  <title>R-pod Owners Forum : Introduction</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Introduction</description>
  <pubDate>Wed, 23 Sep 2026 16:06:40 +0000</pubDate>
  <lastBuildDate>Mon, 14 May 2012 13:02:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=2538</WebWizForums:feedURL>
   <title>Introduction : kayak - as already stated, no...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24229#24229</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 14 May 2012 at 1:02pm<br /><br />kayak - as already stated, no dumb questions exist here.&nbsp; If you are handy with a voltmeter you can obtain the pinout of the Bargman connector online and test to see if you already have +12 between the + and - pins.&nbsp; If you don't at first try starting the vehicle, some vehicles&nbsp;switch that off to prevent a dead battery.]]>
   <pubDate>Mon, 14 May 2012 13:02:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24229#24229</guid>
   <title>Introduction : Don&amp;#039;t assume your tv is charging...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24219#24219</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 14 May 2012 at 10:25am<br /><br />Don't assume your tv is charging the pods battery just because of a factory bargman connector. A towing package may or may not be set up from the factory to charge a trailer battery. On our Expedition, with factory tow package, the hitch and connector were installed, but, in a seperate bag in the truck were the brake controller interface connection, and a fuse and relay that needed to be installed, in order for the truck to charge the trailer's battery.]]>
   <pubDate>Mon, 14 May 2012 10:25:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24219#24219</guid>
   <title>Introduction :   WELCOME ROY THERE IS NO DUMB...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24212#24212</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1010" rel="nofollow">rex</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 14 May 2012 at 1:46am<br /><br />WELCOME ROY THERE IS NO DUMB QUESTIONS THIS FORAM HAS HELPED ME SO MUCH LIKE YOU THIS WAS NEW TO ME I STILL RUN INTO PROBLEMS BUT I KEEP DIGGING INTO THE OLD POSTS AND CAN USUALLY FIND AN ANSWER. HAPPY TRAILS TO YOU rex pHp stuart fla.]]>
   <pubDate>Mon, 14 May 2012 01:46:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24212#24212</guid>
   <title>Introduction : Thanks very much, Ds.  I should...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24211#24211</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1245" rel="nofollow">KayakkrazyUP</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 13 May 2012 at 11:01pm<br /><br />Thanks very much, Ds.  I should be fine.  The pod is in the shop for a toilet fix so I haven't had much opportunity to check it out.  <br />The tv, a 2012 Jeep Grand Cherokee, has the factory installed 6-pin connection so I assume it will charge the pod battery.<br /><br />Thanks again.<br /><br />Roy]]>
   <pubDate>Sun, 13 May 2012 23:01:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24211#24211</guid>
   <title>Introduction : Roy, some tow vehicles (tv) are...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24204#24204</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1034" rel="nofollow">dsmiths</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 13 May 2012 at 9:20pm<br /><br />Roy, some tow vehicles (tv) are prewired at the factory to include a 12 volt wire to the pods 12 volt system, sometimes if the selling dealer did the wiring connection this may not be included. does your tv have a factory trailer plug in or was it added at the dealer ? also the interior lights work off of 12 volts during dry camping, if you are planning on doing a lot of dry camping you may want to invest in low currect led type bulbs, there are a lot of sources on this website. keep poddin and keep smiling.]]>
   <pubDate>Sun, 13 May 2012 21:20:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24204#24204</guid>
   <title>Introduction : OK...I&amp;#039;ll preface this with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24203#24203</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1245" rel="nofollow">KayakkrazyUP</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 13 May 2012 at 9:13pm<br /><br />OK...I'll preface this with an apology for the dumb question.  <br /><br />I've been told that the alternator on the car charges the camper battery when travelling.  That true?<br /><br />Do the interior lights function on 12 volt while dry camping?<br /><br />Please remember, you were all "green" once.  Well, maybe not this green.<br /><br />Roy]]>
   <pubDate>Sun, 13 May 2012 21:13:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=24203#24203</guid>
   <title>Introduction :   Welcome to the group! Feel...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23971#23971</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 02 May 2012 at 4:35pm<br /><br />Welcome to the group!&nbsp; Feel free to post any questions you may have....there are lots of fine folks who will help.&nbsp; Regarding the "stinky slinky" holder, I would agree to just go ahead and replace it with a longer one with a larger diameter - life will be better.&nbsp; There a a few suppliers, one of which is Camping World.<div>&nbsp;</div><div>I think you are on the right track regarding the plumbing.&nbsp; I would suggest leaving the pump on for a while to pressurize the system and check all of the plumbing you can access.&nbsp; </div>]]>
   <pubDate>Wed, 02 May 2012 16:35:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23971#23971</guid>
   <title>Introduction :   Pods have manuals?? </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23964#23964</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 02 May 2012 at 12:53pm<br /><br />Pods have manuals??&nbsp; <img src="https://www.rpod-owners.com/smileys/smiley36.gif" height="18" width="18" border="0" alt="LOL" title="LOL" /><img src="https://www.rpod-owners.com/smileys/smiley36.gif" height="18" width="18" border="0" alt="LOL" title="LOL" /><img src="https://www.rpod-owners.com/smileys/smiley36.gif" height="18" width="18" border="0" alt="LOL" title="LOL" /><img src="https://www.rpod-owners.com/smileys/smiley36.gif" height="18" width="18" border="0" alt="LOL" title="LOL" /><div>&nbsp;</div><div>&nbsp;</div>]]>
   <pubDate>Wed, 02 May 2012 12:53:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23964#23964</guid>
   <title>Introduction : Welcome. I agree about the manual...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23957#23957</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 02 May 2012 at 10:33am<br /><br />Welcome.&nbsp; I agree about the manual - look for the "manual" thread I started in the mods forum.&nbsp; It is far from complete but its far better than anything you'll get from FR. <DIV>&nbsp;</DIV><DIV>You may want to look into getting a bigger sewer pipe container.&nbsp; Someone else here contacted the manufacturer and found they have a bigger one.&nbsp; The problem is the factory container won't accept some&nbsp;sewer hoses.&nbsp; Especially if they've been fitted with parts so they make a good seal with the campsite sewer connection.</DIV>]]>
   <pubDate>Wed, 02 May 2012 10:33:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23957#23957</guid>
   <title>Introduction :   WE all hope to get a manual...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23956#23956</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 02 May 2012 at 8:49am<br /><br />WE all hope to get a manual soon.&nbsp; The only real complaint I have about the Pod is the poor rather generic manual.&nbsp; You will do much better here with questions and searches.<div>&nbsp;</div><div>We love our 177.&nbsp; Just got back from a week in it and ready to go for the next trip!</div>]]>
   <pubDate>Wed, 02 May 2012 08:49:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23956#23956</guid>
   <title>Introduction : Thanks.One cover for the sewer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23954#23954</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1245" rel="nofollow">KayakkrazyUP</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 02 May 2012 at 8:18am<br /><br />Thanks.<div><br></div><div>One cover for the sewer pipe container on the tongue is broken, the other missing entirely. Can they be purchased at an R-pod dealer? &nbsp;We did not get an owners manual with the purchase, so we are investigating by trial and error. &nbsp;Hope to get a manual soon.</div>]]>
   <pubDate>Wed, 02 May 2012 08:18:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23954#23954</guid>
   <title>Introduction :   The Pod&amp;#039;s plumbing is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23952#23952</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 02 May 2012 at 7:07am<br /><br />The Pod's plumbing is a relatively simple set of small pvc pipes and hoses, nothing that someone with basic handy skills couldn't tackle if you find more leaks.<div>&nbsp;</div><div>Welcome and congratulations on the Pod purchase, you'll love it!!&nbsp; And hopefully you won't find anymore small leaks!!</div><div>&nbsp;</div><div>Good luck!</div>]]>
   <pubDate>Wed, 02 May 2012 07:07:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23952#23952</guid>
   <title>Introduction : We are new members, just having...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23948#23948</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1245" rel="nofollow">KayakkrazyUP</a><br /><strong>Subject:</strong> 2538<br /><strong>Posted:</strong> 01 May 2012 at 10:55pm<br /><br />We are new members, just having purchased a new/used 2011 r-pod 177 yesterday. &nbsp;It's a year old but only slept in two nights, on one short trip. &nbsp;Unfortunately, the original owner did not properly winterize it last fall. &nbsp;All I have noticed is a leak at the back of the toilet when I convinced the seller to let me fill the water tank and turn the pump on. &nbsp;I couldn't detect any sight or sound of more moving water, and the water heater pressure relief valve flushed water when opened. &nbsp;Tomorrow after work I'll open things up to see the pump and water heater, and some more water pipe connections. &nbsp;Is there anything in particular I should be looking for?<div><br></div><div>This site has been very helpful for a number of days, tho I didn't join until we had actually made the purchase yesterday. &nbsp;Thanks for your help....past and future.</div><div><br></div><div>Roy, Deb (and Coco the Munsterlander Pointer)</div>]]>
   <pubDate>Tue, 01 May 2012 22:55:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2538&amp;PID=23948#23948</guid>
