  <title>R-pod Owners Forum : My Northern Tool Cover</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : My Northern Tool Cover</description>
  <pubDate>Thu, 26 Nov 2026 16:28:17 +0000</pubDate>
  <lastBuildDate>Fri, 30 Dec 2011 20:06:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=2182</WebWizForums:feedURL>
   <title>My Northern Tool Cover : I purchased my Northern Tool cover...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21501#21501</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=727" rel="nofollow">turncoat3</a><br /><strong>Subject:</strong> 2182<br /><strong>Posted:</strong> 30 Dec 2011 at 8:06pm<br /><br />I purchased my Northern Tool cover in October and the177 pod is put to bed with the cover on since Dec 1.&nbsp; It was easy with two persons doing the covering.&nbsp; there is a video on putting a cover on and it does help a lot as well as the instructions in the package.&nbsp; <img src="http://www.rpod-owners.com/uploads/727/IMG_0774.JPG" height="480" width="640" border="0" />]]>
   <pubDate>Fri, 30 Dec 2011 20:06:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21501#21501</guid>
   <title>My Northern Tool Cover :   Originally posted by melpQuestion:  Does...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21492#21492</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 2182<br /><strong>Posted:</strong> 29 Dec 2011 at 5:27pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by melp</strong></em><br /><br />Question:<br><br>Does your Rpod have the rooftop AC unit and the round Wineguard  antenna.</td></tr></table><br><br>Yep to both.&nbsp; The noodle things sound pretty good.<br><br>Terry<br>]]>
   <pubDate>Thu, 29 Dec 2011 17:27:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21492#21492</guid>
   <title>My Northern Tool Cover :  Originally posted by TerryMThings...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21484#21484</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=931" rel="nofollow">Footslogger03</a><br /><strong>Subject:</strong> 2182<br /><strong>Posted:</strong> 28 Dec 2011 at 9:35pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by TerryM</strong></em><br /><br />Things started out okay getting it on.  Then Murphy's Law took control!  I just about had 1/2 of it on when the wind picked up and blew it back off!  But, I persisted!  The next thing I knew I was standing on the roof pulling that thing on against the wind.  I had it on sideways!<img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" />  Got off the roof and by pulling a little on one side then move over to the other side and pulled a little I got it turned around.It fits pretty good!  Like others have said "the zippers for the door opening doesn't hit exactly right" but I can open the door all the way with no trouble.For the money you can't go wrong.  It seems to be well made too.  I'm going to cut up an old "T" shirt and make some padding for the 4 corners.  It looks like the corners will eventually rub through the cover on mine.Too bad I didn't have this cover before the sun ruined some of my decals.  But its just a small piece. Terry <br /></td></tr></table> <br /><br />=============<br /><br />Another thing that works well on the corners are strips of those foam beach noodles. Split them open and spread them over the sharp corners.<br /><br />MJ]]>
   <pubDate>Wed, 28 Dec 2011 21:35:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21484#21484</guid>
   <title>My Northern Tool Cover : Question:  Does your Rpod have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21482#21482</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=963" rel="nofollow">melp</a><br /><strong>Subject:</strong> 2182<br /><strong>Posted:</strong> 28 Dec 2011 at 10:39am<br /><br />Question:<br /><br />Does your Rpod have the rooftop AC unit and the round Wineguard  antenna.  ]]>
   <pubDate>Wed, 28 Dec 2011 10:39:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=21482#21482</guid>
   <title>My Northern Tool Cover : where are the pictures of you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=20313#20313</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=431" rel="nofollow">rpodcamper.com</a><br /><strong>Subject:</strong> 2182<br /><strong>Posted:</strong> 18 Oct 2011 at 4:00pm<br /><br />where are the pictures of you "flying"your cover?<img src="http://www.rpod-owners.com/smileys/smiley36.gif" height="18" width="18" border="0" alt="LOL" title="LOL" /><DIV>&nbsp;</DIV><DIV>My only problem I see with the covers are that the wind will catch them and rub against the trailer doing damage.&nbsp; But I may be wrong.</DIV>]]>
   <pubDate>Tue, 18 Oct 2011 16:00:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=20313#20313</guid>
   <title>My Northern Tool Cover : Things started out okay getting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=20312#20312</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 2182<br /><strong>Posted:</strong> 18 Oct 2011 at 3:52pm<br /><br />Things started out okay getting it on.&nbsp; Then Murphy's Law took control!&nbsp; I just about had 1/2 of it on when the wind picked up and blew it back off!&nbsp; But, I persisted!&nbsp; The next thing I knew I was standing on the roof pulling that thing on against the wind.&nbsp; I had it on sideways!<img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" />&nbsp; Got off the roof and by pulling a little on one side then move over to the other side and pulled a little I got it turned around.<br><br>It fits pretty good!&nbsp; Like others have said "the zippers for the door opening doesn't hit exactly right" but I can open the door all the way with no trouble.<br><br>For the money you can't go wrong.&nbsp; It seems to be well made too.&nbsp; I'm going to cut up an old "T" shirt and make some padding for the 4 corners.&nbsp; It looks like the corners will eventually rub through the cover on mine.<br><br>Too bad I didn't have this cover before the sun ruined some of my decals.&nbsp; But its just a small piece. <br><br>Terry <br>]]>
   <pubDate>Tue, 18 Oct 2011 15:52:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=2182&amp;PID=20312#20312</guid>
