  <title>R-pod Owners Forum : taillights</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : taillights</description>
  <pubDate>Tue, 27 Oct 2026 18:46:10 +0000</pubDate>
  <lastBuildDate>Thu, 14 Nov 2024 11:35:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16085</WebWizForums:feedURL>
   <title>taillights : Thanks to both Larry D and Pod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154020#154020</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10701" rel="nofollow">tewjax</a><br /><strong>Subject:</strong> 16085<br /><strong>Posted:</strong> 14 Nov 2024 at 11:35am<br /><br />Thanks to both Larry D and Pod People for making me THINK. After a little more trouble shooting I found that it is my 7 pin plug not making a good connection. A little contact cleaner and maintenance goes a long way! Thanks again!]]>
   <pubDate>Thu, 14 Nov 2024 11:35:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154020#154020</guid>
   <title>taillights : Are both the left and right lights...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154017#154017</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 16085<br /><strong>Posted:</strong> 14 Nov 2024 at 9:49am<br /><br /><div><br></div><div>&nbsp;Are both the left and right lights out?? If so, check to insure that the main power cord from the tow vehicle is sending power to the lights.</div><div>If only one, replacement units are available form etrailer. Measure the diameter, the number of LED's and any manufacturer's number. they have several types.&nbsp; We have replaced one of ours before and they are exactly the same units.</div><div>Travel often and safe</div><div>Vann<br></div>]]>
   <pubDate>Thu, 14 Nov 2024 09:49:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154017#154017</guid>
   <title>taillights : If they&amp;#039;re LED you have to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154010#154010</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7744" rel="nofollow">Larry-D</a><br /><strong>Subject:</strong> 16085<br /><strong>Posted:</strong> 13 Nov 2024 at 4:10pm<br /><br />If they're LED you have to replace the entire light.&nbsp; Check the wiring first to see if the connections are tight at the light and then "upstream" from there.]]>
   <pubDate>Wed, 13 Nov 2024 16:10:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154010#154010</guid>
   <title>taillights : Rear taillight out. Do you replace...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154008#154008</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10701" rel="nofollow">tewjax</a><br /><strong>Subject:</strong> 16085<br /><strong>Posted:</strong> 13 Nov 2024 at 3:33pm<br /><br />Rear taillight out. Do you replace bulb or entire assembly?]]>
   <pubDate>Wed, 13 Nov 2024 15:33:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16085&amp;PID=154008#154008</guid>
