  <title>R-pod Owners Forum : Dry caping power supply</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Dry caping power supply</description>
  <pubDate>Sun, 25 Oct 2026 10:47:31 +0000</pubDate>
  <lastBuildDate>Sat, 01 Feb 2025 23:13:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16119</WebWizForums:feedURL>
   <title>Dry caping power supply : That being said, I do use a Harbor...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16119&amp;PID=154194#154194</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 16119<br /><strong>Posted:</strong> 01 Feb 2025 at 11:13pm<br /><br />That being said, I do use a Harbor Freight tongue box to hold a 200ah LiFePO4 battery. The BMS in the batteries should protect it from cold weather charging. I do have some foam (the packing foam from the battery's original packaging) under and partly surrounding the battery. So far, it has worked well.<div><br></div><div>Also, you could find batteries that have a built-in heater to warm them in such situations. That does use some of the battery power, but does help with cold weather camping. Sometimes, there just isn't room inside so one has to adapt.</div>]]>
   <pubDate>Sat, 01 Feb 2025 23:13:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16119&amp;PID=154194#154194</guid>
   <title>Dry caping power supply : Lithium batteries are less tolerant...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16119&amp;PID=154189#154189</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 16119<br /><strong>Posted:</strong> 01 Feb 2025 at 11:37am<br /><br />Lithium batteries are less tolerant of cold temps, and can be damaged if you attempt to charge them when too cold. It's better to find a cubby inside to protect them from marginally cold temps.]]>
   <pubDate>Sat, 01 Feb 2025 11:37:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16119&amp;PID=154189#154189</guid>
   <title>Dry caping power supply : I have a rm177. Acis 11k. I also...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16119&amp;PID=154188#154188</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13795" rel="nofollow">Gbr1955</a><br /><strong>Subject:</strong> 16119<br /><strong>Posted:</strong> 01 Feb 2025 at 7:03am<br /><br />I have a rm177. Acis 11k. I also have a 3500 power inverter. Where can I find how to set up 2 lithium batteries 100ah each? Was thinking about a big box on camper front to house batteries and inverter.]]>
   <pubDate>Sat, 01 Feb 2025 07:03:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16119&amp;PID=154188#154188</guid>
