  <title>R-pod Owners Forum : First Weekend with ¡Podtástic!</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Camping Adventures : First Weekend with ¡Podtástic!</description>
  <pubDate>Fri, 23 Oct 2026 12:52:08 +0000</pubDate>
  <lastBuildDate>Mon, 25 Apr 2011 18:46:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=1750</WebWizForums:feedURL>
   <title>First Weekend with ¡Podtástic! : Techntrek,That is an interesting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=15017#15017</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=735" rel="nofollow">tpierce220</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 25 Apr 2011 at 6:46pm<br /><br />Techntrek,<div><br></div><div>That is an interesting trick! &nbsp;Thanks so much.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /></div>]]>
   <pubDate>Mon, 25 Apr 2011 18:46:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=15017#15017</guid>
   <title>First Weekend with ¡Podtástic! : Wow, that is some blog entry....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=15011#15011</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 25 Apr 2011 at 5:22pm<br /><br />Wow, that is some blog entry.&nbsp; A bit slow to load with all of the pics and maps, but a good read and nice to see where you were going.&nbsp; <DIV>&nbsp;</DIV><DIV>A trick to make sure you are hooked up correctly, I've been doing this for years:&nbsp;&nbsp;after you think the ball is seated and you've latched it, crank the tongue jack down a half-dozen turns (assuming it was still touching the ground)&nbsp;and watch the ball + hitch to see if the ball starts to pull out.&nbsp; If I'm still not sure I'll even sit on the tow vehicle's bumper at this point and bounce on it a few times.&nbsp; Then I'll lock the hitch and crank the jack all the way up for travel.</DIV><DIV>&nbsp;</DIV><DIV>As for the water heater, now that the anode is back in place you can leave it there.&nbsp; I don't drain my water heater all season until I winterize again, and when I do I use the low point drains and open the pressure safety valve to break the vacuum inside.&nbsp; You should remove the anode every 2 years to check its condition (draining the tank in the process), but put it back in to prevent rust on the threads.</DIV>]]>
   <pubDate>Mon, 25 Apr 2011 17:22:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=15011#15011</guid>
   <title>First Weekend with ¡Podtástic! : This is perfect! Thanks!!Tim </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14974#14974</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=735" rel="nofollow">tpierce220</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 24 Apr 2011 at 1:37pm<br /><br />This is perfect! &nbsp;Thanks!!&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /><div><br></div><div>Tim</div>]]>
   <pubDate>Sun, 24 Apr 2011 13:37:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14974#14974</guid>
   <title>First Weekend with ¡Podtástic! : Here is a POD Check List that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14973#14973</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=738" rel="nofollow">marshwatcher</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 24 Apr 2011 at 1:22pm<br /><br />Here is a POD Check List that might help you on your next outing. You can customize it to fit your equipment and needs!<br /><br />RPOD CHECK LIST<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ARRIVAL<br />find a good spot, line up door and power source<br />complete1st side to side level check<br />raise trailer/hitch w/ tongue jack & lower hitch<br />release coupler and then lock with coupler lock<br />raise trailer/place lynx pad and lower—complete 2nd side to side level check<br />disconnect chains & electric<br />level trailer w/ tongue jack (front to rear level)<br />set trailer stabilizers installing lynx pads; Re-check level<br />open propane line<br />test shore power with volt meter<br />install surge protector and lock<br />connect shore power to trailer<br />disinfect water supply with bleach solution, install pressure regulator and connect<br />slide steps out and door handrail<br />slide slide out--out<br />turn TV booster on<br />check all faucets by turning on/clearing lines of air<br />be sure  hot water tank is filled & then turn on hot water heater (remove screens)<br />set refrigerator to correct power source<br />open bathroom vent<br /><br />  DEPARTURE<br />empty fresh water tank if needed<br />check that black & grey water caps are closed & secured<br />disconnect shore power & remove SURGE PROTECTOR; stow away  <br />turn off  hot water heater/replace screens<br />disconnect-stow water hoses, connectors, PRESSURE REGULATOR<br />turn off propane tank (put refrigerator on battery if desired)<br />close bathroom door & fan vent<br />turn TV booster off<br />shades down and locked<br />loose items stowed (black table especially)<br />place tongue weight on tongue jack<br />connect chains & electric (walk around lights check)<br />raise stabilizer jacks, stow lynx pads<br />un-chock wheels<br />check doors and locks<br />slide in steps & close door handle<br />CHECK CAMPSITE FOR ANY LEFT BEHIND ITEMS<br /> <br /><br />]]>
   <pubDate>Sun, 24 Apr 2011 13:22:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14973#14973</guid>
   <title>First Weekend with ¡Podtástic! : It was a weekend that I&amp;#039;ll...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14963#14963</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=735" rel="nofollow">tpierce220</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 23 Apr 2011 at 9:11pm<br /><br />It was a weekend that I'll never forget and would do again in a heartbeat minus the mishaps with the trailer and the water heater. &nbsp;<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />]]>
   <pubDate>Sat, 23 Apr 2011 21:11:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14963#14963</guid>
   <title>First Weekend with ¡Podtástic! : You all are an amazing group of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14962#14962</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=738" rel="nofollow">marshwatcher</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 23 Apr 2011 at 7:25pm<br /><br />You all are an amazing group of troopers (including the cats!). I enjoyed your story very much and the pictures made it even more fun. Thanks for sharing.]]>
   <pubDate>Sat, 23 Apr 2011 19:25:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14962#14962</guid>
   <title>First Weekend with ¡Podtástic! : WOW, just wow. It sounds like...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14954#14954</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=786" rel="nofollow">jayber</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 22 Apr 2011 at 7:30am<br /><br />WOW, just wow. It sounds like you'll have plenty of memories of this trip. I can't say if I would have soldiered on like you did, but wow.]]>
   <pubDate>Fri, 22 Apr 2011 07:30:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14954#14954</guid>
   <title>First Weekend with ¡Podtástic! : Enjoy...I have it on my website--http://podtastic.info...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14948#14948</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=735" rel="nofollow">tpierce220</a><br /><strong>Subject:</strong> 1750<br /><strong>Posted:</strong> 21 Apr 2011 at 10:15pm<br /><br />Enjoy...I have it on my website--http://podtastic.info]]>
   <pubDate>Thu, 21 Apr 2011 22:15:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1750&amp;PID=14948#14948</guid>
