  <title>R-pod Owners Forum : CO2 alert beeping</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : CO2 alert beeping</description>
  <pubDate>Fri, 23 Oct 2026 11:59:43 +0000</pubDate>
  <lastBuildDate>Wed, 31 Dec 2025 11:50:34 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16338</WebWizForums:feedURL>
   <title>CO2 alert beeping : Always open a window when you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155186#155186</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14150" rel="nofollow">ppine</a><br /><strong>Subject:</strong> 16338<br /><strong>Posted:</strong> 31 Dec 2025 at 11:50am<br /><br />Always open a window when you run any propane device.&nbsp;<div>The refir is vented outside.&nbsp;</div><div>I do not run the furnace at night and only in really cold weather in the morning.&nbsp;</div><div>Mild exposure to CO means you need to get to fresh air.&nbsp;</div><div>Exposure can make you sleepy which is really dangerous.&nbsp;</div>]]>
   <pubDate>Wed, 31 Dec 2025 11:50:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155186#155186</guid>
   <title>CO2 alert beeping : It should be noted that carbon...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155142#155142</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 16338<br /><strong>Posted:</strong> 07 Dec 2025 at 3:02pm<br /><br />It should be noted that carbon monoxide is odorless, colorless, and extremely toxic. It will displace oxygen in your bloodstream and once it's bound to your hemoglobin, it can <b><u>NOT</u></b> be removed. The only cure for CO poisoning is a transfusion, and quickly.]]>
   <pubDate>Sun, 07 Dec 2025 15:02:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155142#155142</guid>
   <title>CO2 alert beeping : What ppine said.A small point...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155138#155138</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 16338<br /><strong>Posted:</strong> 06 Dec 2025 at 2:23pm<br /><br /><div>What ppine said.</div><div><br></div><div>A small point though.&nbsp; It's a Carbon Monoxide (CO) detector, not a Carbon Dioxide (CO2) detector.</div><div><br></div><div>TT</div>]]>
   <pubDate>Sat, 06 Dec 2025 14:23:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155138#155138</guid>
   <title>CO2 alert beeping :  They have an expected life of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155135#155135</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14150" rel="nofollow">ppine</a><br /><strong>Subject:</strong> 16338<br /><strong>Posted:</strong> 06 Dec 2025 at 11:38am<br /><br />They have an expected life of 5 years.&nbsp; After that that start beeping at odd times.&nbsp;<div>I just removed mine.&nbsp; I only use the stove and open a window.&nbsp;</div><div>A new one is about 30 dollars.&nbsp; I will replace it sometime.&nbsp;</div><span style="font-size:10px"><br /><br />Edited by ppine - 06 Dec 2025 at 11:39am</span>]]>
   <pubDate>Sat, 06 Dec 2025 11:38:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155135#155135</guid>
   <title>CO2 alert beeping :    </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155084#155084</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5762" rel="nofollow">Annie</a><br /><strong>Subject:</strong> 16338<br /><strong>Posted:</strong> 17 Nov 2025 at 3:19pm<br /><br />]]>
   <pubDate>Mon, 17 Nov 2025 15:19:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16338&amp;PID=155084#155084</guid>
