  <title>R-pod Owners Forum : Clean water leak in thetford toilet</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : Clean water leak in thetford toilet</description>
  <pubDate>Wed, 18 Nov 2026 00:34:23 +0000</pubDate>
  <lastBuildDate>Tue, 30 Jun 2026 17:17:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16463</WebWizForums:feedURL>
   <title>Clean water leak in thetford toilet : Bolts are there. The space is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155619#155619</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14150" rel="nofollow">ppine</a><br /><strong>Subject:</strong> 16463<br /><strong>Posted:</strong> 30 Jun 2026 at 5:17pm<br /><br />Bolts are there.&nbsp; The space is so small they are hard to see.&nbsp;<div>Thanks for your observations.&nbsp;</div>]]>
   <pubDate>Tue, 30 Jun 2026 17:17:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155619#155619</guid>
   <title>Clean water leak in thetford toilet : There should be two bolts, one...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155608#155608</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 16463<br /><strong>Posted:</strong> 27 Jun 2026 at 5:57pm<br /><br />There should be two bolts, one on either side just like a conventional toilet. Maybe hidden behind a plastic plug on the base of the toilet. It's been a while since I repaired mine on my R179 when I had it. There might be a Youtube video out there that might help.<div><br></div>]]>
   <pubDate>Sat, 27 Jun 2026 17:57:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155608#155608</guid>
   <title>Clean water leak in thetford toilet : Yes. I agree. Good thoughts.I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155607#155607</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14150" rel="nofollow">ppine</a><br /><strong>Subject:</strong> 16463<br /><strong>Posted:</strong> 27 Jun 2026 at 10:57am<br /><br />Yes.&nbsp; I agree.&nbsp; Good thoughts.&nbsp;<div>I have a 2015 rpod.&nbsp; Not sure of the model number of the Thetford.&nbsp;</div><div>I do not see any mounting bolting holding the unit to the floor.&nbsp;</div><div>How is this toilet removed for valve repair?</div>]]>
   <pubDate>Sat, 27 Jun 2026 10:57:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155607#155607</guid>
   <title>Clean water leak in thetford toilet : Most of the time it is the toilet...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155606#155606</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 16463<br /><strong>Posted:</strong> 27 Jun 2026 at 6:19am<br /><br />Most of the time it is the toilet valve. It's an easy fix with the valve and a new seal usually available on Amazon.&nbsp;]]>
   <pubDate>Sat, 27 Jun 2026 06:19:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155606#155606</guid>
   <title>Clean water leak in thetford toilet : Anyone had this problem?Was it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155605#155605</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14150" rel="nofollow">ppine</a><br /><strong>Subject:</strong> 16463<br /><strong>Posted:</strong> 27 Jun 2026 at 12:18am<br /><br />Anyone had this problem?<div>Was it a leaking valve or supply line?</div><div>When the system is pressurized water leaks out the bottom of the toilet in the middle in a stream.&nbsp;</div>]]>
   <pubDate>Sat, 27 Jun 2026 00:18:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16463&amp;PID=155605#155605</guid>
