  <title>R-pod Owners Forum : Dometic refirgerator not working on electric</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Dometic refirgerator not working on electric</description>
  <pubDate>Fri, 23 Oct 2026 08:55:46 +0000</pubDate>
  <lastBuildDate>Fri, 29 May 2026 21:37:20 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16448</WebWizForums:feedURL>
   <title>Dometic refirgerator not working on electric : Thanks so much, Jay. That really...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16448&amp;PID=155549#155549</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14189" rel="nofollow">Dalebrons</a><br /><strong>Subject:</strong> 16448<br /><strong>Posted:</strong> 29 May 2026 at 9:37pm<br /><br />Thanks so much, Jay. That really helps to know it has reached its serviceable life! I think we'll just run it off of gas for now.<div><br></div><div>Appreciate your response,</div><div>Dale</div>]]>
   <pubDate>Fri, 29 May 2026 21:37:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16448&amp;PID=155549#155549</guid>
   <title>Dometic refirgerator not working on electric : You have done some good elemination/investigation...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16448&amp;PID=155547#155547</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 16448<br /><strong>Posted:</strong> 29 May 2026 at 9:01am<br /><br />You have done some good elemination/investigation of the problem.&nbsp; But the Dometic 8501 has a serviceable life of 5 to 7 years. There are a couple of things that could be causing the problem you are having.&nbsp; There are several electrical components if not working correctly that would cause your problem. Such as the "motherboard" or the 110v electrical elements them selves come to mind.&nbsp; It depends on just how much you want to invest in your fridge.&nbsp;Hope this helps you and feel free to private messsage me if you want. Jay<br>]]>
   <pubDate>Fri, 29 May 2026 09:01:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16448&amp;PID=155547#155547</guid>
   <title>Dometic refirgerator not working on electric : I have a 2016 RPOD 178. Recently,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16448&amp;PID=155546#155546</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14189" rel="nofollow">Dalebrons</a><br /><strong>Subject:</strong> 16448<br /><strong>Posted:</strong> 28 May 2026 at 10:57pm<br /><br />I have a 2016 RPOD 178. Recently, the Dometic refrigerator quit working on electric only. It still works when it is set to "gas" or to "battery."&nbsp;<div><br></div><div>The microwave/induction oven still works. The lights work. The slide-out still works.&nbsp;</div><div><br></div><div>Thoughts?</div><div><br></div>]]>
   <pubDate>Thu, 28 May 2026 22:57:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16448&amp;PID=155546#155546</guid>
