  <title>R-pod Owners Forum : BEEPING</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : BEEPING</description>
  <pubDate>Wed, 23 Sep 2026 10:24:56 +0000</pubDate>
  <lastBuildDate>Mon, 11 Nov 2024 20:56:13 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16081</WebWizForums:feedURL>
   <title>BEEPING : When you plug in and the fridge...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16081&amp;PID=153993#153993</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 16081<br /><strong>Posted:</strong> 11 Nov 2024 at 8:56pm<br /><br />When you plug in and the fridge is on AC, it will beep if the door is open or ajar]]>
   <pubDate>Mon, 11 Nov 2024 20:56:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16081&amp;PID=153993#153993</guid>
   <title>BEEPING : Are you sure it is the AC? It...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16081&amp;PID=153992#153992</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 16081<br /><strong>Posted:</strong> 11 Nov 2024 at 8:29pm<br /><br />Are you sure it is the AC? It could be the refrigerator. If the battery was disconnected, it could also be the LP/CO detector. What year is your RPod? If it is 5 years old, the LP/CO detector has reached its end of life and needs to be replaced. If the battery is installed and not run down, it would be beeping periodically regardless of whether plugged in or not.<div><br></div><div>Look at the lights on the LP/CO detector and see if it is flashing a code that means it is time to replace it.</div>]]>
   <pubDate>Mon, 11 Nov 2024 20:29:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16081&amp;PID=153992#153992</guid>
   <title>BEEPING : WHEN I PLUG OUR R POD INTO THE...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16081&amp;PID=153991#153991</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13667" rel="nofollow">WHEATLEY</a><br /><strong>Subject:</strong> 16081<br /><strong>Posted:</strong> 11 Nov 2024 at 3:07pm<br /><br />WHEN I PLUG OUR&nbsp; R POD INTO THE ELECTRIC OUTLET THERE IS A BEEPING EVERY FEW SECONDS FROM THE AIR CONDITIONER I CHECKED THE FILTERS THEY ARE CLEAN.I CANT FIGURE WHY THE A/C IS BEEPING]]>
   <pubDate>Mon, 11 Nov 2024 15:07:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16081&amp;PID=153991#153991</guid>
