  <title>R-pod Owners Forum : 2017 RPod 180 frame question</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : 2017 RPod 180 frame question</description>
  <pubDate>Fri, 23 Oct 2026 08:50:27 +0000</pubDate>
  <lastBuildDate>Tue, 30 Jun 2026 07:50:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16466</WebWizForums:feedURL>
   <title>2017 RPod 180 frame question : Good Morning,Unfortunately I have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16466&amp;PID=155617#155617</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14321" rel="nofollow">Pilgrim</a><br /><strong>Subject:</strong> 16466<br /><strong>Posted:</strong> 30 Jun 2026 at 7:50am<br /><br />Good Morning,<div>Unfortunately I have to embark upon installing outriggers on my 2017 RPod 180.&nbsp; To that end I have been crawling under the rig exploring what and how I am going to install the newly ordered outriggers.&nbsp; I noticed that the frame is not exactly straight and is bent down on each side of the newly installed axle. This looks consistent on both side but the door size is harder to eye ball due to the door itself.&nbsp; Yes, I blew a tire which took out the axle so Blue Compass RV in Prescott, AZ recently installed but "did not notice" the slider sag.&nbsp; Lastly, has anyone welded the outriggers as compared to drill and tap?</div><div>Thanks for your input.</div>]]>
   <pubDate>Tue, 30 Jun 2026 07:50:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16466&amp;PID=155617#155617</guid>
