  <title>R-pod Owners Forum : TV Antenna</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : TV Antenna</description>
  <pubDate>Fri, 23 Oct 2026 19:30:38 +0000</pubDate>
  <lastBuildDate>Thu, 21 Aug 2025 11:06:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16274</WebWizForums:feedURL>
   <title>TV Antenna : If you put a different antenna...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16274&amp;PID=154833#154833</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 16274<br /><strong>Posted:</strong> 21 Aug 2025 at 11:06am<br /><br />If you put a different antenna up there, it will need a matching amplifier, but it should work about as well as the OEM antenna.]]>
   <pubDate>Thu, 21 Aug 2025 11:06:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16274&amp;PID=154833#154833</guid>
   <title>TV Antenna : The 2016 183G that we picked up...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16274&amp;PID=154829#154829</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14020" rel="nofollow">Jcmorgan31</a><br /><strong>Subject:</strong> 16274<br /><strong>Posted:</strong> 20 Aug 2025 at 2:58pm<br /><br />The 2016 183G that we picked up a month ago does not have an antenna on it.&nbsp; &nbsp;I can see where the antenna was, but it has been removed and the roof patched.&nbsp; &nbsp;I pulled the radio a couple of days ago and it looked like the antenna had been leaking in the past, so I assume a previous owner just took it out.<div><br></div><div>My question is has anyone just used a portable TV antenna that you could just sit on the roof once parked and run a coax down to the antenna / cable in on the camper?&nbsp; &nbsp;</div><div><br></div><div>Will the antenna amplifier send power back to this port if I want to use a boosted antenna like this?</div><div><br></div><div>I could purchase and reinstall an antenna where the old one was, but not sure I want to put that hole back in the roof.</div><div><br></div><div>Thanks in advance!</div>]]>
   <pubDate>Wed, 20 Aug 2025 14:58:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16274&amp;PID=154829#154829</guid>
