  <title>R-pod Owners Forum : Water hose</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : Water hose</description>
  <pubDate>Sat, 24 Oct 2026 20:59:10 +0000</pubDate>
  <lastBuildDate>Sat, 31 Mar 2012 02:41:22 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=2465</WebWizForums:feedURL>
   <title>Water hose :    Gunga WELCOME. Make sure...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23298#23298</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=648" rel="nofollow">Goose</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 31 Mar 2012 at 2:41am<br /><br />&nbsp; Gunga WELCOME. Make sure that your water hose is "white" in color as some campgrounds do not permit you to use a colored garden hose for water supply to the trailer.<div>&nbsp;&nbsp;&nbsp; We use a water filter as others have mentioned, found it to really help alot when we stay in AZ. with all the minerals in the water out there.&nbsp;&nbsp; Goose</div>]]>
   <pubDate>Sat, 31 Mar 2012 02:41:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23298#23298</guid>
   <title>Water hose :   Yes, because you wash your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23296#23296</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=828" rel="nofollow">Snowbound</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 10:11pm<br /><br />Yes, because you wash your dishes, have showers and boil water for coffee and tea-and boiling does not remove lead!]]>
   <pubDate>Fri, 30 Mar 2012 22:11:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23296#23296</guid>
   <title>Water hose : All good suggestions. Even though...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23293#23293</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1190" rel="nofollow">Gunga</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 4:27pm<br /><br />All good suggestions. Even though I do not see us drinking from the faucet in most instances a drinking water hose makes sense.]]>
   <pubDate>Fri, 30 Mar 2012 16:27:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23293#23293</guid>
   <title>Water hose : I have a potable water hose and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23292#23292</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 2:42pm<br /><br />I have a potable water hose and a length of ordinary garden hose for flushing out the blackwater tank and washing down the Pod and truck if the spirit moves me.]]>
   <pubDate>Fri, 30 Mar 2012 14:42:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23292#23292</guid>
   <title>Water hose :  Congratulations and welcome...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23291#23291</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=574" rel="nofollow">psaman</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 2:13pm<br /><br />Congratulations and welcome Gunga!! Since we are talking water hoses, something else you might consider is a pressure regulator. Don't know how bad the problem is or even if it exists, but this will keep over-pressure from damaging your plumbing. &nbsp; <br><a href="http://www.campingworld.com/search/index.cfm?Ntt=water+pressure+regulator&amp;N=0&amp;Ntx=mode+matchallpartial&amp;Ntk=p_keyword&amp;Nty=1&amp;Ntpc=1" target="_blank">http://www.campingworld.com/search/index.cfm?Ntt=water+pressure+regulator&amp;N=0&amp;Ntx=mode+matchallpartial&amp;Ntk=p_keyword&amp;Nty=1&amp;Ntpc=1</a><br>]]>
   <pubDate>Fri, 30 Mar 2012 14:13:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23291#23291</guid>
   <title>Water hose : Welcome! Agree with all of the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23287#23287</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 11:39am<br /><br />Welcome!&nbsp; Agree with all of the above.&nbsp; I'll add that the problem with many garden water hoses is they contain lead, so if the water has been sitting in them you need to let them run for a minute or two before drinking from them (Consumer Reports did a test years ago and found all this out).&nbsp; The white drinking water hoses don't have lead.]]>
   <pubDate>Fri, 30 Mar 2012 11:39:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23287#23287</guid>
   <title>Water hose : I agree totally with tpierce,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23283#23283</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=884" rel="nofollow">2Peas-n-Rpod</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 10:36am<br /><br />I agree totally with tpierce, and will add one thing: you might want to get a long hose (25') and also a short one (10' or 15'). If you have hook ups close to your spot, it's nice to have that smaller hose so you don't have to wrestle with the long one. Have some great travels in your new rig!]]>
   <pubDate>Fri, 30 Mar 2012 10:36:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23283#23283</guid>
   <title>Water hose : Gunga, make sure that the water...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23282#23282</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=735" rel="nofollow">tpierce220</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 10:03am<br /><br />Gunga, make sure that the water hose is the right type--one that is specifically used for drinking water such as&nbsp;http://www.campingworld.com/shopping/product/never-kink-hoses/4343 . &nbsp;<div><br></div><div>Also, you may want to get yourself a water filter to attach to the hose. &nbsp;Water quality can vary from campground to campground. &nbsp;We've used something like this:&nbsp;http://www.campingworld.com/shopping/item/tastepure-kdfcarbon-water-filter/18478</div><div><br></div><div>You can get find everything you need at Wal Mart much cheaper than the prices you'll find at Camping World. &nbsp;</div>]]>
   <pubDate>Fri, 30 Mar 2012 10:03:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23282#23282</guid>
   <title>Water hose :   Welcome!It really does not...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23278#23278</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=828" rel="nofollow">Snowbound</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 1:13am<br /><br />Welcome!<div></div>It really does not hurt to carry two 25 foot hoses.&nbsp; We have needed two lengths once in a while in some&nbsp;campgrounds and once our 25 ' 'blew up' and we came back to find a note on the door from the management saying we had sprung a leak in the hose so they turned off the water.<div>&nbsp;</div>]]>
   <pubDate>Fri, 30 Mar 2012 01:13:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23278#23278</guid>
   <title>Water hose : Thanks for the replies. I did...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23277#23277</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1190" rel="nofollow">Gunga</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 12:26am<br /><br />Thanks for the replies. I did get a starter kit but did not check it that close. I am thinking a 25' collapsible hose is the way to go.]]>
   <pubDate>Fri, 30 Mar 2012 00:26:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23277#23277</guid>
   <title>Water hose : Congrats on the new Rpod. Yes,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23276#23276</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 12:18am<br /><br />Congrats on the new Rpod.&nbsp; Yes, you will have to provide a hose from the hose bib at your campsite to your trailer.&nbsp; Also, will have to carry your own sewer disposale pipe if you have a full hookup.&nbsp; Didn't your dealer provide you with a starter kit which included both.&nbsp; Or, did you purchase from a private party?]]>
   <pubDate>Fri, 30 Mar 2012 00:18:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23276#23276</guid>
   <title>Water hose :   Welcome, Gunga. Yup, it&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23275#23275</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 12:17am<br /><br />Welcome, Gunga. Yup, it's me from the Tacoma board. You do need a water hose, and make sure it's at a 25 footer or so. Some campgrounds may not have the water or electric hookups too close, although it's not usually a problem with most hook up sites.]]>
   <pubDate>Fri, 30 Mar 2012 00:17:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23275#23275</guid>
   <title>Water hose : New member here. Do I need to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23273#23273</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1190" rel="nofollow">Gunga</a><br /><strong>Subject:</strong> 2465<br /><strong>Posted:</strong> 30 Mar 2012 at 12:01am<br /><br />New member here. Do I need to carry my own water hose to campgrounds with water hookups?]]>
   <pubDate>Fri, 30 Mar 2012 00:01:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2465&amp;PID=23273#23273</guid>
