  <title>R-pod Owners Forum : New Member First Post</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : New Member First Post</description>
  <pubDate>Wed, 23 Sep 2026 09:05:39 +0000</pubDate>
  <lastBuildDate>Fri, 08 May 2026 22:41:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16439</WebWizForums:feedURL>
   <title>New Member First Post : You have a nice setup, congratulations!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155516#155516</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 16439<br /><strong>Posted:</strong> 08 May 2026 at 10:41pm<br /><br /><div>You have a nice setup, congratulations!&nbsp; Having owned a 177 for over 15 years, it has been towed by the following: '94 F-150, '08 and '13 front wheel drive Explorers, '11 F-150, and currently a "17 F-150 with the 3.5 EB.&nbsp; All have been towed with a Curt friction bar, no WDH.&nbsp; Have towed through snowstorms, hail, sleet, heavy rain and winds in excess of 25 mph without issue.&nbsp; You do need this info however, weigh your fully loaded 171 as though you were going on a trip, you want 10% or more of that weight on your tongue (a-frame).&nbsp; Our 177 fully loaded for a 30 day journey (including 36 gallons of water, tank behind axle) comes in at 2940#.&nbsp; Tongue weight is 340# which is more than the 10% minimum, resulting in a smooth relaxing ride, regardless of weather or road conditions.</div><div><br></div><div>Welcome to your 24/7 'owners manual.'</div>]]>
   <pubDate>Fri, 08 May 2026 22:41:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155516#155516</guid>
   <title>New Member First Post : Welcome! The 3.5L EcoBoost is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155514#155514</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11535" rel="nofollow">Rpod-Couple</a><br /><strong>Subject:</strong> 16439<br /><strong>Posted:</strong> 08 May 2026 at 9:31pm<br /><br />Welcome! The 3.5L EcoBoost is more than capable towing a 171. I have a VW Atlas with the 275 hp 3.5L V6 I tow a 2021 171. It tows nicely. I have towed the 171 with and without a WDH. I prefer using a WDH since it smooths out the ride on my softly sprung SUV. Don’t go overboard getting a WDH with 1000lb tongue weight. It will be way too stiff a ride and you run the risk of bending the trailer tongue. I replaced the 1000lb spring bars on my WDH with 600lb bars after the first trip and the ride is so much smoother.&nbsp;]]>
   <pubDate>Fri, 08 May 2026 21:31:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155514#155514</guid>
   <title>New Member First Post : Welcome! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155513#155513</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 16439<br /><strong>Posted:</strong> 08 May 2026 at 7:04pm<br /><br />Welcome!]]>
   <pubDate>Fri, 08 May 2026 19:04:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155513#155513</guid>
   <title>New Member First Post : That&amp;#039;s a good combo.We pull...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155512#155512</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 16439<br /><strong>Posted:</strong> 08 May 2026 at 1:03pm<br /><br />That's a good combo.<div><br></div><div>We pull our RP179 HRE with our 2015 F150, also with the 3.5L EcoBoost. We use an E2 WDH, and it's been about as flawless as can be.</div>]]>
   <pubDate>Fri, 08 May 2026 13:03:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155512#155512</guid>
   <title>New Member First Post : Hello from central NM. This is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155508#155508</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14265" rel="nofollow">JWake</a><br /><strong>Subject:</strong> 16439<br /><strong>Posted:</strong> 08 May 2026 at 10:21am<br /><br />Hello from central NM.&nbsp; This is my first post.&nbsp; I am considering purchase of a new rpod 171 Hood River Edition.&nbsp; I live an hour out of Albuquerque and they have one in stock that I have looked at.&nbsp; I have a new Ford F-150 XLT with the 3.5 ecoboost engine so towing the 171 should not be an issue.&nbsp; The 171 has about everything I need and it will just be me using it.&nbsp; Right now the only upgrade I am considering is going to a lithium battery and adding a Weight Distro Hitch.&nbsp; I would be driving on fairly well maintained dirt roads on occasion.&nbsp; Any thoughts or recommendations would be appreciated!&nbsp;&nbsp;]]>
   <pubDate>Fri, 08 May 2026 10:21:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16439&amp;PID=155508#155508</guid>
