  <title>R-pod Owners Forum : Weight Equalizer Hitch</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Weight Equalizer Hitch</description>
  <pubDate>Fri, 23 Oct 2026 05:33:02 +0000</pubDate>
  <lastBuildDate>Sat, 16 May 2026 19:46:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16435</WebWizForums:feedURL>
   <title>Weight Equalizer Hitch : Yes, 15 years towing our 2011...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155530#155530</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 16435<br /><strong>Posted:</strong> 16 May 2026 at 7:46pm<br /><br />Yes, 15 years towing our 2011 177 using a basic Curt friction bar over 53,000+ miles through blizzards, sleet, hail, thunderstorms, and cross winds in excess of 25 mph without incident.&nbsp; Tow vehicles have included over the years and in order: '94 F-150 5.0L V-8,manual shift, '08 Explorer front wheel drive 4.0L, V-6 '13 Explorer front wheel drive 3.5L V-6, '11 F-150 5.0L V-8, and since 2020 a '17 F-150 3.5 V-6 with ecoboost.&nbsp; Really enjoyed the Explorers but wanted a bit more storage for when we go on month long trips boondocking for the most part.&nbsp; The big thing you want to remember is to have at least 10% of the total loaded weight of your 171 on the a-frame (tongue).&nbsp; Our 177 fully loaded with 36 gallons of water and prepped for a 30 day excursion weighs in at 2940 lbs.&nbsp; The minimum tongue weight (10% would be 294 lbs. on the tongue.&nbsp; I carry a Sherline tongue weight scale (current cost around $165 for a 0-1000# scale) and it reads 340# so I am at 11.6%, well over the minimum 10%, hence, no problems with sway.]]>
   <pubDate>Sat, 16 May 2026 19:46:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155530#155530</guid>
   <title>Weight Equalizer Hitch : Thanks for the repoly.IS anyone...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155529#155529</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14250" rel="nofollow">kevinkirk51</a><br /><strong>Subject:</strong> 16435<br /><strong>Posted:</strong> 16 May 2026 at 2:40pm<br /><br />Thanks for the repoly.&nbsp;<div>IS anyone towing without equalizer hitch . have a rpod 171 and a new 1500 truck 4x4</div>]]>
   <pubDate>Sat, 16 May 2026 14:40:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155529#155529</guid>
   <title>Weight Equalizer Hitch : What you need for your wayward...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155494#155494</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 16435<br /><strong>Posted:</strong> 04 May 2026 at 2:16pm<br /><br />What you need for your wayward 17 is an anti-sway bar like this: https://www.etrailer.com/Weight-Distribution-Hitch/CURT/17200.html?feed=npn&amp;gad_source=1&amp;gad_campaignid=11229265674&amp;gbraid=0AAAAAD_vMtkfndD2i950l4YLqmz9qzEJq&amp;gclid=Cj0KCQjwh-HPBhCIARIsAC0p3cdc31bSLdjrFwbPalJMHUHoUNOE9eTfq77tb7sCspJNGr6bPXeLwvoaAlPbEALw_wcB.&nbsp;<div><br></div><div>A weight distribution hitch levels the the rig, trailer and tow vehicle, by distributing weight. Some have anti-sway built into them and some will not.&nbsp;&nbsp;</div>]]>
   <pubDate>Mon, 04 May 2026 14:16:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155494#155494</guid>
   <title>Weight Equalizer Hitch : Does anyone use one of these with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155493#155493</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14250" rel="nofollow">kevinkirk51</a><br /><strong>Subject:</strong> 16435<br /><strong>Posted:</strong> 04 May 2026 at 1:01pm<br /><br />Does anyone use one of these with an Rpod 17. I have towed it some and it can search for a path it seems like. Will a hitch solve that problem.&nbsp;<div><br></div>]]>
   <pubDate>Mon, 04 May 2026 13:01:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16435&amp;PID=155493#155493</guid>
