  <title>R-pod Owners Forum : Left turn/brake lights</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Left turn/brake lights</description>
  <pubDate>Fri, 23 Oct 2026 05:25:24 +0000</pubDate>
  <lastBuildDate>Wed, 09 Sep 2026 15:48:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16412</WebWizForums:feedURL>
   <title>Left turn/brake lights : That happens once in a while....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155693#155693</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 09 Sep 2026 at 3:48pm<br /><br />That happens once in a while. You're the lucky 1 in 10,000 that got the bad LED.<div><br></div><div><img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><br></div><div><br></div>]]>
   <pubDate>Wed, 09 Sep 2026 15:48:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155693#155693</guid>
   <title>Left turn/brake lights : Ended up replacing the tail light....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155691#155691</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14222" rel="nofollow">Beckman0208</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 09 Sep 2026 at 5:18am<br /><br />Ended up replacing the tail light. Seems the led lights were bad. ]]>
   <pubDate>Wed, 09 Sep 2026 05:18:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155691#155691</guid>
   <title>Left turn/brake lights : Update plugged into camper and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155432#155432</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14222" rel="nofollow">Beckman0208</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 14 Apr 2026 at 6:27am<br /><br />Update plugged into camper and no signals. So i hauled it to fix it shop. They moved some wires around on the plug and all seems well. Hauled her home will update next time she goes out. ]]>
   <pubDate>Tue, 14 Apr 2026 06:27:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155432#155432</guid>
   <title>Left turn/brake lights :   Originally posted by Beckman0208Ok...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155405#155405</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 31 Mar 2026 at 6:06pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Beckman0208</strong></em><br /><br />Ok update. Ground wire was attached to painted frame. So i removed the paint reattached with a grip washer close to the frame. Seems to be working now.</td></tr></table></div><div><br></div><div>Wonderful!&nbsp; I am still curious as to why it would function until you brought the slide in.&nbsp; From what you describe, the ground was the issue, the painted frame caused it; by running your slide this would not change so is it possible that the left brake blinker never worked in the first place?</div>]]>
   <pubDate>Tue, 31 Mar 2026 18:06:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155405#155405</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155404#155404</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8159" rel="nofollow">poston</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 31 Mar 2026 at 1:45pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Beckman0208</strong></em><br /><br />Ok update. Ground wire was attatched to painted frame. So i removed the paint reattached with a grip washer close to fhe frame. Seems to be working now.</td></tr></table><div><br></div><div>Great work, and thanks for the update!</div><div><br></div><div>It's so helpful&nbsp;for fellow Podders when the original poster follows up with what worked (and even what didn't work).&nbsp;</div>]]>
   <pubDate>Tue, 31 Mar 2026 13:45:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155404#155404</guid>
   <title>Left turn/brake lights : Ok update. Ground wire was attatched...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155403#155403</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14222" rel="nofollow">Beckman0208</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 31 Mar 2026 at 1:27pm<br /><br />Ok update. Ground wire was attatched to painted frame. So i removed the paint reattached with a grip washer close to fhe frame. Seems to be working now. ]]>
   <pubDate>Tue, 31 Mar 2026 13:27:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155403#155403</guid>
   <title>Left turn/brake lights : There is no reason the turn signmal...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155402#155402</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 31 Mar 2026 at 1:15pm<br /><br />There is no reason the turn signmal light wiring needs to go up into the cabin. I would look below where the wires go out to the fender (and below the slide out).]]>
   <pubDate>Tue, 31 Mar 2026 13:15:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155402#155402</guid>
   <title>Left turn/brake lights : In my 179, the slide wiring is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155400#155400</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 30 Mar 2026 at 12:49pm<br /><br /><div>In my 179, the slide wiring is behind the movable panel under the refrigerator.</div><div>From your&nbsp; description, it does sound like&nbsp; wires are moving and some are shorting out as the slide moves and pulls wire with it</div><div><br></div><div>Good luck</div><div>Travel often and safe</div><div>Vann</div>]]>
   <pubDate>Mon, 30 Mar 2026 12:49:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155400#155400</guid>
   <title>Left turn/brake lights : +1 That sounds like a ground issue...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155397#155397</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 30 Mar 2026 at 10:11am<br /><br />+1 That sounds like a ground issue someplace.]]>
   <pubDate>Mon, 30 Mar 2026 10:11:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155397#155397</guid>
   <title>Left turn/brake lights : Going to check ground again later....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155395#155395</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14222" rel="nofollow">Beckman0208</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 30 Mar 2026 at 10:06am<br /><br />Going to check ground again later. Noticed it was not against bare metal. Its up against painted black frame. ]]>
   <pubDate>Mon, 30 Mar 2026 10:06:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155395#155395</guid>
   <title>Left turn/brake lights : Personally I have not, however...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155393#155393</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 30 Mar 2026 at 9:18am<br /><br />Personally I have not, however there are a lot of wires bundled together in the slide area that move back and forth when the slide is activated.&nbsp; Hopefully you have a voltmeter and can trace the bad wires or physically locate the wire bundle and find which wires have been compromised.&nbsp; On my 177 the wires are behind a removable panel located under the sink just above the floor and are easily accessible.]]>
   <pubDate>Mon, 30 Mar 2026 09:18:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155393#155393</guid>
   <title>Left turn/brake lights : I have a 2018 179. With the slide...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155390#155390</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14222" rel="nofollow">Beckman0208</a><br /><strong>Subject:</strong> 16412<br /><strong>Posted:</strong> 30 Mar 2026 at 5:59am<br /><br />I have a 2018 179. With the slide open i have all running/brake/turn signals on both sides. When i close the slide i am losing brake/ turn signals on left side. Anyone seen this problem? Lights usually go out when slide has about 2 inches left before fully closing. ]]>
   <pubDate>Mon, 30 Mar 2026 05:59:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16412&amp;PID=155390#155390</guid>
