time we are out.<div>Cheers</div></td></tr></table><br>Here's a place to start http://www.tempulog.com/.&nbsp; Let us know what you find.<br><br>It was mentioned on this forum that a 2KW system will run the A/C but it won't start it due to the surge.&nbsp; It would be worth a test to see if the A/C will stay on even if one of the generators stops.&nbsp; It might, which would give you a little more margin.&nbsp; That's not a replacement for the monitor, but rather a little extra insurance against using it should it work.<br>]]>
   <pubDate>Wed, 20 Jun 2012 20:46:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25463#25463</guid>
   <title>Generator :   Thanks for all the great info...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25462#25462</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1169" rel="nofollow">PugPod</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 20 Jun 2012 at 7:00pm<br /><br />Thanks for all the great info &amp; suggestions.... The 3 pugs read all the notes and talked me into the Honda EU2000i with the companion plus parallel wiring kit. Picking them up in Milwaukee this weekend.&nbsp;Now I am going to find a temperature alarm that will dial my phone when temp is out of range. There could be times on normal power that we could be in the show ring with 1 dog and the others in the cool Pod when power magically disappears.&nbsp; Doesn't take long for the heat to really knock down a Pug. Will post photos of the PugPod &amp; pugs next time we are out.<div>Cheers</div>]]>
   <pubDate>Wed, 20 Jun 2012 19:00:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25462#25462</guid>
   <title>Generator :   Originally posted by HuronSailorAsk...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25381#25381</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1273" rel="nofollow">elko.mike</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 18 Jun 2012 at 2:09pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by HuronSailor</strong></em><br /><br />Ask three rPodders about gensets and you'll get four opinions.&nbsp;<div><br></div><div><br></div></td></tr></table><br>On a day of harmony.<br>]]>
   <pubDate>Mon, 18 Jun 2012 14:09:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25381#25381</guid>
   <title>Generator : Ask three rPodders about gensets...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25379#25379</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=140" rel="nofollow">HuronSailor</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 18 Jun 2012 at 1:55pm<br /><br />Ask three rPodders about gensets and you'll get four opinions.&nbsp;<div><br></div><div><br></div>]]>
   <pubDate>Mon, 18 Jun 2012 13:55:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25379#25379</guid>
   <title>Generator :   Well, David, I gotta admit...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25299#25299</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 15 Jun 2012 at 11:16am<br /><br />Well, David, I gotta admit that you've got me there. As the&nbsp;PTA showers (think body parts) in our Pods are kinda weak, so you probably smell much better than I after camping.]]>
   <pubDate>Fri, 15 Jun 2012 11:16:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25299#25299</guid>
   <title>Generator : Well, I like the Pods enough to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25297#25297</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 15 Jun 2012 at 8:42am<br /><br />Well, I like the Pods enough to have&nbsp;shelled out 5 figures for an RP173, back in July of 2009.&nbsp; Also, I can get quite a number of folks who would line up to testify that "yes, he truely is weird".<DIV>&nbsp;</DIV><DIV>But alas, the lure of a dry bath and awning seduced me into a "regular" TT.&nbsp; Interestingly, my camper is within 2-3 inches lenght-wise of the Pods.&nbsp; Width - the actual body is a few inches wider, at 7' (84") but, the "track" -&nbsp;width between the wheels is more narrow.&nbsp;&nbsp;&nbsp;</DIV>]]>
   <pubDate>Fri, 15 Jun 2012 08:42:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25297#25297</guid>
   <title>Generator :   Ford? Chevy? Honda? Champion?...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25290#25290</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 8:41pm<br /><br />Ford? Chevy? Honda? Champion? Hey, I don't agree with any of ya. I tow with a Toyota Tundra, have a Yamaha generator, and&nbsp;I'm super satisfied with both. But let's face it. We're all just a little different or we wouldn't be towing our Pods. Except for maybe folks like David who've&nbsp;kinda&nbsp;come to their senses and jumped ship. No offense, David, as you have a great looking towing combo, but kinda mainsteam for some of us weird Podophiles,&nbsp;heh, heh!&nbsp;]]>
   <pubDate>Thu, 14 Jun 2012 20:41:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25290#25290</guid>
   <title>Generator : For the record, I&amp;#039;m a Chevy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25286#25286</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 6:33pm<br /><br />For the record, I'm a Chevy guy.&nbsp; Safe Travels]]>
   <pubDate>Thu, 14 Jun 2012 18:33:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25286#25286</guid>
   <title>Generator :     I should probably add,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25281#25281</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 5:46pm<br /><br />I should probably add, as a reminder, that everyone is entitled to their opinion and that is what you get here......a lot of different opinions.&nbsp; It's up to the readers to sift through all of this and then come to their own conclusion/decision.&nbsp;&nbsp; Every post is an opinion.&nbsp; Every post is valuable!&nbsp; <div>&nbsp;</div><div>For example - One guy might think Ford trucks are best.&nbsp; I think Chevys are best.&nbsp; He's happy with his Ford.&nbsp; I am happy with my Chevy.&nbsp; When all is said and done, that's all that really matters - that each is satisfied within themselves.&nbsp; The&nbsp;<em>right</em> choice in most matters is the choice that is right for YOU in YOUR situation.&nbsp; <img src="https://www.rpod-owners.com/smileys/smiley1.gif" height="18" width="18" border="0" alt="Smile" title="Smile" /></div>]]>
   <pubDate>Thu, 14 Jun 2012 17:46:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25281#25281</guid>
   <title>Generator :   Originally posted by SeanlIsn&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25280#25280</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 5:35pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Seanl</strong></em><br /><br /><img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" />&nbsp;Isn't it funny how some topics bring out a lot of opinions. &nbsp;</td></tr></table><div>&nbsp;</div><div>YES! <img src="https://www.rpod-owners.com/smileys/smiley36.gif" height="18" width="18" border="0" alt="LOL" title="LOL" /></div><div>&nbsp;</div><div>Just mention anything electrical, hitches or towing and you'll get lot's of participation!</div>]]>
   <pubDate>Thu, 14 Jun 2012 17:35:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25280#25280</guid>
   <title>Generator :   Originally posted by dsmithsSeanl,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25277#25277</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1004" rel="nofollow">Seanl</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 3:52pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by dsmiths</strong></em><br /><br />Seanl, sounds like that Champion is a good all around deal, Donna and I dont usually dry camp, but I have a 5500/6875 surge Generac, but I dont think thats to practical to take with us. Be careful shrouding your gen set, the alternator and engine are air cooled, maybe you could come up with something that is circular and the top is open, that way it would dampen sound going out at ear level but keep the air flow moving, just a thought, safe travels all.  <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" align="middle" /></td></tr></table><div><br></div><div>Thanks for the info. One of the reasons my wife and I did not want to spend lot of money on a generator was we only need it about one week a year when we go to the Nascar races and the rest of the time we camp at parks with hookups. The Generator Tent is designed with with ventilation. The top opens up and so do both ends if you need it for exhaust and air intake. also the bottom walls of the tent are 4 inches off the ground so that it will draw cooler air in from the bottom and out through the top like a chimney.&nbsp;<br></div>]]>
   <pubDate>Thu, 14 Jun 2012 15:52:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25277#25277</guid>
   <title>Generator : Seanl, sounds like that Champion...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25275#25275</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1034" rel="nofollow">dsmiths</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 3:23pm<br /><br />Seanl, sounds like that Champion is a good all around deal, Donna and I dont usually dry camp, but I have a 5500/6875 surge Generac, but I dont think thats to practical to take with us. Be careful shrouding your gen set, the alternator and engine are air cooled, maybe you could come up with something that is circular and the top is open, that way it would dampen sound going out at ear level but keep the air flow moving, just a thought, safe travels all.  <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" align="middle" /> ]]>
   <pubDate>Thu, 14 Jun 2012 15:23:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25275#25275</guid>
   <title>Generator :   Originally posted by Camper...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25274#25274</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1004" rel="nofollow">Seanl</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 2:05pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Camper Bob</strong></em><br /><br />Does the Champion have the inverter electronics to safely run tv's, computers, etc?&nbsp; That may be why they are so much cheaper.&nbsp; Additionally, can't easily lift 100 lbs now.&nbsp; That would be a major stumbling block for me.&nbsp; Bought the Honda, no regrets.&nbsp; Light, quiet, and will run sensitive electronics.&nbsp; Safe Travels.</td></tr></table><div><br></div><div>I will give you quiet and light but the part about sensitive electronics not so much. Inverter Generators are less noisy which means they will run audio and video equipment with less aritfacts but computers don't care. Computer power supplys will work with anything from 100 volts to 240 volts AC and filter it to within an inch of their lives. There is nothing more robust than a computer power supply. There is very little &nbsp;danger of damaging sensitive electronics only in introducing hiss to audio and snow to video. Having said that I ran my TV and Radio in the Pod and it was dead clean.&nbsp;</div><div><br></div><div>Have fun with the Honda It really was my first choice just not in the budget and any of the budget inverter generators really are junk as far as I can tell.&nbsp;</div>]]>
   <pubDate>Thu, 14 Jun 2012 14:05:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25274#25274</guid>
   <title>Generator : Does the Champion have the inverter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25272#25272</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 11:35am<br /><br />Does the Champion have the inverter electronics to safely run tv's, computers, etc?&nbsp; That may be why they are so much cheaper.&nbsp; Additionally, can't easily lift 100 lbs now.&nbsp; That would be a major stumbling block for me.&nbsp; Bought the Honda, no regrets.&nbsp; Light, quiet, and will run sensitive electronics.&nbsp; Safe Travels.]]>
   <pubDate>Thu, 14 Jun 2012 11:35:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25272#25272</guid>
   <title>Generator :   Originally posted by Keith-N-DarMy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25271#25271</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1004" rel="nofollow">Seanl</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 10:40am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Keith-N-Dar</strong></em><br /><br />My Champion has nearly 50 hours on it (0 hours camping sadly) and starts easily, runs fine, and uses no where near as much gas as wagnert's buddy's Generator does.&nbsp; You can hold a conversation right next to it while running, but it is louder than a Honda.&nbsp; But even the Hondas shut down during quiet time in the campground.&nbsp; I think it is a good value. YMMV</td></tr></table><div><br></div><div>Mine is brand new just has 5 hours of break in time on it and at 58 Db really quite for the price and as for easy starting mine has the electric start so I just push a button<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />. &nbsp;</div><div><br></div><div><br></div><div><img src="uploads/1004/961741c.jpg" height="298" width="298" border="0" /></div><div><br></div><div><br></div><div>I am getting a small tent type device made with sound deadening material put put over it to cut the sound even more and eventually I am going to get a tri fuel conversion kit for it so it will run on propane. Earlier I said that it was 3500 watts but it is only 3000 running watts and 4000 surge. More than enough for everything on the Rpod.&nbsp;</div><div><br></div><div>The Motor is a blueprint level copy of the Honda GX200 engine. I am really happy with it so far. Its only downside is the weight but I don't think that you can get 3000 watts much lighter. I could save a little by taking out the battery and using the Pod's battery to start it but I don't want to do that just yet. I also took the wheels off mine so that I can get it on a rack I put on the tongue of the trailer.&nbsp;</div>]]>
   <pubDate>Thu, 14 Jun 2012 10:40:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25271#25271</guid>
   <title>Generator : My Champion has nearly 50 hours...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25270#25270</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 9:40am<br /><br />My Champion has nearly 50 hours on it (0 hours camping sadly) and starts easily, runs fine, and uses no where near as much gas as wagnert's buddy's Generator does.&nbsp; You can hold a conversation right next to it while running, but it is louder than a Honda.&nbsp; But even the Hondas shut down during quiet time in the campground.&nbsp; I think it is a good value. YMMV]]>
   <pubDate>Thu, 14 Jun 2012 09:40:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25270#25270</guid>
   <title>Generator : Isn&amp;#039;t it funny how some topics...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25269#25269</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1004" rel="nofollow">Seanl</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 14 Jun 2012 at 8:52am<br /><br /><img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" />&nbsp;Isn't it funny how some topics bring out a lot of opinions. I Think any of these solutions will work you just have to find the one that is right for you. As for the Champion that broke the first night. I guess that can happen but from the reviews I have read that is not typical.<div><br></div><div>I think that the Champion is the best bang for the buck in its class but would concede that the Honda and the Yamha generators are in a whole different class. &nbsp;</div>]]>
   <pubDate>Thu, 14 Jun 2012 08:52:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25269#25269</guid>
   <title>Generator : I use 2 Honda 2000ius together...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25265#25265</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1003" rel="nofollow">sfish</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 11:17pm<br /><br />I use 2 Honda 2000ius together and dont always need both but they are fuel efficient ,quiet&nbsp; easy to start light weight.My camping &nbsp;buddy bought a champion 3500 and the muffler broke off the first night and even after fixing that had fuel shut off problems and it was still noizy. You get what you pay for.]]>
   <pubDate>Wed, 13 Jun 2012 23:17:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25265#25265</guid>
   <title>Generator : I have a Honda 2000. Have had...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25263#25263</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1094" rel="nofollow">wagnert</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 10:48pm<br /><br />I have a Honda 2000. Have had it for several years and it has gotten us through some long home power outages (6 days, 5 days, etc.).<br>It's a great unit.<br>During one of the 6 day outages here in western WA state, (trees often fall on&nbsp; power lines) my friend bought a generator for much less money. Problem is he had to go for gasoline every day. At first no gas stations had power. My little rascal runs 10-12 hours on a one gallon fill. His used 5-7 gal/day.<br>Other factors: <br>The power is "clean." No concern of it surging and blowing electronics. No spikes.<br>It automatically adjusts to power needs, slows when full generation is not needed.<br>It is very quiet. Decibel chart compares it to the volume of normal speech.<br>It is small, about the size of two briefcases side to side.<br>Excellent unit! Very happy with it.<br><br>Tom Wagner<br>R-Pod 177<br>2003 Toyota Sienna<br>]]>
   <pubDate>Wed, 13 Jun 2012 22:48:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25263#25263</guid>
   <title>Generator : Not so for all non-inverter gensets....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25257#25257</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=920" rel="nofollow">ka9nyn</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 9:46pm<br /><br />Not so for all non-inverter gensets. My Generac 5500 senses load and when no load, idles down. Rolls back up to full speed when reloaded.<DIV>&nbsp;</DIV><DIV>Also, remember surge&nbsp; capability of the genset plays a role, as starting current for AC motors is many times running current, although for a very short time.</DIV><DIV>&nbsp;</DIV><DIV>My 2 cents.</DIV>]]>
   <pubDate>Wed, 13 Jun 2012 21:46:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25257#25257</guid>
   <title>Generator : http://www.consumersearch.com/...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25252#25252</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1273" rel="nofollow">elko.mike</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 8:10pm<br /><br />http://www.consumersearch.com/portable-generators/yamaha-ef2000is another set of reviews for what it is worth.<br><br>]]>
   <pubDate>Wed, 13 Jun 2012 20:10:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25252#25252</guid>
   <title>Generator :   Thanks Outbound! I was thinking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25251#25251</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 8:04pm<br /><br />Thanks Outbound!&nbsp; I was thinking of a few of your previous posts while waiting of Dixie.&nbsp; What is the approx. cost of the Yamaha?]]>
   <pubDate>Wed, 13 Jun 2012 20:04:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25251#25251</guid>
   <title>Generator :    Sorry, Dixie needed to go...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25249#25249</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 7:57pm<br /><br />Sorry, Dixie needed to go outside.&nbsp; So.....<div>&nbsp;</div><div>To answer the original question, it's hard to argue the quality of Honda.&nbsp; However, the Champion seems to be a good "value"....if they have something in the 2500watt or better range, it could run the AC without the capacitor mod and possible cost less than the others. (?).</div><div>&nbsp;</div><div>As with everything I post......IMHO.&nbsp; <img src="https://www.rpod-owners.com/smileys/smiley1.gif" height="18" width="18" border="0" alt="Smile" title="Smile" /></div>]]>
   <pubDate>Wed, 13 Jun 2012 19:57:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25249#25249</guid>
   <title>Generator :  The Yamaha EF2400iSHCis the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25246#25246</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=418" rel="nofollow">Outbound</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 7:52pm<br /><br />The <a href="http://www.yamaha-motor.ca/products/products.php?model=3547&amp;class=33&amp;group=G|&amp;LANG=en" target="_blank">Yamaha EF2400iSHC</a>&nbsp;is the one you want. &nbsp;It'll run your A/C or microwave without problem, its relatively small &amp; light, its quiet, and its dead reliable.]]>
   <pubDate>Wed, 13 Jun 2012 19:52:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25246#25246</guid>
   <title>Generator :   If you are interested, in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25245#25245</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 7:17pm<br /><br />If you are interested, in the June issue of QST (ARRL Ham Radio magazine), their test engineer compared 4 - 2000watt generators:<div>Champion 73536i</div><div>Generac iX2000i</div><div>Honda EU2000i</div><div>Yamaha EF 2000is</div><div>&nbsp;</div><div>I can't reprint/publish the article without their permission and it is not available on their web site unless you are an ARRL member.&nbsp; While they looked at a lot of parameters; load test, fuel economy, waveform, no load to full load test, etc. I can give you my "take" on what the article revealed that might be of interests to campers (in contrast to radio geeks).</div><div>&nbsp;</div><div>In short, the Generac performed the worst of the bunch in just about every way.&nbsp; Suggested retail $589</div><div>&nbsp;</div><div>The Yamaha and Champion, I would say, tied for second place.&nbsp; The main difference was - when a 2000watt load was placed on each, the Champion shut down in one minute, the Yamaha shut down in 20 seconds.&nbsp; Sound levels were about identical.&nbsp; Champion - $599, Yamaha - $990</div><div>&nbsp;</div><div>The Honda won out overall.&nbsp; The sounds levels were about the same as the above two.&nbsp; The big difference was the Honda, when placed under a 2000watt load was still running after 30 minutes and showed no signs of overheating or other complaints.&nbsp; It's no load to full load response time was the best.&nbsp; Output voltage was a bit high @ 127vac with a 100watt load.&nbsp; Price - $899</div><div>&nbsp;</div><div>&nbsp;</div>]]>
   <pubDate>Wed, 13 Jun 2012 19:17:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25245#25245</guid>
   <title>Generator : All true, which is why my home...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25243#25243</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 6:55pm<br /><br />All true, which is why my home generator uses propane.  Also hooked up my grill to the same tank, no more filling up small tanks and running out half way through a steak!<br><br>]]>
   <pubDate>Wed, 13 Jun 2012 18:55:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25243#25243</guid>
   <title>Generator :    I looked at the Yamaha generators...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25241#25241</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=648" rel="nofollow">Goose</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 6:27pm<br /><br />&nbsp;&nbsp; I looked at the Yamaha generators that have the tri-fuel set up, they run on gas, propane and natural gas. If I was to go the route of adding a genset I think that it would be worth the time and money to put a quick connect on the line from the propane tank and run it to the genset, I am not big on carrying a gas can on the trip.<div>&nbsp; There are a lot of up-sides to the propane generators, the carbs will not foul on propane and a tank of propane will not go bad over time.&nbsp;They cost about the same as a Honda and claim to be as quiet.&nbsp;&nbsp; Goose</div>]]>
   <pubDate>Wed, 13 Jun 2012 18:27:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25241#25241</guid>
   <title>Generator : Well after reading &amp;#034;hard...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25231#25231</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2663<br /><strong>Posted:</strong> 13 Jun 2012 at 4:07pm<br /><br />Well after reading "hard start" on Google.&nbsp; I purchased a larger starting capacitor for the A/C.&nbsp; Called Dometic for some help but they were worthless.&nbsp; In any event, will add it next week and see if it works.&nbsp; Have to take the A/C shroud on the roof off to access the replaceable part.&nbsp; Safe Travels.]]>
   <pubDate>Wed, 13 Jun 2012 16:07:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2663&amp;PID=25231#25231</guid>
