  <title>R-pod Owners Forum : water heater turnoff switch</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : water heater turnoff switch</description>
  <pubDate>Wed, 28 Oct 2026 07:31:25 +0000</pubDate>
  <lastBuildDate>Wed, 02 Nov 2011 06:04:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=2219</WebWizForums:feedURL>
   <title>water heater turnoff switch :   Not worried I drained it....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20725#20725</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 02 Nov 2011 at 6:04am<br /><br />Not worried I drained it.&nbsp; Thanks ]]>
   <pubDate>Wed, 02 Nov 2011 06:04:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20725#20725</guid>
   <title>water heater turnoff switch : Yup, that is why I was asking,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20722#20722</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 8:30pm<br /><br />Yup, that is why I was asking, I don't think it was emptied.  And both switches should be off before draining it.]]>
   <pubDate>Tue, 01 Nov 2011 20:30:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20722#20722</guid>
   <title>water heater turnoff switch :  There is NOT a HWH &amp;#034;drain...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20719#20719</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 7:38pm<br /><br />There is NOT a HWH "drain valve". In order to drain the HWH, you MUST remove the anode rod/ plug. If you "drained" valve at the top, that is the high pressure valve, and there is still about 5 1/2 gallons of water in the HWH. It doesn't "drip out" when you remove the anode rod, it will FLOW out.<br><br>EDIT: if it isn't drained, the damage will be bad. A broken water heater. Bad. Expensive. <br>]]>
   <pubDate>Tue, 01 Nov 2011 19:38:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20719#20719</guid>
   <title>water heater turnoff switch :        Nope antifreeze was...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20715#20715</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 5:21pm<br /><br /> <div id="yiv928833646"><div id="yui_3_2_0_1_13201819118743397"><div style="color: rgb0, 0, 0; font-family: arial, helvetica, sans-serif; font-size: 10pt; : rgb255, 255, 255;" id="yui_3_2_0_1_13201819118743396"><div id="yui_3_2_0_1_13201819118743395"><span id="yui_3_2_0_1_13201819118743394">Nope antifreeze was in there but i hopefully emptied what water/antifreeze was in the heater by opening the valve and letting the water drip out. Then turned the outside electric switch switch off and left the inside switch off and turned the furnace on.  Hopefully, there will be no damage to the water heater since I feel comfortable with it being drained.  If ther is some  damage, this year, hopefully it won't be too bad. I then ran the furnace. </span></div></div></div></div>]]>
   <pubDate>Tue, 01 Nov 2011 17:21:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20715#20715</guid>
   <title>water heater turnoff switch :  Originally posted by HZNHRZI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20711#20711</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=474" rel="nofollow">this_is_nascar</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 2:44pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by HZNHRZ</strong></em><br /><br />I emptied he water/antifreeze from the water heater by opening the external valve.</td></tr></table> <DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>I'm confused.&nbsp; So you did have antifreeze in the HWH and now you don't?&nbsp; Did you not use the HWH bypass, so that antifreeze didn't enter the HWH?</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 01 Nov 2011 14:44:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20711#20711</guid>
   <title>water heater turnoff switch : Which external valve?  There is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20702#20702</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 12:58pm<br /><br />Which external valve?  There is an overpressure valve on the water heater itself which is useful when you use the low-point drains to drain the whole water system.  Opening that valve will break the vacuum lock allowing the water heater to drain.  The only other way to drain the water heater is to remove the anode rod temporarily.]]>
   <pubDate>Tue, 01 Nov 2011 12:58:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20702#20702</guid>
   <title>water heater turnoff switch :   I emptied he water/antifreeze...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20700#20700</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 9:32am<br /><br />I emptied he water/antifreeze from the water heater by opening the external valve.]]>
   <pubDate>Tue, 01 Nov 2011 09:32:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20700#20700</guid>
   <title>water heater turnoff switch :   Thanks </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20699#20699</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 9:31am<br /><br />Thanks]]>
   <pubDate>Tue, 01 Nov 2011 09:31:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20699#20699</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20686#20686</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=474" rel="nofollow">this_is_nascar</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 01 Nov 2011 at 8:36am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by HZNHRZ</strong></em><br /><br />I have added camper antifreeze for the winter.&nbsp; However, I coud not find a turnorr switch for the water heater in the outside compartment.&nbsp; I open the valve to let the remaining water out after I added the antifreeze.&nbsp;&nbsp; If there is a switch, I can't find it.</td></tr></table> <DIV>&nbsp;</DIV><DIV>I'm assuming you bypassed the hot water heater, so antifreeze did not enter it, correct?&nbsp; What switch are you looking for, the one that allows it to run on electric?&nbsp; As others have said, it's at the hot water heater, behind the outside cover.&nbsp; I'm not sure why your concerned with that switch though.&nbsp; Did you use it throughout the year?&nbsp; If so, you should have turned it off before you winterized.&nbsp; In addition, you should be disconnecting your battery for the winter, unless you're keeping it plugged in all winter, which is fine to do.</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 01 Nov 2011 08:36:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20686#20686</guid>
   <title>water heater turnoff switch :   Hmmm.The pics show upon the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20662#20662</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=819" rel="nofollow">Hodge-PODge</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 6:00pm<br /><br />Hmmm.&nbsp;&nbsp;The pics show up&nbsp;on the PC.&nbsp; Must have been an "Apple" problem.]]>
   <pubDate>Mon, 31 Oct 2011 18:00:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20662#20662</guid>
   <title>water heater turnoff switch : YES </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20660#20660</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1003" rel="nofollow">sfish</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 5:45pm<br /><br />YES]]>
   <pubDate>Mon, 31 Oct 2011 17:45:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20660#20660</guid>
   <title>water heater turnoff switch :   Originally posted by TerryMI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20646#20646</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=819" rel="nofollow">Hodge-PODge</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 9:54am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by TerryM</strong></em><br /><br />I did a bunch of searching in my pictures.&nbsp; The arrow shows the switch location.<br><br>Terry<br><br><img src="http://i245.photobucket.com/albums/gg51/Fulltimer_KJ/R-Pod001.jpg" border="0" /><br></td></tr></table><div><br></div><div>Terry, I can't see anything. &nbsp;Instead of a picture, I have a small blue square with a question mark inside it. &nbsp;Don't know if it's because I'm on a Mac at the moment. &nbsp;Will try my PC later and see if the pic shows up.</div>]]>
   <pubDate>Mon, 31 Oct 2011 09:54:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20646#20646</guid>
   <title>water heater turnoff switch :   Is this switch inside the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20644#20644</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 9:06am<br /><br />Is this switch inside the camper underneath the kitchen sink?]]>
   <pubDate>Mon, 31 Oct 2011 09:06:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20644#20644</guid>
   <title>water heater turnoff switch : There is another toggle switch...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20641#20641</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1003" rel="nofollow">sfish</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 8:31am<br /><br /><P>There is another toggle switch inside next to the water pump.That switch turns on the gas portion of the water heater. Make sure you dont turn that on. The furnace is just fine to use without water in the hot water heater.</P>]]>
   <pubDate>Mon, 31 Oct 2011 08:31:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20641#20641</guid>
   <title>water heater turnoff switch :   One other question. Assuming...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20640#20640</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 8:25am<br /><br />One other question.&nbsp; Assuming I find the switch would you know if I can turn the heat on using propane without burning out the water heater, assuming I emptied the water with the on/off valve.<div>&nbsp;</div><div>Thanks again</div>]]>
   <pubDate>Mon, 31 Oct 2011 08:25:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20640#20640</guid>
   <title>water heater turnoff switch :   Thank you </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20639#20639</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 8:22am<br /><br />Thank you]]>
   <pubDate>Mon, 31 Oct 2011 08:22:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20639#20639</guid>
   <title>water heater turnoff switch : I did a bunch of searching in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20638#20638</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 7:40am<br /><br />I did a bunch of searching in my pictures.&nbsp; The arrow shows the switch location.<br><br>Terry<br><br><img src="http://i245.photobucket.com/albums/gg51/Fulltimer_KJ/R-Pod001.jpg" border="0" /><br>]]>
   <pubDate>Mon, 31 Oct 2011 07:40:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20638#20638</guid>
   <title>water heater turnoff switch : Somewhere on here is a picture...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20637#20637</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 7:35am<br /><br />Somewhere on here is a picture showing the outside switch.&nbsp; I couldn't find it.&nbsp; But, the switch in the heater compartment is hidden behind something.&nbsp; It is pretty hard to see.&nbsp; Its a small rocker switch.<br><br>Terry<br>]]>
   <pubDate>Mon, 31 Oct 2011 07:35:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20637#20637</guid>
   <title>water heater turnoff switch :   I have added camper antifreeze...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20635#20635</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=777" rel="nofollow">HZNHRZ</a><br /><strong>Subject:</strong> 2219<br /><strong>Posted:</strong> 31 Oct 2011 at 7:11am<br /><br />I have added camper antifreeze for the winter.&nbsp; However, I coud not find a turnorr switch for the water heater in the outside compartment.&nbsp; I open the valve to let the remaining water out after I added the antifreeze.&nbsp;&nbsp; If there is a switch, I can't find it.]]>
   <pubDate>Mon, 31 Oct 2011 07:11:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2219&amp;PID=20635#20635</guid>
