  <title>R-pod Owners Forum : Door Won&#039;t Open After Transit</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Door Won&#039;t Open After Transit</description>
  <pubDate>Sun, 25 Oct 2026 06:04:40 +0000</pubDate>
  <lastBuildDate>Mon, 10 Feb 2025 11:17:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16121</WebWizForums:feedURL>
   <title>Door Won&#039;t Open After Transit : I&amp;#039;ve added to my shopping...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154216#154216</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13791" rel="nofollow">LuckyLindy</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 10 Feb 2025 at 11:17am<br /><br />I've added to my shopping list! Thanks jato.]]>
   <pubDate>Mon, 10 Feb 2025 11:17:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154216#154216</guid>
   <title>Door Won&#039;t Open After Transit : I have had tremendous success...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154215#154215</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 09 Feb 2025 at 9:23pm<br /><br />I have had tremendous success using a penetrant for issues such as you raised.&nbsp; Schaeffer's 'Penetrol 90' is excellent (we have used it at the golf courses for years) for rusted bolts/nuts or metal that is bound together.&nbsp; You think WD 40 is good, you'll never use that again after using this product.]]>
   <pubDate>Sun, 09 Feb 2025 21:23:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154215#154215</guid>
   <title>Door Won&#039;t Open After Transit : Just to say thanks to all of you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154213#154213</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13791" rel="nofollow">LuckyLindy</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 09 Feb 2025 at 7:20pm<br /><br />Just to say thanks to all of you who shared experience w/o making me feel like a total rookie. I'm sure to maintain my "newbie" status for some time, but the day will come (hopefully sooner than later) when I can "pass it forward." Happy Trails, or as we say in the aviation world, "Blue Skies and Tailwinds."<div><br></div><div>LL<br><div><br></div></div>]]>
   <pubDate>Sun, 09 Feb 2025 19:20:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154213#154213</guid>
   <title>Door Won&#039;t Open After Transit : Got it! I used lock and hinge...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154212#154212</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13791" rel="nofollow">LuckyLindy</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 09 Feb 2025 at 7:13pm<br /><br />Got it! I used lock and hinge spray in all 3, still stiff enough to avoid wind damage but all the sound has disappeared. Thank you!&nbsp;]]>
   <pubDate>Sun, 09 Feb 2025 19:13:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154212#154212</guid>
   <title>Door Won&#039;t Open After Transit : Friction hinges need to be lubed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154211#154211</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 08 Feb 2025 at 8:40pm<br /><br />Friction hinges need to be lubed more than regular hinges in my experience. If you let them get too stiff and you open and close the door, you could twist the light metal frame and then you have a bigger problem ]]>
   <pubDate>Sat, 08 Feb 2025 20:40:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154211#154211</guid>
   <title>Door Won&#039;t Open After Transit : Used lightweight &amp;#034;lock and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154210#154210</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13791" rel="nofollow">LuckyLindy</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 06 Feb 2025 at 7:36am<br /><br />Used lightweight "lock and hinge" spray lube and have main door working perfectly. Screen door as well. Leveling helped. Many thanks to all!&nbsp;]]>
   <pubDate>Thu, 06 Feb 2025 07:36:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154210#154210</guid>
   <title>Door Won&#039;t Open After Transit : Thank you!This makes sense (the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154199#154199</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13791" rel="nofollow">LuckyLindy</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 02 Feb 2025 at 6:31pm<br /><br />Thank you!&nbsp;<div>This makes sense (the friction hinge) for wind control. What concerns me is the door operated smoothly at the lot where I purchased it. Only after a 25 mile trip did it bind up. I hesitated to lubricate the hinges until the service department looks at the problem. Will post!</div>]]>
   <pubDate>Sun, 02 Feb 2025 18:31:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154199#154199</guid>
   <title>Door Won&#039;t Open After Transit : Thank you!I did try all these...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154198#154198</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13791" rel="nofollow">LuckyLindy</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 02 Feb 2025 at 6:28pm<br /><br />Thank you!&nbsp;<div>I did try all these options w/ limited success. The door is still binding pretty tight.&nbsp;</div><div>Headed to an RV service center this week. Will post!</div>]]>
   <pubDate>Sun, 02 Feb 2025 18:28:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154198#154198</guid>
   <title>Door Won&#039;t Open After Transit : I have a 2019 179 and +to what...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154196#154196</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 02 Feb 2025 at 8:51am<br /><br />I have a 2019 179 and +to what SH suggested it is spot on. Another thing that you could look at is that my 179 has a "friction" door hinge on that outside door. That becomes a little stiff to move, the intent of that hinge is not to allow the door to flop in the breezes when set up in the campground. Your trailer may have a door hinge that has not been lubricated over time and may have gotten too stiff which has caused what you are experiencing now. I have had to over time lubricated my door hinge so that is operatable. I have used WD-40 on the hinge which seems to have helped over time. Hope this helps you.]]>
   <pubDate>Sun, 02 Feb 2025 08:51:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154196#154196</guid>
   <title>Door Won&#039;t Open After Transit : Did you level with the stabilizers...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154193#154193</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 01 Feb 2025 at 11:09pm<br /><br />Did you level with the stabilizers or with leveling blocks? If you used the stabilizers to level it, then lower it back down. Then level it side-to-side with leveling blocks/ramps, etc. Then only put enough tension on the stabilizers to stabilize it (lower to the ground, then a turn or two after it gets tight). If you leveled with the jacks, then it flexed the frame and could be the cause of the door binding. You could try the door with the stabilizers off the ground. That would help confirm whether there had been too much pressure on the stabilizers or not.<div><br></div><div>Other than that, welcome and congratulations on your "new to you" RPod. I hope you have many fun adventures and make many great memories in your travels with it.</div><div><br></div>]]>
   <pubDate>Sat, 01 Feb 2025 23:09:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154193#154193</guid>
   <title>Door Won&#039;t Open After Transit : Picked up a well-maintained 2019...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154191#154191</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13791" rel="nofollow">LuckyLindy</a><br /><strong>Subject:</strong> 16121<br /><strong>Posted:</strong> 01 Feb 2025 at 10:45pm<br /><br />Picked up a well-maintained 2019 Model 191 today, my first. Got a solid briefing from the RV specialist at a car dealership. (Unit was a trade in for sale of a van). Hitched up and drove home on good roads. Arrived, unhitched including sway bars. Leveled the unit and went to unlock door only to find it binding. Could not open more than six inches. Screen door seemed free. Nothing lodged in between. Tried several different levels hoping it would "unbind." No luck. First recommendation, hitch up again and drive it locally, see if that frees up the bind. Any other suggestions welcome and thank you.&nbsp;]]>
   <pubDate>Sat, 01 Feb 2025 22:45:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16121&amp;PID=154191#154191</guid>
