  <title>R-pod Owners Forum : Lug Nut Size</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Lug Nut Size</description>
  <pubDate>Thu, 27 Aug 2026 13:54:25 +0000</pubDate>
  <lastBuildDate>Mon, 02 Apr 2012 21:44:18 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=2455</WebWizForums:feedURL>
   <title>Lug Nut Size :    Just the thought of chewin&amp;#039;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23356#23356</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=648" rel="nofollow">Goose</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 02 Apr 2012 at 9:44pm<br /><br /> Just the thought of chewin' on Gorilla nuts brought tears to my eyes. Goose<div>&nbsp;&nbsp;&nbsp; Glade that the Lug Nuts work for you.</div>]]>
   <pubDate>Mon, 02 Apr 2012 21:44:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23356#23356</guid>
   <title>Lug Nut Size :   Originally posted by Camper...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23353#23353</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=140" rel="nofollow">HuronSailor</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 02 Apr 2012 at 6:10pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Camper Bob</strong></em><br /><br />Are they anything like Prairie Oysters?</td></tr></table><div><br></div><div>Hahahahahahahahahaha.</div><div><br></div><div>Can't. Breathe.</div>]]>
   <pubDate>Mon, 02 Apr 2012 18:10:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23353#23353</guid>
   <title>Lug Nut Size :   Thanks again, Goose and Camper...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23350#23350</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 02 Apr 2012 at 5:51pm<br /><br />Thanks again, Goose and Camper Bob, my stainless steel Gorilla Lugs are mounted and lookin' good. They're advertized as the last lugs you'll have to buy--We'll see. Hope so! The size, #61188, is a good fit. The Gorilla #61187 are the same sized lugs in a 4 pack. I was lucky enough to get some Amazon (used/returned but perfect) ones for $3.00 each pack-regular $13.82 each pack.]]>
   <pubDate>Mon, 02 Apr 2012 17:51:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23350#23350</guid>
   <title>Lug Nut Size : Your welcome. Are they anything...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23289#23289</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 30 Mar 2012 at 11:54am<br /><br />Your welcome.&nbsp; Are they anything like Prairie Oysters?]]>
   <pubDate>Fri, 30 Mar 2012 11:54:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23289#23289</guid>
   <title>Lug Nut Size :   Holy smokes, Camper Bob, way...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23288#23288</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 30 Mar 2012 at 11:53am<br /><br />Holy smokes, Camper Bob, way to delve into things. Your grandfather musta been Sherlock Holmes. I've had some Gorilla lugs before, and they're good stuff. Great job!]]>
   <pubDate>Fri, 30 Mar 2012 11:53:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23288#23288</guid>
   <title>Lug Nut Size : Wow, that took some investigation!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23286#23286</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 30 Mar 2012 at 11:34am<br /><br />Wow, that took some investigation!&nbsp; Thanks for the info.]]>
   <pubDate>Fri, 30 Mar 2012 11:34:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23286#23286</guid>
   <title>Lug Nut Size : OK. I called FR and they confirmed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23274#23274</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 30 Mar 2012 at 12:11am<br /><br />OK.&nbsp; I called FR and they confirmed that on my HRE edition I would be getting a Lippert axle.&nbsp; However FR was concerned that replacing the lug nuts might invalidate the warranty from Lippert.&nbsp; Next call was to Lippert and they were not concerned at all about changing lug nuts.&nbsp; Then called Gorilla Lug Nuts in L.A. and they recommended a&nbsp;61188 part number.&nbsp;They are SS and have a lifetime warranty. Their retail price is about 3.58 per nut.&nbsp; Went to Amazon and they don't seem to have the 61188.&nbsp; Then Googled the number and was able to purchase them from Brandsport.com for $2.53 each.&nbsp;&nbsp;&nbsp; There, you have it.&nbsp; Hope that helps.&nbsp; ]]>
   <pubDate>Fri, 30 Mar 2012 00:11:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23274#23274</guid>
   <title>Lug Nut Size : I&amp;#039;d like to add...that an...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23269#23269</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=931" rel="nofollow">Footslogger03</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 29 Mar 2012 at 9:08pm<br /><br />I'd like to add&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...that an "impact" socket is the best way to go. It is a 12 point socket and makes a more secure lock on the lug nut.<br /><br />MJ]]>
   <pubDate>Thu, 29 Mar 2012 21:08:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23269#23269</guid>
   <title>Lug Nut Size :   Hey Goose, thanks for the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23257#23257</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 29 Mar 2012 at 2:59am<br /><br />Hey Goose, thanks for the lug specs. The thread size is what I needed to make a raid on Amazon for the stainless steel ones.]]>
   <pubDate>Thu, 29 Mar 2012 02:59:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23257#23257</guid>
   <title>Lug Nut Size :    Sorry that I did not think...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23255#23255</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=648" rel="nofollow">Goose</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 28 Mar 2012 at 9:48pm<br /><br />&nbsp;&nbsp;&nbsp; Sorry that I did not think of this earlier, I just went out and pulled up the cover to get into the sidebox where I have a package of locking lug nuts. The size is "&nbsp;1/2-20, tapered seat ".&nbsp; 1/2 inch stud with a standard thread count of 20 threads per inch and a tapered seat.&nbsp; Make sure that you do not pick up a mm size for foreign cars. <div>&nbsp; Why I have locking lug nuts (one on each wheel) is another story. </div><div>&nbsp; I would not think that there would be any difference in size between the Dexter or Lippert axles. I do have a Dexter.&nbsp;&nbsp;&nbsp; Goose</div>]]>
   <pubDate>Wed, 28 Mar 2012 21:48:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23255#23255</guid>
   <title>Lug Nut Size : I have that on my list of things...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23253#23253</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 28 Mar 2012 at 2:33pm<br /><br />I have that on my list of things to do upon delivery.&nbsp; I checked on the web and lug nuts come in various sizes even based on an outside size of 13/16ths.&nbsp; Trying the factory for more info.&nbsp; ]]>
   <pubDate>Wed, 28 Mar 2012 14:33:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23253#23253</guid>
   <title>Lug Nut Size : When I took delivery of my Pod,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23252#23252</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=422" rel="nofollow">TIDALWAVE</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 28 Mar 2012 at 1:55pm<br /><br />When I took delivery of my Pod, I took both wheels over to a tire shop and had them both dynamically balanced.&nbsp; Shop said that they definitely needed balancing.&nbsp; So I recommend having your wheels checked.&nbsp; It may save you having to replace the tires too soon.]]>
   <pubDate>Wed, 28 Mar 2012 13:55:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23252#23252</guid>
   <title>Lug Nut Size :   5 lug nuts per wheel. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23251#23251</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=648" rel="nofollow">Goose</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 28 Mar 2012 at 11:19am<br /><br />&nbsp;&nbsp;5 lug nuts per wheel.]]>
   <pubDate>Wed, 28 Mar 2012 11:19:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23251#23251</guid>
   <title>Lug Nut Size : Haven&amp;#039;t taken delivery or...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23249#23249</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 28 Mar 2012 at 10:34am<br /><br />Haven't taken delivery or ours yet, however replacing the lug nuts with SS ones makes sense.&nbsp; How many per wheel?&nbsp; Someone had suggested having the wheels balanced and the air stems replaced with SS also.&nbsp; Seems like thats the time to replace the original ones.&nbsp; Thanks in advance for your help.&nbsp; Good Camping.]]>
   <pubDate>Wed, 28 Mar 2012 10:34:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23249#23249</guid>
   <title>Lug Nut Size : 13/16 on the outside, same as...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23162#23162</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1034" rel="nofollow">dsmiths</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 24 Mar 2012 at 8:31pm<br /><br />13/16 on the outside, same as Ford, I think the rim is a Ford pattern, just take one lug nut off and go to , fill in the blank.  Autozone, Oreilly, Sears. The stainless steel is a good idea, I saw some rust on one of my lugs today during recheck torque, it's only 6 months old.]]>
   <pubDate>Sat, 24 Mar 2012 20:31:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23162#23162</guid>
   <title>Lug Nut Size :   Hey, spring is coming, and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23154#23154</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 2455<br /><strong>Posted:</strong> 24 Mar 2012 at 3:54pm<br /><br />Hey, spring is coming, and it's time to clean up the Pod.&nbsp; I live by the sea and &nbsp;have a few rusting lug nuts. Does anyone know the size and thread size I will need to buy? I think I'll try stainless steel ones if available for the Pod.]]>
   <pubDate>Sat, 24 Mar 2012 15:54:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2455&amp;PID=23154#23154</guid>
