  <title>R-pod Owners Forum : Rpod 178 Black Water Tank</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Rpod 178 Black Water Tank</description>
  <pubDate>Fri, 23 Oct 2026 10:20:21 +0000</pubDate>
  <lastBuildDate>Fri, 12 Jun 2026 20:38:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16458</WebWizForums:feedURL>
   <title>Rpod 178 Black Water Tank : I would fill the black water tank...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155588#155588</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 16458<br /><strong>Posted:</strong> 12 Jun 2026 at 8:38pm<br /><br />I would fill the black water tank via the toilet until the water is up to the base of the toilet.&nbsp; Open the black water tank drain and observe what comes out.&nbsp; If nothing, take a snake through the drain and see if you can work anything loose, repeat at the toilet opening as well.&nbsp; Repeat the filling process and drain again to see what comes out.]]>
   <pubDate>Fri, 12 Jun 2026 20:38:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155588#155588</guid>
   <title>Rpod 178 Black Water Tank : Ok, I finally got an inspection...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155587#155587</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14302" rel="nofollow">coltonk</a><br /><strong>Subject:</strong> 16458<br /><strong>Posted:</strong> 12 Jun 2026 at 3:35pm<br /><br />Ok, I finally got an inspection camera and stuck it down the throat of the toilet. What I am seeing is a 45 degree pipe fitting angled towards the outlet pipe of the black water tank. Ive never seen this before on RV's!!]]>
   <pubDate>Fri, 12 Jun 2026 15:35:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155587#155587</guid>
   <title>Rpod 178 Black Water Tank : I have no picture. I will have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155581#155581</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14302" rel="nofollow">coltonk</a><br /><strong>Subject:</strong> 16458<br /><strong>Posted:</strong> 10 Jun 2026 at 6:21pm<br /><br />I have no picture. I will have to get a bright light to take the picture . Its mightly dark down there.<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />]]>
   <pubDate>Wed, 10 Jun 2026 18:21:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155581#155581</guid>
   <title>Rpod 178 Black Water Tank : Got a picture? </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155579#155579</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 16458<br /><strong>Posted:</strong> 10 Jun 2026 at 4:12pm<br /><br />Got a picture?]]>
   <pubDate>Wed, 10 Jun 2026 16:12:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155579#155579</guid>
   <title>Rpod 178 Black Water Tank : I bought a used Rpod 178 a I am...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155577#155577</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14302" rel="nofollow">coltonk</a><br /><strong>Subject:</strong> 16458<br /><strong>Posted:</strong> 09 Jun 2026 at 4:27pm<br /><br /><div>I bought a used Rpod 178 a I am an issue. The Black water tank fills up way to quickly. Yes, I did have enough water in it along with a treatment. After cleaning it out and looking down thru the toilet opening I see something directly under the toilet. Its about 8" wide and rectangular in shape. Does anyone know what this is? I did a search and the toilet is a Thetford model 31647. I originally thought that piece was part of the toilet but it isn't, I'm guessing it is part of the black water tank.</div><div><br></div><div>Any ideas?</div>]]>
   <pubDate>Tue, 09 Jun 2026 16:27:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16458&amp;PID=155577#155577</guid>
